Old 04-27-2002, 03:10 PM   #1
JAnderson
Member#: 325
2004 STi
Exclamation Engine Oil Leak ?
Could some one please shead some light as to why I maybe seeing oil along the rim of my spark plugs. When I changed my plugs this weekend noticed oil aroung the spark plug cover and engine. If your looking at the engine I found oil only on the front left and right plugs.
When I removed the spark plugs they both were snug when removing. I also looked at the tip of the spark plug and it was white ( See more pictures here link). The car seems to be running fine. Idles ok when warming up.
Any thoughts are appreciated?
MORE PICTURES HERE
Jim
JAnderson is offline   Reply With Quote
Old 04-28-2002, 10:19 AM   #2
bender
Member#: 1839
there is a gasket around each one of the spark plug holes, and it looks like that one is starting to leak. I believe it's part of a valve cover gasket set to can get from the dealer.
btw, if you think that is bad, you should see some of the v6 ford probes that come into our shop
bender is offline   Reply With Quote
Old 04-28-2002, 07:40 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
those are seperate from the valve cover gasket but if you have a warranty it's covered, just take it in.
jeremy
HndaTch627 is offline   Reply With Quote
Engine Oil Leak Poo Vancouver Impreza Club Forum -- VIC 14 03-03-2005 02:02 AM
Engine Oil Leak b.rowe Mid West Subaru Owners Club Forum -- MWSOC 4 12-01-2004 06:46 AM
1.8L FWD engine oil leak yimmer Normally Aspirated Powertrain 15 07-17-2004 04:08 AM
Engine oil leaking GTKim Service & Maintenance 8 09-15-2002 06:03 PM
Engine oil leaking into transmission bmacauto Normally Aspirated Powertrain 5 02-23-2002 04:00 PM
