Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 10-24-2008, 01:44 AM   #1
lackofhp
Member#: 149001
09 Caliber
ex 07 WRX
Default TD04 19T Upgrade Discussion
My stocker is on the fritz and I am thinking of picking up a new/used one and going this route:
http://www.blouchturbo.com/turbos/WR...essor_Upgrade/
Has anyone had and experience with this? Trying to do some research and the good ole search button isnt helping much.
If it helps, current power mods:
STi TMIC
SPT Intake
Flying Performance BCS
TurboXS Catless TBE
Grimmspeed uppipe with Tial 38mm EWG
Note- I will get retuned (even if I just get a OEM replacement)
lackofhp is offline   Reply With Quote
Old 10-24-2008, 01:47 AM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
If you're not going to get a re-tune for it, stick with an OEM TD04.
Audiosavvy is offline   Reply With Quote
Old 10-24-2008, 01:49 AM   #3
lackofhp
Member#: 149001
09 Caliber
ex 07 WRX
It will get retuned. I did a little detuning tonight with my tuner (awdtuning.com) so that I can prolong the current one.
Old 10-24-2008, 01:59 AM   #4
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Ok, as long as you've got that covered you should be good. I don't have any personal experience with that turbo, but it would be a cool experiment! Good luck.
Old 10-24-2008, 02:20 AM   #5
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
hey i have really been looking into this, i talked to a guy and bought a turbo that i thought was a 19t wheel , ended up being a 16g wheel but what i found out, it that the TD04 wheel is to small, and you loose power over the whole power band, a better set up would be basicly what i have, its a TD04 exhaust housing bored to fit a TD04HL wheel, which is basicly a TD05, and then sticking the 19t or a 16g wheel on there , i believe the 19t is a 31lbs/hr wheel and the 16g is a 32.5lbs/hr wheel, with the 16g and TD04HL wheel i hit full boost by 2650, and at 12psi, im pushing more power that with the stock at 20psi, if you want, you can pm me and i can send you some of the links, and alot of the info i have found. forced performace sells the exhaust wheel for 237.50 , its the only place i could find it, but either way it will be a nice set up that has lots of power and the amount of spool up time of a reg TD04
also i will have a stock TD04 with like no play in it, in about a week and a half or so, and im in the houston area
seanathanq83 is offline   Reply With Quote
Old 07-28-2009, 12:45 AM   #6
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
Thought I would bump this tread back up with my results of the Blouch TD04-19T on my 05 WRX. This thread was helpful awhile back and it felt appropriate to add some info...
Mod List
Stock 2.0l
TD04-19T ported and clipped
Ver 8 JDM TMIC
Stock air box with Subaru AA080 filter
GM EBCS
APS turbo inlet
Pink Injectors
STi up-pipe
Stock mid-pipe to Prodrive Axle back with a Invidia down-pipe
This graph was not the finished product, the final graph is alot smother... but it shows the difference between my stage 2 setup over the TD04-19t aftermath. spools fast as hell on the street I'm seeing 19-20psi at 2700rpm and ended up with 277hp and 277ft-lbs
and here's the difference between a VF39 (dotted line) and the Blouch TD04-19t (Solid line)
VF-39 WRX
Stock 2.0l
VF-39
e-bay TMIC
APS 65mm cold air
Pink Injectors
catless up-pipe
full 3" turbo back
I like to see how this turbo blows the socks off the VF-39 even with the stock air box and basically a stock cat back
Steve
Surfer Steve is offline   Reply With Quote
Old 07-28-2009, 02:20 PM   #7
WRX SEX
Member#: 212171
08 SSM WRX
MSPT Tuned: 254whp/343wtq
so you're peaking at 20psi and the tapering to...
WRX SEX is offline   Reply With Quote
Old 09-08-2009, 12:35 PM   #8
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Mod List
Stock 2.0l
Ver 8 JDM TMIC
GM EBCS
APS turbo inlet
Pink Injectors
STi up-pipe
VF-39 WRX
Stock 2.0l
VF-39
e-bay TMIC
APS 65mm cold air
Pink Injectors
catless up-pipe
full 3" turbo back
Steve
LOL, I figured I stop in and see if i could find any performance numbers from this turbo, as it seems to be a hot topic. Dyno numbers dont mean much, im curious of traps.
It seems to make decent power with great spool, but I think you should concentrate on going faster than the fastest td04 car before trying to beat up on 39's / 43's.
STi Mikey is offline   Reply With Quote
Old 09-08-2009, 07:46 PM   #9
SacksLax
Member#: 193949
BugI WRX "Rissa Roo"
WRB E III XVIG
Fact...
Comparing dyno numbers are like hot chicks on myspace. Sure some look great at first, then they are a pure let-down in real life.
Traps are a more accurate way of telling power, a dyno is just a means of getting a semi-consistent, semi-accurate measure.
My stock td04 made 250/252 on pump at EPIC on a mustang. Is it faster than one that might make 240 somewhere else? You can't tell without traps and slips.
