Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 10-21-2008, 12:26 PM   #1
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
Impreza GC8 wiseco cant help, who can?
"Hybrid EJ22 with EJ25 DOHC Crank & Rods"
this is a wiseco stroker pistons set
part # - K602M975
I have this setup with my98 DOHC heads and phase2 head gaskets
this should according to wiseco yeild an 8.5:1 c/r
so my question in what should the psi read durring a compression check?
btw wiseco has been no help in the matter
2.5rsDOHC is offline   Reply With Quote
Old 10-21-2008, 02:46 PM   #2
Vmiz
Member#: 115744
reason they may not be able to help is the fact of compression readings will be different having to do with the altitude you are at and also cam timing will change that reading,
for instance as on my 12.1 motor advancing and retarding cam timing let the compression range from 180 to 240 and that was in a range of only 7 degrees of change.kind of a hard number for a company to pin down
Vmiz is offline   Reply With Quote
Old 10-21-2008, 05:18 PM   #3
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
so what should I do to be able to tell if Im losing compression if theres not a certain psi range to be looking for
Old 10-21-2008, 05:36 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
A leakdown test would help.
Jay
Old 10-21-2008, 09:29 PM   #5
BoostInc
Member#: 176520
1994 Legacy SS
black and mud
test all four cylinders. if they are all in a range within 20 or so your good. But guessin i would say anywhere from 120-150 maybe lower, its hard to say
BoostInc is offline   Reply With Quote
Old 10-22-2008, 12:36 AM   #6
silentt
Member#: 119995
2004 Outback XT
Peachy
20 or so? That's a pretty big discrepancy...
silentt is offline   Reply With Quote
Old 10-22-2008, 03:05 AM   #7
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
awesome little settup. is it the ej22t block with sti internals ?? or just NA ej22 with your stock rods and crank ?
IllNastyImpreza is offline   Reply With Quote
Old 10-22-2008, 08:13 PM   #8
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
would a leak down test be as accurate as a compression test?
yeah its a EJ22t with a phase1 EJ25 internals
TXIC, who here has an 02 WRX and cant help me out? scottyrx Texas Impreza Club Forum -- TXIC 5 12-06-2008 04:02 PM
Can anyone who can read Japanese help? f1vlad Off-Topic 22 11-18-2008 09:24 PM
Jamie (or anyone else who can help)...can you help me find brake part number(s)? kaisersouse Brakes, Steering & Suspension 6 06-19-2006 07:12 PM
I need someone's help who can draw on their comp. Shakuwa Off-Topic 3 05-08-2004 08:08 PM
Help! I cant remember who I bought my TXS st1 from!need info Camperguy New England Impreza Club Forum -- NESIC 6 08-04-2003 07:17 AM
