Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 06-10-2009, 07:23 PM   #1
Niku-Sama
Member#: 212426
1990 Loyale AWD Turb
Default need to fix a DIY r134a A/C conversion
ok so this is on a loyale turbo AWD heres what i think is going on.
the hood has a sticker saying it was converted in late 2006 to 134a, compressor still comes on, no leaks and has dye in the system, system is holding pressure but still blows warm.
i'm not exactly sure how much 134 is in it, its not much because i watch the little window on the dryer when the a/c is on and the refrigerant only goes by every once in a while in a white foamy lookin manner. what i think they did is they get one of those fill nipple/o-ring conversion kits, blew all the old stuff into the atmosphere and stuck the conversion kit on and filled it up.
how should i go about fixing this?
should i find some one to suck out whats in there and then further suck out the air my self some how and fill it with a can or should i have them suck the old stuff out and suck the air out and then fill with a can?
i am trying to go cheap here, i think refilling at an a/c shop is gonna cost alot more but i also dont know how much just sucking it down is gonna be either.
the only thing i wont do is open the system and let it vent out, thats just stupid
Niku-Sama is offline   Reply With Quote
Old 06-10-2009, 08:23 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
How badly do you want AC? Given what's already been done to it, it may need more than just a refill so I'd highly suggest having a shop look at it. It may cost you more up front but, as long as you go to a place that really knows AC, they are much more likely to get it working than you are messing around on your own.
Old 06-11-2009, 01:04 AM   #3
Niku-Sama
Member#: 212426
pretty bad, i'm going to be in el paso tx next summer (hopefully) and talk about hot.
everything is functional but i kinda get the feeling if i have some one suck it down its going to be cheaper for me to fill, unless i can find some place thats having some sort of special
Old 06-12-2009, 03:00 PM   #4
DrSaabaru
Member#: 183225
2005 Saab 9-2x Aero
It's not that expensive to have a shop evacuate and recharge the system... $120 maybe? I'd consider it money well spent if I was going to be in El Paso in the summer
DrSaabaru is offline   Reply With Quote
Old 06-12-2009, 08:50 PM   #5
my4isflat
Member#: 120002
2000 2.5 RS, '95
Legacy w/325k mi (RIP)
$120 to evac and recharge is dirt cheap. I used to love a/c service, I'd make 2.6 hrs just to hook up a machine and let it do all the work, good times.
You're going to have to hook up a set of manifold gauges to see what is going on with your a/c system, or take it to a shop. A good rule of thumb is whatever the pressure is on the low side is what the temp the a/c system should be blowing (36 psi on the low side roughly equates to 36 degrees out the vents, etc.). If you know for a fact your system is full then it is mostlikely the compressor or the expansion valve.
my4isflat is offline   Reply With Quote
Input needed to make this DIY look better STi__G Interior & Exterior Modification 22 03-03-2010 12:54 AM
Anybody need a Realtor? I need to fix my FXT roloc31 Rocky Mountains Impreza Club Forum -- RMIC 19 12-06-2009 03:29 AM
I need to fix my brakes! Anyone want to make some money? robsta1 Southern California Impreza Club Forum -- SCIC 7 04-11-2008 06:33 PM
HELP!!!Need to recover fre-on r134a on my suby!!! gene4ace Southern California Impreza Club Forum -- SCIC 10 03-27-2008 06:01 AM
need to fix my rear drum today...so I need info. help or be shot Keith Off-Topic 23 06-27-2004 03:20 PM
