Old 09-13-2008, 01:17 PM   #1
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Default DIY Fog Light Modd
Not Shure if this is the best thread to be posting this in but, I figured I took pics of most of the DI soY I'd put it in here (feel free to move it to a proper thread)
Ok to start I must give credit where credit is due I got most of my info from this thread....
http://forums.nasioc.com/forums/showthread.php?t=570252
but was still a bit confused so I made this to better help anyone else who wants to do the mod. As far as I know it works on most Impreza's (WRX or not, Wagon or Sedan) from 2002-2007. This may be an old modd but its new to me and always wanted to do it :: I finally grew a Pair and did:
This Modd will alow your fog lights to work independently without needing your Headlights on, It also allows the Fog Lights to stay on with with High-Beams. I am doing this on a 2007 WRX Ltd. Wagon.
Okay First you will need an Add-A-Circuit, you can get one at AutoZone for $6.99 this will be used to "tap" into the Fog Lamp Relay and it will allow a constant 12v source of power to the Fog Lamp switch (Not the Fog Lights themselves) So in other words the Fog light switch will work to turn the fog lights on and off at anytime.
You will be getting to the Relay from under your dash, Remove the coin tray and the 2 screws on both sides with a philipps head screwdriver, there is also a pop clip on the upper left side to be popped out, after that the lower part of the dash will be free and is held in with about 3 clips be gentle and drop it down ( careful not to pinch or pull any wires while doing so)
a Closer look at the fuses
There is a metal bracket that also need s to be removed in order to get to the relay that looks like this...
2 screws on both sides will get that out of your way.
Whooooohh Im getting sweaty crouching under there time to turn on my trusty "LITTLE" fan......
The Fog Relay is the third from the bottom just left of the fuses...Sorry I dont have a better pic of it before I took it out but this will be the most frustrating part of the DIY....Removing the relay!!! There are two tabs on both side but they are recessed. I used two flathead baby screwdrivers to hold the tabs and pried it out with a needlenose pliers... here it is
Now you wll need to bed a leg of the relay like so...
With that leg bent the Add-A Circuit comes into Play....
Solder the Circuit to the Relay like so...
As far as I know for the 06 and 07's (should fit back in fine on other model years) the relay housing needs to be modified in order to allow the realy to fit back in with its bent leg and added wire..... so out comes the trusty Dremmel
JoeSUBARU is offline   Reply With Quote
Old 09-13-2008, 01:20 PM   #2
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
this mod was in sport compact car in 2002.
scby rex is offline   Reply With Quote
Old 09-13-2008, 01:24 PM   #3
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Good to know, Yea its old but New to Me
Old 09-14-2008, 04:15 PM   #4
mbaker
Member#: 188614
2004 WRB WRX wagon
VF-37 twin scroll on E85!
good stuff looks like this is going to be my first mod!!!!
mike
mbaker is offline   Reply With Quote
Old 09-13-2008, 01:22 PM   #5
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
I dremmeled here....
Enough to get the realy in. (Be very careful while doing this, there are alot of wires around, and the plastic is fairily soft)
A few test fits in between using the Dremmel and Viola...
You are now ready to plug in the Add-A-Circuit. I chose to tap into my rear wiper fuse (seeing that it is a 12v constant) Ideally you would use the Illumination fuse, But I chose the Rear Wiper since it will supply constant power to the Fog switch.
Reassamble the dash (making shure not to pinch any wires)
Pop the Coin Tray back in and you sir are done...
Now on to the Good Stuff.....
I started the car and pressed in the Fog Switch....SUCCESS!!!
Fogs on Independently...
Fogs and Parking Lights...
Fogs, Parks, and Low Beams...
Fogs, Parks, Lows and Highs...
Old 10-01-2009, 03:06 PM   #6
x7742539329x
Member#: 205832
2005 saab 9-2x AERO
black
Originally Posted by JoeSUBARU View Post
hey i noticed there was two fuses and was just wondering what size that other fuse is? I can make out the red 10 Fuse but the other one?
x7742539329x is offline   Reply With Quote
Old 01-13-2010, 03:34 PM   #7
shibby2821
Member#: 229778
04 WRX
WR blue
do we need the extra purple fuse or will it run without it?
shibby2821 is offline   Reply With Quote
Old 09-13-2008, 01:23 PM   #8
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Ohhh Yea!!!
