Old 06-30-2009, 06:07 AM   #1
simonasaur
Member#: 128997
99 rsti 207
white
Default what is that... a forester? """GF8 swap"""
some guy at the shop said that today... i thought it was funny, it is forester green i guess.
im just about to dive into the motor/wiring swap tomorrow. my friends and i already did the transmission. heres the leftover parts... anybody want a full 1.8 drivetrain & motor lemme know.
and some of the new parts... ill try to work on my photo skills
i shoulda documented better, i got too excited and forgot about the camera
im swapping bugeye guts and a turbo leg block (yeah closed deck!) ill try to update this as parts go on... and come off... and go back on again.
simonasaur is offline   Reply With Quote
Old 06-30-2009, 10:02 PM   #2
04trailsti
Member#: 179170
so you are dropping a fxt drivetrain into a GF8???
I have a few posts on here asking about that swap, I have been pondering doing it and throwing ppg's in the 4.44 tranny. keep us updated
04trailsti is offline   Reply With Quote
Old 06-30-2009, 11:31 PM   #3
Crawdads
Member#: 30907
SWP GDB-G
Check his post again...He is swapping in Bugeye WRX bits and using a Legacy 2.2T closed deck block.
4.44 Cars are a lot of fun...my buddy has a v.6 STi 4.44 in his swapped RS.
Crawdads is offline   Reply With Quote
Old 07-05-2009, 08:14 PM   #4
simonasaur
Member#: 128997
99 rsti 207
white
well i got my nifty jdm rear hatch installed along with rear 06 2pots. im curently removing the dash in favor of either a wrx dash (which i have but requires a good amount of modification), or a 2.5 rs dash, if someone wants to trade.
my car has a mullet
cool jdm parking pass
custom coca cola holder
Old 07-08-2009, 04:53 PM   #5
haji
Member#: 54624
1999 impreza wgn
Yo dood!
It's Erik...
You gonna use that clutch?
Will it work?
haji is offline   Reply With Quote
Old 07-18-2009, 03:06 PM   #6
simonasaur
Member#: 128997
99 rsti 207
white
Originally Posted by haji View Post
Yo dood!
It's Erik...
Will it work?
i wish i could for sure, the model numbers from a 2.5 rs so its a lil too small... its just chillin @ the shop now. ima b back tmrw morning and gonna b painting the engine bay when i return. hit me up, you should stop by!
Old 08-07-2009, 06:49 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
Check the piston for nicks and lube it up so you don't tear the seal. Be glad it didn't shoot out onto your finger. Hopefully you remember to never spray air into the calipers ever again!!!
Looks good!
Jay
Old 08-10-2009, 10:51 PM   #8
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
still have that 1.8 drivetrain? i'll take it off your hands... if you need any help with the swap let me know, i'm in portland too
elislider is offline   Reply With Quote
Old 08-17-2009, 01:19 AM   #9
simonasaur
Member#: 128997
99 rsti 207
white
already sold the 1.8. were gonna be finishing up all this week if ya wanna come help out youre welcome to.
Old 08-29-2009, 05:11 AM   #10
simonasaur
Member#: 128997
99 rsti 207
white
well its been a while since my last update on my project and alot changed. the progress of things was really coming along pretty well and the goal of driving to WCSS was looking great. unfortunatly there was a pretty signifigant snag in the way which ill get to later that froze the progress.
on a good note i did get somestuff rolling
andrew and i got the harness a lil wired up, just running the wires throughout the car where theyll live. were doing a full harness swap, dash included. knowing what i know now i realize why a full harness swap is NOT easier than a merge. although if your updating the dash and dont mind or have reason to pull the whole car apart then its not that big a deal
also the new crossmember is installed
the heater core didnt want to fit all snug where it should, actually it didnt want to fit at all. we cut a oval in the firewall to acomidate the antifreeze that flows into the core. if you were installing ac you would also put another oval on the other side of the firewall but i skipped that.
theres no way to paint to it but its the hole just right of the clutch arm that was cut. i found it was just barely too tight of a fit so removing the sound deadening did the trick.
Old 08-29-2009, 05:25 AM   #11
simonasaur
Member#: 128997
99 rsti 207
white
the next challenge was to make the dash fit. even though to the naked eye, both the 93 and 02 dash bar look like they use the same mounting points. they dont. they are close though, and through a happy accident it worked pretty good. in the 1st picture, what look like the closest holes to the camera are actally 2 cut off studs. these were removed and saved in order to re weld them. if you remove all 4 studs from both sides then the bar will mount with 2 out of four holes on either side.
then youll also need to remove the pointy peices of plastic from the back of the dash in order to snug the dash against the windshield.
these next 2 photos show how the dash beam bolts to either side. if i were to do this again i would make a diagram of the holes/ studs on the unibody. then id like up the rear 2 holes on the dash beam with the dagram and just drill 2 new holes so i could use all 4 stock mounting points from the body.
