Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 05-01-2009, 02:07 PM   #1
MR2fanatic
Member#: 48179
03 WRX
Default ..:: misfire cyl 2 - COIL sparking arcing VIDEO ::.. please help diagnose
MY car is a 1998 2.5 RS with 110k miles on it.
So my car has been intermittently misfiring on cylinder 2. I verified the code with my OBD2 scanner. I've also been researching about the possible reasons that this could be happening:
- bad injector
- valve adjustment
- bad plug and/or wire
- bad coil
- bad front o2 sensor
I've been waiting for it to misfire again so I can verify that the plug is even firing. Well today it started acting up again....it always happens when it rains... and popped the hood and noticed that the coil is arcing or sparking on the plug wire. The link below shows the video of what is going on. Does this seem to be a coil, spark plug, spark plug wire, or all of the above? Any and all help will be greatly appreciated.
MR2fanatic is offline   Reply With Quote
Old 05-01-2009, 03:30 PM   #2
wirolla
Member#: 109725
2001 GM6
SRP
if i were you i would put on oem wires, oem plugs, and an oem coil. Otherwise just replace the coil. If you look closely enough u can probably see that it has a crack.
wirolla is offline   Reply With Quote
Old 05-01-2009, 04:16 PM   #3
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
I had the same thing on my contour....the coil is cracked, or that wire clip is broken. Replace the coil and wires and ull be fine.
rivman05 is offline   Reply With Quote
Old 05-01-2009, 09:15 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
yup, looks like your coil is borked.
yarrgh is offline   Reply With Quote
Old 05-01-2009, 09:16 PM   #5
GrundleJuice
Member#: 165749
the spark is weak, too. so defanately replace the coil instead of trying to repair it. The aircraft i work on with piston engines do this sometimes, always due to a crack in the magneto distributor block, so look closely for cracks or deep burns in the coil housing if you are curious. either way, the coil needs to be replaced.
good idea to check/replace the plugs since a weak/intermittent spark can cause fouling which can lead to uncleanable buildup or damage to the electrodes.
after replacing you should see a noticeable increase in power and gas mileage, too
Old 05-01-2009, 10:10 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The coil pack is bad.
The cause of this failure is most likely that you (or the previous owner) did not replace the spark plugs and wires at the appropriate time which forced the spark to find an easier path to ground.
ciper is offline   Reply With Quote
Old 05-02-2009, 12:18 PM   #7
wirolla
Member#: 109725
2001 GM6
SRP
just replace the coil, plugs, and wires with oem parts.
/thread.
Old 05-02-2009, 07:35 PM   #8
MR2fanatic
Member#: 48179
03 WRX
Ordered up a set of oem wires and coil. Thanks for the advice
Misfire Cyl 2 SLVRBUGEYE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-04-2010 06:08 PM
help with my gf's 2007 MAZDA 3, please help diagnose!! thinkofone28 Off-Topic 55 04-29-2009 06:59 PM
coil pack.. arcing from #3.. please help Spy Electrical & Lighting 3 09-18-2006 04:16 PM
01 OBW lean misfire cyl 2 mechanic can't locate cause! GYates Outback Forum 3 08-23-2006 01:57 PM
1/2 million volt arc video Detroit wagon Off-Topic 2 01-15-2004 10:00 PM
