Notices
Old 03-22-2009, 12:04 PM   #1
VOLTIS5
Member#: 2353
98' LegOver GT
dark whiteish pearly red
Default HELP!!!!! P0325 Knock sensor on my Legacy 2.5
Hi all.
My car has been running like CRAP for the past week ever since i got the CEL for a knock sensor P0325. I've tried using a higher octane (91) gas to see if that was the problem but the car still bogs when i go WOT from a complete stop or on cruise. Any advice on what else i need to do/look at before actually replacing the KS? And how much work is involved in replacing it.
Any suggestions greatly appreciated
VOLTIS5 is offline   Reply With Quote
Old 03-22-2009, 05:23 PM   #2
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
PO325 means the sensor is toast. I tried the same thing with the Forester, clearing the code only to return. Replaced the sensor, problem solved.
It is located near/under the throttle body on top of the motor. If you search you should be able to find a pic. Easy install, just don't tighten the bolt too much on the new one, the specs are light (around 10-11 lbs. I think) and you will smash the sensitive plate... You will also need a socket extension to reach it.
surowrxa is offline   Reply With Quote
Old 03-23-2009, 02:37 PM   #3
VOLTIS5
Member#: 2353
98' LegOver GT
thank you good sir. i will give that a try. off to the stealership i go.........
Old 03-24-2009, 02:20 AM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Ya, if you find the throttle cable on the driver side and look down from there you'll see it. It's a 12mm bolt. The torque spec is 17.4+/=2.2 ft. lbs and they want it mounted 45 degrees from the center line of the engine. The +/=2.2 is a safe overtorque amount. Basically it means 17.4-19.6 would be fine. Make sure the mounting surface is clean.
Tim Sanderson is offline   Reply With Quote
Need help!! Car wont start!! 1997 subaru legacy 2.5 GT BallzToTheWallz Normally Aspirated Powertrain 1 02-16-2010 11:20 AM
need help on my MY00 2.5 RS turbo conv. many questons zakats Subaru Conversions 12 08-15-2003 02:28 PM
what can i do to my legacy 2.5 gt sedan canesx1 Legacy Forum 15 07-07-2001 02:17 PM
what can i do to my legacy 2.5 gt canesx1 Newbies & FAQs 6 07-04-2001 04:16 PM
is there a way to bypass the maf sensor on a 99 2.5 rs sc00by25rs Technical Forum Archive 11 07-06-2000 10:32 AM
