Old 11-29-2008, 12:14 PM   #1
loki12487
Member#: 140781
2013 STI
CBS
Default coolant overheating issue need help asap
i'm having an issue with my car overheating while im on the highway the gauge will start moving towards the red area and then it will drop close to the normal range. i've changed the coolant and it hasn't fixed the problem. could i possibly have a problem with the thermostat?
loki12487 is offline   Reply With Quote
Old 11-29-2008, 12:15 PM   #2
anthonywrx
Member#: 60276
2012 Chevy Malibu LT
03 WRX/STi hybrid sold :(
burp the coolant lines
open radiator cap *WHEN COLD* and squeeze the upper radiator hose for about 30 seconds til it stops bubbling. then start the car and wait for the coolant to rise and slightly overflow. turn off car, and put cap back on
anthonywrx is offline   Reply With Quote
Old 11-29-2008, 12:21 PM   #3
loki12487
Member#: 140781
2013 STI
CBS
i will burp the lines once the car cools, i've also noticed that there is more coolant in the resevoir than i put in originally.
Old 11-29-2008, 01:03 PM   #4
loki12487
Member#: 140781
2013 STI
CBS
i tried burping the car and it's still having the same problem
Old 11-29-2008, 01:18 PM   #5
clkoontziii
Member#: 128389
2006 impreza wrx
steel gray
so if you drive around town the temp stays down right?
but 15min at 60mph or higher temp goes up? get a coolant kit that tests for carbon my 2001 rs had a similar issue
the res. bottle fills up too right
i never really tracked it down after replacing the head gasket and tstat twice and rad once
it got rid of it with what i thought was a small crack in the block passed comp. test though
clkoontziii is offline   Reply With Quote
Old 11-29-2008, 01:21 PM   #6
loki12487
Member#: 140781
2013 STI
CBS
yea that's what its doing, it's starting to heat up at idle now
Old 11-29-2008, 04:16 PM   #7
clkoontziii
Member#: 128389
2006 impreza wrx
steel gray
get it to heat up alittle and then quickly do a comp. test i bet there is a leak
also test the coolant
that sux man good luck
Old 11-29-2008, 05:02 PM   #8
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
likely a thermostate or the more expensive fix... internal headgasket leak.
If you smell your coolant, does it smell like exhaust fumes?
Mavrik is offline   Reply With Quote
Old 11-29-2008, 05:28 PM   #9
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Hopefully the problem is just a sticky thermostat. If the testing for exhaust gases in the coolant shows negative I recommend you have the thermostat replaced to see if that fixes it. Get this problem straightened out as soon as you can. This isn't a good thing.
Cougar4 is offline   Reply With Quote
Old 11-29-2008, 10:29 PM   #10
anthonywrx
Member#: 60276
post your mods
coolant issues. need help! ImprezivEJ20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-22-2008 04:38 PM
WTB wrx coolant reservoir tank. Need it asap! ki11switch NWIC Private Classifieds 5 09-24-2008 01:53 PM
serious, serious issues... need help ASAP with turbo placement silentt Normally Aspirated with bolt-on Forced Induction Powertrain 25 09-03-2007 06:53 PM
strange issue..freaking me out need help asap. willguidry Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 09-14-2006 11:47 AM
UTEC tuning issues need help asap Sharky NRK Engine Management & Tuning 6 11-11-2005 05:23 PM
