Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 05-13-2001, 08:17 PM   #1
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Talking OT: The Mustang goes under the knife (pics)
Well, there are a few pictures of the Mustang's extensive surgery here: http://albums.photopoint.com/j/Album...221&a=12911164 . First comes the rollbar and new subframe connectors, then comes the torque arm and panhard bar rear suspension setup.
For the uninitiated, the '93+ Camaros/Firebirds have a torque arm and panhard bar from the factory, which is probably the biggest reason they handle better than any Mustang (other than the '99+ Cobra with its IRS) when it comes to auto-x and OT. The torque arm gives the car a huge improvement in traction, while the panhard bar laterally locates the axle and makes things operate a bit more smoothly. You can look here http://www.alanchavis.com/mmtapb/mmtapb.htm to see 4 pages worth of photos of a TA/PB setup being installed.
I can't wait to get the car back - it should be a completely different beast. Of course, the "to do" list on the damn thing is out of control right now - Lord only knows when the thing will truly be done.
Pat Olsen
'97 Legacy 2.5GT sedan
'89 Mustang GT convertible, blown and intercooled
Old 05-14-2001, 02:50 AM   #2
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Post
Wow, I did not know your putting a 6-point in the car. Can you say stiff, no body flex, I thought you could..
I can't wait for a fun run in this car!
Paul G.
paultg is offline   Reply With Quote
Old 05-14-2001, 07:12 AM   #3
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Post
Pat,
I showed your post to a friend w/ a mustang and he wanted me to ask you a few questions,
I have some questions about your setup. I have Flowmaster 2.5" exhaust and a stock H pipe and a FMS aluminum drivesaft. I am concerned with clearances. What affect do you expect on ground clearence? I also have an 87 lx convertable and I have Kenny brown square welded in subs. I have a mig welder and access to a lift - do see any gotchas in me doing this myself? What was the total cost of all this?
Lou
m750 is offline   Reply With Quote
Old 05-14-2001, 08:33 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Post
Aaron - Tell your friend Lou to check out http://www.maximummotorsports.com/onlinecat.html for info on pricing. I went with a torque arm package, which included the heavy-duty torque arm, panhard bar, and height adjustable rear lower control arms for around $1270. The normal torque arm is $200 cheaper, but can only take 425lb-ft (at the flywheel), and I'm probably over that. Anyway, add in some H&R rear springs for another $139.
As for exhaust clearance, I think the Flowmaster pipes will be a problem around the panhard bar bracket. The bracket is designed to clear the stock exhaust routing, which Dynomax follows pretty closely, but apparently Flowmaster is a bit different. I had Flowmaster 3-chambers with Dynomax tailpipes on the car for years, so you could always do that. The Dynomax tailpipes are pretty inexpensive, much cheaper than the Flowmaster ones.
As for the subframe connectors, MM says the KB ones aren't strong enough to take the loads imparted by the torque arm. They recently began selling some add-on pieces that weld to the KB SFCs to make them taller (hence stronger in bending), or you can chop out the KB ones and get full-length MM SFCs. That's what I did, and I kinda wish I hadn't - if the KB SFCs are welded in there well, it's a huge PITA to get them out.
Last but not least, can you do it yourself? I dunno. Give the guys at MM a call - they're extremely friendly and helpful, and will tell you everything you need to know.
Feel free to email me with more questions (thepno95@earthlink.net) so we don't bore the Subaru crowd with too much Mustang babble.
Pat
Old 05-14-2001, 10:33 AM   #5
Ru fan
Member#: 1605
1997 1.8L Brighton
NESIC TrackH0z member#1
Post
Cool beans yo! Hey pat, I saw your car at LRP this past Saturday, and I saw the red Stang #6.
Later,
Seth E.
Ru fan is offline   Reply With Quote
Old 05-14-2001, 03:34 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Post
Cool, Seth - it's good to be recognized! Joe in the #6 car took first in ITE, qualifying about 2.5sec quicker than the 2nd place car, and finishing the race about 20sec ahead of 2nd place. I had never been to an SCCA Road Racing event - that's quite a production! I had no idea it would be so big.
Pat
Old 05-14-2001, 10:06 PM   #7
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Post
Stupid question :
Can't you just purchase a Cobra IRS subframe ? (I am not sure if your torque tube would work with this setup or not).
I think the IRS subframe is basically a bolt-on piece holding the new Rear Diff. I would think that the torque tube setup is more for drag racers than for people searching for the ultimate in handling ?
Jonathan is offline   Reply With Quote
Old 05-15-2001, 08:53 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Post
Jonathan - Theoretically, yes, you could put the Cobra IRS into a Fox-body Mustang. As much as the outside of the car has changed in the past 8 years or so, the underpinnings of the Mustang (even the brand new ones) are still based on the '79 Fairmont. Sweet, eh?
Anyway, the problem with trying to do that conversion is that it's not a straight swap, and a very limited number of people have done it. Any sort of conversion stuff would have to be custom fabricated. The Max Motorsports TA and PB is a straight bolt/weld-on affair. There are other problems, too, like I think the rear track is quite a bit wider - 3" maybe? - so the fenders would have to be flared out. That wider rear track would also make the car's tendency to understeer even worse (of course, the added grip of the torque arm will do the same thing to some extent, but it will be easier to tune around that). And, of course, the cost of a complete Cobra IRS is very high at this point, because there just aren't a whole lot of them around to scavenge from.
It would definitely be sweet, but you'd have to have some serious $$$ to get it all set up right.
Pat
Old 05-16-2001, 02:33 PM   #9
Subedave
Member#: 1872
03 SVT Cobra
508rwhp 490rwtq
Question
Hey Pat,
Do you know anything about the griggs racing suspensions?
Dave
Subedave is offline   Reply With Quote
Batmobile goes under the knife... Project Hybrid Build begins!!! brcewane Member's Car Gallery 804 06-17-2013 09:18 PM
Pics Of the Bugeye before it goes under the knife. smileyou Member's Car Gallery 21 12-05-2008 05:44 PM
The King Goes to the Drive Thru (Halloweenur Pics) Scubiedoo Off-Topic 35 10-31-2005 05:21 PM
Mastro Monster goes under the knife... Opie South East Region Forum 48 01-24-2005 08:43 PM
Message Board Statistics All times are GMT -4. The time now is 07:43 AM.
