Old 06-30-2008, 01:41 AM   #1
hotrod
Member#: 14141
2002 Impreza WRX
Default G force simulation of oil control
For those that think oil return is not a big issue on a flat engine, here is an interesting video that shows how Porsche simulated track G forces on a test rig.
It is easy to understand what the oil must be doing inside the engine as you watch the simulation.
http://www.autoblog.com/2008/06/27/v...ing-virtually/
Larry
hotrod is offline   Reply With Quote
Old 06-30-2008, 12:31 PM   #2
charliew
Member#: 125304
Great video. I couldn't read the gauges but it sounds like maybe 7500. This shows the R&D the big guys come up with. I don't think I can fathom a dry sump that will take those angles and Gs without sucking air. That shows why you need a good air seperator and tank.
charliew is offline   Reply With Quote
Old 06-30-2008, 08:12 PM   #3
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Do you mean wet sump? That's the type of conditions dry sump systems were designed for.
Old 06-30-2008, 02:07 PM   #4
dmross
Member#: 2818
2000 2.5RS
Very cool video.
dmross is offline   Reply With Quote
Old 06-30-2008, 09:58 PM   #5
hotrod
Member#: 14141
2002 Impreza WRX
A dry sump pulls a vacuum on the oil pan and pumps the oil and air into a holding tank where it has a chance to become de-aerated, then it pumps clean oil back to the engine.
They use several suction pump stages pulling oil from multiple locations in the engine and taking it all back to the surge tank.
Larry
Old 07-01-2008, 11:08 AM   #6
charliew
Member#: 125304
I meant mostly air.
My sportster is dry sump. When I hotrodded it if you kept the rpms up around 5k or more the rocker box area would fill up with oil and go out the breather and get all in the air filter and then run down the side of the bike. A Pro One (I think) pump with a bigger scavenge side pump fixed it. It seems that everything that is hotrodded needs oil system upgrades. That pump cost 500.00 but it was worth it.
Old 07-01-2008, 11:45 AM   #7
kellygnsd
Member#: 32669
LINK G4 hybrid STi
H-D sportster? Dry sump? Dang, I know nothing about those bikes exept they have what, like three seperate oil systems or something. I'd like to rebuild one someday just to see what's going on in there.
Old 07-01-2008, 12:41 PM   #8
modaddict
Member#: 95840
sold to a good bud
awaiting next car
that was a pretty cool video.
thanks larry.
modaddict is offline   Reply With Quote
Old 07-01-2008, 07:33 PM   #9
Rickyh
Member#: 40453
That engine sounds absolutely incredible!
Rickyh is offline   Reply With Quote
Old 07-02-2008, 03:08 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
That's pretty cool stuff. Thanks for sharing, Larry!
Old 07-02-2008, 12:07 PM   #11
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
They are limited to 1g but cool stuff.
Kosmic is offline   Reply With Quote
Old 07-02-2008, 04:38 PM   #12
JSC Speed
Member#: 75126
It looks like an amusement ride. Does not look like a cheap rig either.
JSC Speed is offline   Reply With Quote
Old 07-02-2008, 05:07 PM   #13
hotrod
Member#: 14141
2002 Impreza WRX
Not really, the absolute G force is limited to one G, but the effective G force is any G you care to use. A 45 degree tilt will will have the same effect on the oil as a 1 G cornering load in the real world, a 63 degree tilt the same effect as a 2 G load in the real world. A 90 degree tilt would be equal to an infinite G load.
The force vector is trying to simulate a situation which has 1 vertical G at all times plus a lateral, G load (cornering, acceleration or braking). In the sim when they increase the tilt they simultaneously increase the lateral load and reduce the G load along the engines physical vertical axis so except for inertial loads like toping a hill at speed and going weightless they can come very close to duplicating the effective force vector the engine sees in the real world.
Larry
oil coming out of boost controler avengermike Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-19-2005 06:14 PM
Air Force Joint Tactical Air Controllers (JTAC) video (need host) L Bo Off-Topic 17 05-23-2005 11:38 AM
playstation console+logitech driving force wheel+GT4+extra controller+memory card nkkilla Private 'For Sale' Classifieds 2 04-05-2005 09:50 AM
Force simulation for driving games (video) Gundoo Off-Topic 13 03-06-2005 05:35 PM
found conisderable amount of oil where boost controller Y's off juztin180 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-06-2003 03:15 PM
