Welcome to the North American Subaru Impreza Owners Club Thursday April 28, 2016
Old 11-21-2008, 03:03 PM   #1
sburck
Member#: 191491
2011 Forester
Default When to switch to winter tires?
Well I know that the rubber on summer tires isn't especially cut out for cold temperatures. I'm wondering, it's not snowing yet and I still have summer tires on my car. Should I wait for snow to switch, or will the winter tires work better even without snow because the rubber is designed for the cold temperature?
BTW tires are blizzak lm-25's
sburck is offline   Reply With Quote
Old 11-21-2008, 04:54 PM   #2
krzyss
Member#: 8365
2013 Ford Focus SE
If temperature, when you drive, drops below 45F I would have switched.
Krzys
krzyss is offline   Reply With Quote
Old 11-21-2008, 06:34 PM   #3
drdabbles
Member#: 110229
2004 WRX STi
Java Black
I'm still on my summers. They aren't the stock rubber, though. I am also keeping a very VERY close eye on them.
I will probably get them swapped out on Monday, since the temps will be staying consistently below 45 or so. Now, if it would just SNOW already, I could handle this coldness a little better.
drdabbles is offline   Reply With Quote
Old 11-21-2008, 11:26 PM   #4
sburck
Member#: 191491
2011 Forester
will using summer tires in cold weather cause the rubber to wear fast because of its hardness?
Old 11-22-2008, 08:45 AM   #5
MattPersman
Member#: 139385
no, they are just like driving on bricks with less than optimal traction when it is cold.
they could wear faster if you are spinning them all the time for fun because of the cold
you got the winters, throw them on now
MattPersman is offline   Reply With Quote
When to switch to winter? SubaruImpreza_power Tire & Wheel 24 10-20-2009 01:11 PM
when to take off winter tires? kraigt New England Impreza Club Forum -- NESIC 49 03-21-2006 09:51 AM
OK to switch to winter tires on stock sti rims? StiRiDaZ Tire & Wheel 2 11-24-2005 05:36 PM
When are you going to switch to snow tires? Undepelo Mid Atlantic Impreza Club -- MAIC 14 11-30-2004 09:12 PM
When to switch to snow tires? Rich10 Brakes, Steering & Suspension 15 10-31-2002 07:28 AM