The Only downside was that the indicator light on the Fog Light switch no longer lights up when the switch is pressed in (in the ON position) Ehh a small Price to Pay for a Preety Cool Mod...(there must be a way around this, hmmmm)
Old 01-07-2009, 02:05 PM   #9
Shiz36
Member#: 147730
2007 Impreza 2.5i SE
Urban Gray Metallic
Ohhh Yea!!!
i think there is a way around it, turn your headlights on!
scoobymods mod won't illuminate the fog switch either until the headlights are on, just like factory.
Shiz36 is offline   Reply With Quote
Old 01-10-2009, 11:14 AM   #10
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Your right, I realized this the night after doing the modd
Old 07-28-2012, 05:20 PM   #11
boxer07wrx
Member#: 293439
2007 WRX
Ohhh Yea!!!
Did anyone figure out how to i just did this mod works great, but i want the light to turn on with the fogs
boxer07wrx is offline   Reply With Quote
Old 09-14-2008, 07:01 PM   #12
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
^ Glad to hear it ! Do It!!
You wont be sorry
Old 09-14-2008, 09:17 PM   #13
kamote
Member#: 184110
2007 impreza sti
i tried it.. it works like a champ..
kamote is offline   Reply With Quote
Old 09-14-2008, 09:19 PM   #14
chipusma12
Member#: 153464
2004 STi
Java Black Pearl
Thanks I have been looking for a way to do this with my JDM fogs forever
chipusma12 is offline   Reply With Quote
Old 09-15-2008, 07:56 PM   #15
kpalena
Member#: 82431
2006 06 wrx limited
CGM
YES!!! I searched and asked about this about a year ago....Fianlly!!!!
kpalena is offline   Reply With Quote
Old 09-15-2008, 08:33 PM   #16
rkramer
Member#: 118209
2015 WRX Limitec
There are MUCH easier ways to do this, without having to rig together an unreliable fuse block tap, and without messing with the relay. A couple lengths of wire and a few splices is really all it takes, search scoobymods.
(and the indicator light still works with the other mod)
rkramer is offline   Reply With Quote
Old 09-15-2008, 09:36 PM   #17
Gray Ghost
Member#: 162790
http://www.scoobymods.com/forums/sho...&threadid=1022
Seems alot more straight forward.
Gray Ghost is offline   Reply With Quote
Old 09-15-2008, 10:53 PM   #18
Handsdown
Member#: 29355
agreed... the OP's way of doing this is NOT optimal.
why put +12 across on the relay itself when you can just put +12 through an override switch and solder it into the orange wire?
silly.
Handsdown is offline   Reply With Quote
Old 09-17-2008, 11:22 PM   #19
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Awesome Glad it worked out
No problem, Glad I could help
Hahaa Yea this mod was new to me too, happy it helped
Im shure theres plenty of other ways of doing this mod. I just figured Id post how i did mine. After re-examining my indicator light does work (only when the low beams are on) but then again it shouldnt work on any other setting other than having the low beams on ::hence the wire tap:: (as it did originally before any mods were done)
silly.
Agreed
Old 10-04-2008, 08:55 PM   #20
kpalena
Member#: 82431
2006 06 wrx limited
CGM
I just completed the scoobymod method for this. It worked great. I simply used an inline splice connection on the orange wire and a shrink splice on the red/green side. The fogs with the high beams is really intense. I am happy. I also found out that one of my marker lights is out.....crap. Those things are a pain.
Old 10-06-2008, 11:33 AM   #21
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
why are people still posting this mod?? it was done correctly in 02....
jdubya301 is offline   Reply With Quote
Old 10-08-2008, 11:28 AM   #22
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Beacuase in 2002 I wasn't driving a WRX.... New TO ME
Old 12-26-2008, 11:51 AM   #23
pana24
Member#: 139487
2006 wrx
aspen white
Im going to get busy on this right away
pana24 is offline   Reply With Quote
Old 01-06-2009, 09:30 AM   #24
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
subscribed. Im doing this today lol
emsmap is offline   Reply With Quote
Old 01-06-2009, 10:18 AM   #25
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Nice!! Good Luck Guys
DIY MY02 fog light cover bracket that work with fog lights installed Darren_2.5RS Mid West Subaru Owners Club Forum -- MWSOC 1 04-23-2014 01:09 AM
diy fog light mod help! blakkboxer Electrical & Lighting 5 04-02-2009 07:46 PM
DIY fog light bulb replacement 04 wrx steakraw Interior & Exterior Modification 0 08-24-2008 09:42 PM
DIY fog light covers for 04-05 WRXs? ismegamanthere Interior & Exterior Modification 5 09-25-2007 10:37 AM
DIY fog lights and security? mr_yellow Newbies & FAQs 2 08-18-2003 05:51 PM
