Old 10-11-2008, 05:44 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default Easy DIY compression test with pics!
Spent 45 min performing compression test with $25 compression tester today.
2002 WRX with 90k miles
Mods: VF34 @ 19psi protuned 282whp/272wtq
JDM STI TMIC
Maddad v2 DP & whisper catback
One step colder NGK platinum plugs
Stock intake with K&N panel filter
German castrol oil
1. Remove stock intake box, etc:
2. Remove 12mm bolt in order to remove coil pack from each cylinder:
3. Remove spark plugs using 5/8" long socket with an extension
4. Coil pack and spark plugs removed:
txl146 is offline   Reply With Quote
Old 10-11-2008, 05:44 PM   #2
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
5. Pull ignition fuse
- Fuse remover is located next to battery:
6. Connect compression tester into each cylinder:
7. Now it's time to crank the engine with wide open throttle. Crank the engine 6 times.
8. Repeat the test for each cylinder and pray numbers come out good:
Old 10-11-2008, 05:57 PM   #3
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
thanks!! will try soon
Jubert69 is offline   Reply With Quote
Old 10-11-2008, 06:02 PM   #4
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
You're welcome. Make sure to pray before performing a test!
One thing I forgot to mention is:
Make sure your car is warm when performing a test.
Old 10-11-2008, 06:41 PM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
you forgot a huge part.
throttle to the floor
sidewayz is offline   Reply With Quote
Old 10-11-2008, 06:43 PM   #6
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I mentioned above, ".... with wide open throttle..."
Old 02-04-2009, 10:59 PM   #7
o3WRXTC
Member#: 200856
1994 Legacy TSW
Red
why do you need to do it in WOT?? there's no real need for this imo
thats why you crank it 5-6 times to get the compression test.
imo your fouling your spark plugs when u do this. *good chance*
just my two cent
great write up tho.
o3WRXTC is offline   Reply With Quote
Old 02-05-2009, 12:22 AM   #8
meebs
Member#: 3251
2009 WRX Hatch
just my two cent
great write up tho.
oh boy.
meebs is offline   Reply With Quote
Old 02-05-2009, 01:32 AM   #9
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
Talking
just my two cent
great write up tho.
wow...just wow.
LOL, yup, you can foul your plugs going WOT.
Better put these suckers far away then..
I immediately thought of this after reading that.
http://forums.nasioc.com/forums/show....php?t=1123616
Magnum626 is offline   Reply With Quote
Old 02-05-2009, 10:55 AM   #10
WRXislander
Member#: 50064
'02 WRX
MBP
Originally Posted by Magnum626 View Post
wow...just wow.
BWAHAHAHAHAHAHAHAAHAHAA!!!!
WRXislander is offline   Reply With Quote
Old 02-05-2009, 02:51 AM   #11
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
just my two cent
great write up tho.
Like has been stated above already... the plugs are out of the car.
Secondly, you should still go WOT with the throttle just to get the throttle open to allow air to be less hindered going into the motor.
Thirdly, you just need to disconnect the brown wiring harness below the glove box right next to the door. This contains the fuel pump power etc... unplugging this is like turning the pump off so that you don't wash your cylinders with gasoline and thin out your oil.
Nuff said... This resolves any nonsense about any "clear flood mode" and "standard modern EFI operation" crap.
(And it takes like 5 seconds to unplug/plug it in.)
paintbing is offline   Reply With Quote
Old 03-27-2009, 05:09 PM   #12
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
just my two cent
great write up tho.
You are most certainly entitled to your wrong opinion...
This is how a compresson test is done...by the book...period.
Slowsoul is offline   Reply With Quote
Old 10-11-2008, 06:47 PM   #13
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
why do you crank with the throttle down? What difference does it make?
Bad Noodle is online now   Reply With Quote
Old 10-11-2008, 06:52 PM   #14
jrobinson
Member#: 190786
Sedona Red
Im guessing so all the air can get in.
jrobinson is offline   Reply With Quote
Old 10-12-2008, 01:32 AM   #15
WRXDK
Member#: 187983
2005 WRX
Wouldn't you need to remove the fuel pump relay also?
WRXDK is offline   Reply With Quote
Old 10-12-2008, 02:45 AM   #16
blahhblahh
Member#: 86659
2005 WRX Sedan
WR Blue
you can, but the fuel should just evaporate after you remove the tester.
blahhblahh is offline   Reply With Quote
Old 10-12-2008, 09:18 AM   #17
stikboy9
Member#: 85019
MY02 & MY04 Turbo'd
Money Pits
I would disconnect the fuel pump relay too. Something about raw fuel washing the cylinder walls and fuel dilution in the oil just sounds like bad ju ju to me....Great write up though! Now someone needs to make one for a leakdown test! Hint hint...
stikboy9 is offline   Reply With Quote
Old 10-13-2008, 05:20 AM   #18
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
The injectors need a ignition signal to fire so disconnecting the fuel pump relay is not really necessary.
GDR is offline   Reply With Quote
Old 04-07-2011, 01:02 AM   #19
minus500
Member#: 258271
Definitely pull the fuse or disconnect the harness. You don't want to wash the walls.
OP, good write-up.
minus500 is offline   Reply With Quote
Old 10-12-2008, 01:43 AM   #20
dome24
Member#: 111845
97 RUBAsU Tall2dr
04 FXT VF22/COBB AP
2 man job, or does the gauge peak hold?
dome24 is online now   Reply With Quote
Old 10-12-2008, 09:24 AM   #21
Bort
Member#: 27075
09 WRX, 03 WRX,
98 OBS
Yes, they hold peak.
Bort is offline   Reply With Quote
Old 10-12-2008, 06:57 PM   #22
03SubaruWRX
Member#: 158708
You would if you
had robot ears
Nice write up, can't wait to try it out for myself.
03SubaruWRX is offline   Reply With Quote
Old 10-12-2008, 07:12 PM   #23
csimp3
Member#: 188464
02 wrx
wrb, silver, black,primer
good write up with good pics, may have to give this one a shot this week
csimp3 is offline   Reply With Quote
Old 10-12-2008, 11:09 PM   #24
WRXislander
Member#: 50064
'02 WRX
MBP
Where'd you pick up the compression tester?
Old 10-12-2008, 11:57 PM   #25
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I picked one up from advance auto part.
Compression test instructions with pics. Impr3zy0u Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 123 03-27-2013 06:04 PM
new to boxers. help with compression test wildacex187 Newbies & FAQs 19 02-27-2007 11:03 PM
What is the standard compression test values on a 2.5ltr with forged pistons tino Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 11-25-2005 02:16 AM
can compression test be done with accessport and antitheft mode? anthonyrb98 Engine Management & Tuning 12 09-25-2005 04:05 PM
DIY Compression Test thoughto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-31-2004 05:31 PM
