Old 06-29-2009, 09:20 PM   #1
wrxrallyblue68
Member#: 179467
2015 STI Launch Ed.
Default 2008 Wrx Tpms Sensor
i recently got some new rims for my 08 wrx. they told me at pepboys that they couldn't switch out the tpms sensor from my stock rims or they would break getting them out. so i just had them mounted with normal valve stems, is their anyway to pull a fuse or pull a wire to get rid of this annoying light, and will it pass inspection if this stupid light stays on all the time.?
wrxrallyblue68 is offline   Reply With Quote
Old 06-29-2009, 10:13 PM   #2
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
no there is no fuse. im living with the light with my rotas. in ny its not part of the safety inspection, maybe someone local by you can answer about virginia.
Old 06-29-2009, 11:15 PM   #3
Natas78
Member#: 179549
2005 M.Z.M. WAGON
2.5 hybrid
Why didn't they unscrew the sensor from the valvestem and swap it over to the new rim?
Natas78 is offline   Reply With Quote
Old 06-30-2009, 07:09 AM   #4
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
i read the parts break off when unscrewed.i dont know. i just said f*** it and there sitting in the stockers under my deck.
Old 07-08-2009, 04:36 AM   #5
2tal
Member#: 215196
2009 WRX
I worked at Discount Tire for quite a while and I can probably assume exactly what is going on. The subaru tpms sensors are the Chevy style which is a rubber valve with a threaded hole for the sensor to be screw on. Pep boys likely didn't have the replacement valves which is why they didn't want to switch them over. In all my experience with this style of sensor, they have broken the least. We ran into countless problems with the all metal sensors, but the flexibility allowed by the rubber valve actually helps for a stress free change over. If I were you I would run over to Discount Tire or America's Tire, depending on your location, and have them put the sensors back in so that you can retain the tmps. They will most likely charge you for the mounting and dismounting of the tire, and the cost of the new valves, which sucks because this could have all been done at the time of the original install.
Sorry if that was way to indepth.
2tal is offline   Reply With Quote
Old 07-08-2009, 11:49 PM   #6
Mr.WRX2002
Member#: 7978
13 Mustang Gt
15 f-150 Plat Screw Eco
Thanks for the info, I have been wondering about this as well.
Mr.WRX2002 is offline   Reply With Quote
Old 07-09-2009, 01:51 PM   #7
mls1
Member#: 167607
2008 WRX
Discount put mine in no prob.
mls1 is offline   Reply With Quote
Is my 09 WRX equipped with TPMS sensors? REX265 Tire & Wheel 24 11-12-2009 11:26 PM
2008 wrx o2 sensor power supply d_hump Engine Management & Tuning 4 09-26-2009 02:04 AM
2008 WRX Wagon - TPMS Receiver Location fober Tire & Wheel 0 09-21-2009 04:55 PM
Enkei NT03+M TPMS for 2008 WRX 08SubieWRX Tire & Wheel 2 07-02-2009 08:28 AM
08 WRX Wheel+TPMS sensor weight via simple math hikeeba Tire & Wheel 6 12-25-2007 01:03 AM
