Old 12-02-2008, 11:01 PM   #1
cabe
Member#: 55864
2002 WRX sedan
Default Oil Pan Question
I have a 2003 wrx (2.0 obviously). However, I have an oil pan off of a 2.5 liter to accomodate my headers. At any rate, I am wondering if I should put the same amount of oil in the 2.5 oil pan that I had previously put in the 2.0. Thanks!
cabe is offline   Reply With Quote
Old 12-03-2008, 12:52 AM   #2
Horkus
Member#: 112667
2002 WRX wagon
What I would do is find out the amount of oil it takes on a 2.5L and the 2.0L and take the average of the 2.
Horkus is offline   Reply With Quote
Old 12-03-2008, 01:37 AM   #3
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP
What year & model is the 2.5 pan from?
Most likely it holds the same amount as your 2.0 did.
You can also go by the dipstick....
RonJitsu is offline   Reply With Quote
Old 12-03-2008, 02:06 AM   #4
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
11 Taurus SHO daily
That's assuming that he changed the dipstick to the one that corresponds to the pan. If it is an STi pan you need an STi dipstick, pickup, and windage tray to correctly install it on the WRX 2.0.
FourOnTheFloor65 is offline   Reply With Quote
Old 12-03-2008, 08:23 AM   #5
cabe
Member#: 55864
2002 WRX sedan
The only thing I changed was the oil pan. The dipstick and pickup are the same. I guess I will just find out the amount of oil it takes to fill the 2.5 oil pan. And I thought all the 2.5 wrx oil pans from 06-07 were the same...
Old 12-03-2008, 10:32 AM   #6
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
11 Taurus SHO daily
So you are using an 06-07 WRX pan on an 03 WRX to clear a different header?
I looked up the parts on www.subarugenuineparts.com for 2003 Impreza WRX.
pan 02-05 $66.93
pickup 96-05 $23.27
baffle 95-05 $16.45
Then for the 06 WRX
pan 04-07 $79.27
pickup 06-07 $19.08
baffle 06-07 $7.83
From this it looks like the baffle and pickup are different too. I couldn't find the dipstick on there, and the oil pan doesn't seem to be listed correctly for the 06. I think they are listing the STi pan.
I would do a little more research before you start the car with the new pan. I'd go to the dealer and check the parts for sure including the dipstick.
Old 12-03-2008, 09:25 AM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
the 2.0L oil pan superceeds to the new style oil pan. I know because im about to change mine. There are no parts bulletiens stating any other parts are needed to upgrade, though im changing the pick up tube as well.
munkis is offline   Reply With Quote
oil pan question bluice Subaru Conversions 2 11-15-2005 04:38 PM
Oil Pan Questions ExecNav Normally Aspirated with bolt-on Forced Induction Powertrain 6 08-14-2004 03:08 AM
Oil pan question I drive a WRX wagon Factory 2.0L Turbo Powertrain 4 03-18-2004 01:45 PM
Help! Oil pan question scrmnsmn Factory 2.0L Turbo Powertrain 4 09-30-2002 11:04 PM
oil pan question imprezaboi Normally Aspirated Powertrain 1 02-12-2002 02:29 AM
Message Board Statistics All times are GMT -4. The time now is 03:58 AM.