SacksLax is offline   Reply With Quote
Old 09-08-2009, 09:48 PM   #10
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
LOL you're funny ^^^ I'm NOT concerned about being the fastest TD04 out there that's not what I build my car for I have never been down a drag strip in my suby and don't plan on it.. do you seriously think I give a flying turd if my car is faster than joe shmo HaHa My main concern is spool and torque on my 2.0 and the fact is this turbo setup fits my needs better than a 39 or 43 and I don't see a VF-39 out spooling the 19t upgrade any time soon, not to mention it puts out close to the same power as a 39 and for a practically a brand new turbo you can't beat the price over a new VF-39
Also, dyno numbers and logging may not tell you much about your almighty "trap speed" and "1/4 mile times" but they do show factually information like spool and horsepower that can be utilized to compare to other setups(same dyno)... I have all the respect for drag guys, however some may come off as ignorant it's NOT what I'm into... to each his own...
Old 09-10-2009, 06:05 AM   #11
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Why does everyone think i was talking about dyno numbers???
Dyno numbers are trash, and if you have been in ppb for a while you would see that i have preached this year in and out.
Old 07-28-2009, 03:39 AM   #12
jason miller
Member#: 158313
2003 WRX
Plans to track it? Trap speed would be very interesting.
jason miller is offline   Reply With Quote
Old 07-28-2009, 03:48 AM   #13
GDB FAN
Member#: 105814
Impressive.
Im considering this over my vf34. I miss stage 2 spool.
GDB FAN is offline   Reply With Quote
Old 07-28-2009, 04:58 PM   #14
nolanator
Member#: 197677
62 Chevy Nova
800+ hp/tq on 91 octane
i've been messing around with 19t turbos for a couple years now and i love them...awesome thread
nolanator is offline   Reply With Quote
Old 07-28-2009, 03:48 AM   #15
Boarder325
Member#: 184949
2005 Outback XT Lmtd
Silver 5mt
Wow. That is so nice to see. I have putting off the turbo upgrade for a while and think I might pull the plug on this. That is actually a lttle more power than I want but great spool characteristics!. Thanks for posting this up.
Boarder325 is offline   Reply With Quote
Old 07-28-2009, 02:34 PM   #16
Dobbs
Member#: 28291
2015 WRX
that might be a first for NASIOC....
btw, what are you using for boost control? and what was the turn-around time from Blouch?
Dobbs is offline   Reply With Quote
Old 07-28-2009, 01:43 PM   #17
Thom
Member#: 152775
2004 Wrx
Java Black Pearl
Damn! that is awesome! so full boost by 2700 rpms?!! that would be awesome! and it pulls almost all the way to redline! This i like. This i like a lot. where exactly can i purchase the turbo from? forced performance? or blousch?
Thom is offline   Reply With Quote
Old 07-28-2009, 02:10 PM   #18
Phat04WRX
Member#: 59097
04 WRX
Java Black
thanks for that info. how does it feel on the street/freeway around 6k? does it pull nicely up in the higher rpms?
Phat04WRX is offline   Reply With Quote
Old 07-28-2009, 04:39 PM   #19
GDB FAN
Member#: 105814
You mean blouch? Check the first post (and title)....
Originally Posted by lackofhp View Post
I'd also like to know. And what it tapers to.
Old 07-28-2009, 09:39 PM   #20
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
Blouch has some great customer service and the turnaround time was very acceptable. I shipped it out Monday and got it back before the end of the week, Mike was really helpful and answered all my questions I have no complaints
also, I'm using a GM EBCS...
it feels great on the street and pulls really hard from 3200rpm all the way to redline, I don't notice it falling off too much past 6500rpm but I know it does. night and day compared to the stock TD04...
it tapers to about 17 to 18psi to redline...
I'm not really into drag to much , so I'm not sure if I'll have that info anytime soon... but who knows, I might take a trip out there one day with some of the local t3h Fast-Rarrrrrr Scoobys I do plan on doing some open track days and I always love auto-xing... FP here I come
Steve
Old 07-28-2009, 04:49 PM   #21
fastwrx25
Member#: 126441
03 bugeye
+1 for interesting turbo that noone ever posts info about.
fastwrx25 is offline   Reply With Quote
Old 07-28-2009, 05:57 PM   #22
SubyWill
Member#: 166830
2003 WRX
i'm REALLY interested in this, there's no way i can send my stock turbo in for this? or do i buy the one off the site?
SubyWill is offline   Reply With Quote
Old 07-28-2009, 09:50 PM   #23
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
I don't believe they stock these turbos... just send in your stock turbo or buy a cheep blown TD04 and send it in for a rebuild
Old 07-28-2009, 10:05 PM   #24
SubyWill
Member#: 166830
2003 WRX
hmm you said you shipped yours out and had it within a week?? that's not bad, i can just ship mine out
i was going vf43, but this is wayyyy better and more efficient! thanks for the info man!
Old 07-28-2009, 07:38 PM   #25
conrad87
Member#: 163884
2008 G37S
this is amazing. would really like to see some track times on this
conrad87 is offline   Reply With Quote
td04 19t blouch upgrade. WhiteBgeye02 Private 'Wanted' Classifieds 1 06-23-2010 08:35 PM
WTB td04 for 19t upgrade tanner127 Private 'Wanted' Classifieds 3 04-13-2010 08:04 PM
Blouch TD04 19T upgrade on 4EAT. Opinions Brock31 Transmission (AT/MT) & Driveline 6 12-17-2009 10:35 AM
Blouch TD04 19T Upgrade lackofhp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-31-2008 01:57 PM
TD04-19T questions. ringe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-07-2008 07:19 PM
