#1 |
Member#: 17332
Vehicle:2004 Black STI Not stock anymore |
I'm planning to have a new Ray Hall Plug and Play Vi-PEC system installed week after next.
I occurred to me that aside from loss of cruise control, I haven't been able to confirm or deny whether ABS or EBD, or DCCD will be lost or affected. Any input appreciated. |
#2 |
Member#: 4800
TXIC
Vehicle:1990 Legacy & 97 OBS AWD 5MT EJ22T AWIC Swap |
I can't say with certainty about the newer cars, but with one of the higher end stand alones, Autronic SM4, LinkPlus G3, etc, you should be able to retain a lot if not most of the stock functionality.....as far as I know, when I do the swap in my legacy, I should be able to keep the cruise as long as I wire up an rpm signal to the cruise computer.
Obviously the newer cars are more complicated, so you just need to take some time looking at the wiring diagrams and determine what inputs the different control units utilize. |
#3 | |
Member#: 25952
Vehicle:1995 Impreza Coupe w/ "Extras" :-) |
The only system you'll loose is the Cruise Control because the DBW cars don't have a seperate cruise control module like the cable throttled cars do. The ABS and EBD (Both controlled in the ABS Pump) only share a VSS signal with the ECU from what I remember as well as the DCCD. |
#4 |
Member#: 58251
Vehicle:2004 Sti GT35R |
Any particular reason you chose such an unpopular ecu?
#5 |
Citizen Mick
Member#: 27646
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
I like the look of the feature list for the Vi-PEC, any it's backed by Ray Hall who knows what a standlone should do.
Zornorph - Please post your experience with the setup. |
#6 |
Member#: 17332
As everyone says, trust your tuner. He prefers it over his former favorite, Autronic. I wouldn't call it unpopular, I'd say new and lesser known. However, it does have Ray Hall's name on it, and my tuner has been using the ecu with good success on pro rally cars and other race applications.
I admit some concern, but I have been assured by people I trust that this is not "bleeding edge" technology. Also, it does have a knock control and works directly with the DBW, which although the autronic can be made to do it requires a $700 additional module and apparently does not work flawlessly. Last edited by Zornorph; 07-09-2008 at 08:42 PM. |
#7 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
That's the way to do it if they will be doing your tuning. Good luck with it!!!!
Ya know....WOT is pretty good for cruise control too! ![]() Jay |
#8 |
Member#: 17332
Thanks Jay - the tune is going to be after Maine Forest Rally - He's got to tune cars for that. After that, It's time to start saving for a Justice Racing longblock, cuz I'm sure the stocker will let go sooner or later. I need to start researching heads.
| Thread Tools | |
| Display Modes | |
| What is typical behavior/readings for an oil pressure gauge? | IceWilly | Newbies & FAQs | 2 | 03-23-2008 10:32 PM |
| What is typical STi Delivery mileage? | FrankRizzo | Newbies & FAQs | 45 | 03-10-2005 07:34 AM |
| What is a problem with the world that is fixable? | Gundoo | Off-Topic | 40 | 11-16-2004 07:16 PM |
| What is the matter with Integra drivers in SD this week? (long with cliffnotes) | Coati | Southern California Impreza Club Forum -- SCIC | 12 | 06-23-2004 02:06 AM |
| What is the deal with the keyed washer with a Hook? | latinskllz | Transmission (AT/MT) & Driveline | 1 | 09-11-2003 05:49 PM |
