Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 06-22-2008, 11:51 AM   #1
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
Exclamation My tire blew up!
I always wanted to know what the hardest setting on my coilovers were, so I set them to the hardest 'track' setting. Also, my tires were pumped to around 45psi if I can recall.
On Saturday, I drive to work in the morning and park my car. The temperature outside was around 97ish all day. When I get off work at 7pm, I drive home. I hit those lane reflectors while changing a lane and I hear a louder thump than usual. My alignment then shifts to the left slightly and I notice something is wrong. While stopping towards a light my wheel is flat and has a large gash in it (75% of the sidewall).
Could the temperature, hardness setting, heat, and reflector bump be the cause of all this? I'm thinking that 45 psi in cool weather would actually be higher than 45psi once the temperatures rise dramatically. My tires are relatively new and still have the chalk lines in them. Just wanted to vent. My wheels are fine, so that's good
druxboyz is offline   Reply With Quote
Old 06-22-2008, 12:13 PM   #2
Spazman
Member#: 113519
2002 Forester
Your tire pressure would have raised throughout the day, as it got hotter the pressure increased probably stressing it to the point of failure once you hit the reflector.
SOrry for you luck.
Spazman is offline   Reply With Quote
Old 06-22-2008, 01:15 PM   #3
subaru3169
Member#: 55252
* pullup bar *
glad your wheels are ok=)
i guess it's time to deflate mine a little.. mine are on 40lbs when i had 'em mounted a couple weeks ago
subaru3169 is offline   Reply With Quote
Old 06-22-2008, 01:42 PM   #4
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
yea dude.. this weather is jacking us up! my black plastic thing that holds the antenna cracked too :/ (you newer wrx owners wouldnt know). Too much UV.
Old 06-22-2008, 05:35 PM   #5
subaru3169
Member#: 55252
* pullup bar *
whoa man.. i've had mine for 7yrs and i've never heard of that
Old 06-22-2008, 03:39 PM   #6
Subydude81
Member#: 118266
2007 Lexus IS250 RWD
6MT
Never run that high of pressure. What was the max pressure? 50? You definitely will be over 50 throughout the day of driving and 90+ degree weather. I run whats on the door jam, plus or minus 2-3lbs.
Subydude81 is offline   Reply With Quote
Old 06-22-2008, 04:43 PM   #7
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
holy ****...45psi??? i run 36f and 38r daily...i cant imgaine that much
Mr_Snips is offline   Reply With Quote
Old 06-22-2008, 06:17 PM   #8
mr.right
Member#: 183002
1996 camaro
teal
ouch, sorry to hear. tire pressure was probably too high, but i dont think it should have done that from a reflector...
mr.right is offline   Reply With Quote
Old 06-23-2008, 02:23 AM   #9
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
prior to the 45, an alignment shop has done 40's. I'll stay in the 38's from now on.
So my friend blew up his WRX crusher145 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 55 11-25-2005 07:33 PM
RAAAR - My turbo blew up!!!! darkangelgrafix Normally Aspirated with bolt-on Forced Induction Powertrain 7 12-06-2003 01:36 PM
My engine blew up (sort of) Jademonkey Normally Aspirated Powertrain 32 08-01-2003 02:18 AM
my friend blew up his GT.. what should he do? Rexman Legacy Forum 9 02-22-2003 12:27 PM
