#1 |
Vendor Sales Rating: (11)
Member#: 81166
Vehicle:2008 Forester silver |
For the last few years we have been using DMS and MSI suspension parts for a lot of builds here at the shop and we thought It was time to offer them to you. All DMS and MSI camber plates and lateral links come with a lifetime warranty on all parts except the spherical bearings. If you have questions about any parts from these two company's please let me know.
![]() Proven in rally, road race and autocross cars, these camber plates use the highest quality bearings that do not fail under extreme conditions. These DMS plates are constructed from 6061 aluminum and include heavy duty 4 piece locking front top mounts which have camber and caster adjustment. These plates are designed for most coilover suspension systems. DMS Front camber/caster plates for 2002-2007 WRX/STI $556.00 ![]() Proven in rally, road race and autocross cars, these camber plates use the highest quality bearings that do not fail under extreme conditions. These DMS plates are constructed from 6061 aluminum and include heavy duty 2 piece locking rear top mounts which have camber adjustment. These plates are designed for most coilover suspension systems. DMS Rear adjustable camber plates for 2002-2007 WRX/STI $489.00 ![]() The link kits are CNC machined from billet 6061 aluminum and use a grade B7 steel for the turnbuckle. MSI has been able to produce an adjustable unit that does not add any additional weight over the OEM parts with the bushings. The bushings can be directly replaced with MSI Teflon lined bearings for motorsport use as an additional upgrade. MSI Rear adjustable lateral links for any 2002-2007 WRX/STI $749.00
__________________
Ryan Fine Line Imports To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Become a fan of FLI on facebook at To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Fine Line Imports; 10-19-2009 at 12:12 PM. |
| Thread Tools | |
| Display Modes | |
| DMS and MSI suspension parts for your Subaru | Fine Line Imports | Suspension/Brakes/Handling | 3 | 11-11-2009 12:42 PM |
| New and Used suspension parts for your WRX/STI | Fine Line Imports | Suspension/Brakes/Handling | 2 | 03-01-2009 11:50 PM |
| MSI, DMS, COBB and KW suspension for your WRX/STI | Fine Line Imports | Suspension/Brakes/Handling | 3 | 09-02-2008 01:05 PM |
| FS (VA): DMS Camber Plates and Ground Control Coilover kit | gtsxr | Suspension/Brakes/Handling | 6 | 02-06-2008 06:23 PM |
| FS: DMS Camber Plates and GC Coilover Kit | gtsxr | MAIC Private Classifieds | 13 | 02-06-2008 06:22 PM |
