Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 10-09-2008, 04:35 PM   #1
bjf498
Member#: 136774
2005 Impreza STI
Default Full-contact Disc brakes
What ever happened to that idea? Newtech brakes was the creator of them I think, I remember seeing them a while back on how stuff works. Here's a link scroll down about a 1/4 of the way:
http://www.carbibles.com/brake_bible.html
bjf498 is offline   Reply With Quote
Old 10-09-2008, 04:52 PM   #2
Back Road Runner
Member#: 60082
2004 Forester STI
I think one big issue is weight. The nice thing about current brake systems is they can be very light. With the full contact system pictured, you are putting quite a bit of mass out there at the wheels. The thermal control is nice as there is a LOT there, but it's a compromise. As well, the contact area isn't that big of a deal. The benefit with more contact area is better wear.
Back Road Runner is offline   Reply With Quote
Old 10-09-2008, 06:24 PM   #3
MasterKwan
Member#: 98961
2003 WRX
Expensive and pointless comes to mind. The brakes aren't the limiting factor when it comes to stopping the car.
MasterKwan is offline   Reply With Quote
Old 10-09-2008, 06:30 PM   #4
kumanchu
Member#: 146696
i abuse my crappy tires, they are SCREAAAMING
kumanchu is offline   Reply With Quote
Old 10-09-2008, 09:29 PM   #5
bjf498
Member#: 136774
2005 Impreza STI
I couldn't imagine it being any heaver than what the Subaru rally team uses, those things are HUGE!
Old 10-09-2008, 09:33 PM   #6
Daishi00
Member#: 78952
2005 WRX
CGM
If they have a ton of mass in there it'll help with brake fade.
Daishi00 is offline   Reply With Quote
Old 10-09-2008, 09:36 PM   #7
MasterKwan
Member#: 98961
2003 WRX
Fade? What fade? If you have fade on the street then you're using the wrong pads. I've run both the LGT and Brembo's on the track. They don't fade at all. Even with R-comps.
I think full contact calipers would make cooling the brakes that much tougher.
Old 10-10-2008, 02:20 AM   #8
oldmansan
Member#: 17877
Midnight Pearl
It's not the R-compounds that will fade the brakes. It's the combination of high speed, agressive pads (think Performance Friction or Panther XPs), threshold braking and the lack of brake ducts. I've cooked Motul RBF600 at the track with agressive pads and street tires. I installed brake ducts and was fine. I also recommend Castrol SRF and titanium plates between the pad and pistons.
San
oldmansan is offline   Reply With Quote
Old 10-09-2008, 11:49 PM   #9
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
Do you end up with more torque? It might be harder to modulate than normal brakes :shrug:
Butt Dyno is offline   Reply With Quote
Hmm....full contact karate without the grappling is pretty good. Snoopy Off-Topic 24 06-22-2007 01:58 PM
Sweet Japanese Full Contact MMA video Neek Off-Topic 12 05-24-2006 09:57 PM
$325; Rear drum to Disc JDM VENTED 10.5" disc brake for WRX or GC8 complete KIT supermoose Private 'For Sale' Classifieds 10 02-25-2006 02:50 PM
$120 pair of rear disc brake hubs for your drum-disc conversion supermoose Private 'For Sale' Classifieds 3 11-09-2005 08:25 PM
4 wheel disc brakes better that disc/drum? Whit Brakes, Steering & Suspension 26 01-08-2002 06:08 PM