we left the dash out since theres alot of wiring to b done still
Old 08-29-2009, 06:17 AM   #12
simonasaur
Member#: 128997
99 rsti 207
white
i also got most everything back from the machine shops. instead of a 2.2 which is my favorite motor im going with a 2.5 sti block. that might change in the future but i had a 2.5 availible so i rolled with that. it had a bad rod bearing... big surprise! sooooo i had the crank polished and got new bearings from bearing services in portland oregon. these guys are super legit and do really quality work.
the block was honed and resurfaced
then i got the heads back from cylinder head specialties. they had 7-8 hours of port and polishing done prior to being dropped off.
THIS IS WHERE THE NIGHTMARE BEGAN. we recieved the heads and they LOOKED really nice at first glance. now i havent done too much more than bolt on mods so this kind of thing is new to me. they were supost to do a resurfacing, and a valve job...
they had a weird king of sparkly look to them which my engine asembler imediatly noticed... it looked just like theyd been glassbead blasted.
he said we'd wait to put the heads on till we knew what it was. so the next day he called GREG @ CYLINDER HEAD SPECIALTIES
he said it was a special paint...
WHAT? like i said, i dont build engines but i do know that you shouldnt have paint where your oil is. so he askes "what type of paint?"
"a special paint formulated for drive trains"
"who makes that"
"xxx company"
so my buddy is suspecious like he should be with his level of experience and calls "xxx" paint company.
they tell him the make no such product.
another colige of his calls, and the owner of cylinder head specialties gives the same lie.
so now im brought into the situation and call the guy from the shop. greg says, "youre the 3rd guy to call why dont you bring them in and well remove the paint." so ibring them in and drop them off...
an hour later i go to pick them up, theyre brought out by the shop foreman. i say thanks, and ask what was up with the paint.
"well they were media blasted"
"what? i thought it was paint"
"no we dont paint out heads"
so now im feeling incomfortable with this whole deal because i dont like being lied to
i take a closer look and see theyve done an unconsistant job on the cam journals and thyve only done some of the valve journals. im livid, it looks like **** and my engine guy says no way, its not even as good as stock.
i go back again tell this guy hes really bumming me out and i very disapointed in the quality of work, he says hell fix it.
he does a crappy looking job again and tells me thats as good as it gets.
unfortunatly the blasting was everywhere, including the cam journals. thats not good because when you blast you remove material and since theres very tight tolerences this is worring me
we decide to bolt the heads up and check clearences... they dont look good... i call the owner greg
"hey dude, these heads might b ruined due to all the material removed"
"no theyre fine"
"what? we just measured them and theyre out of subaru tolerances"
"well theyre remanufacured that happens"
"no, it doesnt, theres been material removed by your actions..."
"no we didnt remove any material"
"you media blasted the whole valve train..."
"im through talking about this....click"
so i take the heads to bearing services who looks at them, discused tolerences and is going to double check everything and see what can b done.
i call greg again and tell him i have a 3rd party involved thats measuring/ documenting the situation. i let him know,
"if they are repairable im going to chalk it up to a bad call and well never do business again. but if you have ruined these beyond repair youll be hearing from me."
he interupts and says
"you have to give him a chance to reapair them"
"greg, i already gave you 2 chances. im not letting you touch anything. im just calling to tell you this information"
sometime in the middle of my last sentence he hung up the phone.
not only does CYLINDER HEAD SPECIALTIES PORTLAND OREGON do really bad work. but they also lie to customers. the owner is incredibly hard to work with. and they do not adhere to what i have learned are professional standards of machining.
Old 08-29-2009, 10:24 AM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i guess i know where not to send my heads did you make a post about this in the NW forum
Old 08-29-2009, 06:05 PM   #14
simonasaur
Member#: 128997
99 rsti 207
white
not yet but its on the agenda. the guys a real piece of work so i do think people should know about it
Old 08-29-2009, 09:03 PM   #15
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Wow hell of a project, this is all the stuff I like, making it work ect... Hats off to you lets see some more...
Old 08-31-2009, 08:00 PM   #16
simonasaur
Member#: 128997
99 rsti 207
white
Great news the heads are not ruined! I took them to a real shop that has experience with subarus. They should b back by wed & ready to assemble!
Old 09-09-2009, 12:49 AM   #17
simonasaur
Member#: 128997
99 rsti 207
white
motors in the car! just need to install steering rack and have a homie finish wiring.
Old 09-09-2009, 01:45 AM   #18
GT11
Member#: 128002
0000 four door sedan
Poop color
****ing awesome. Looks like it's a hell of a job
GT11 is offline   Reply With Quote
Old 10-21-2009, 01:23 PM   #19
bobdhead39
Member#: 74836
update?
bobdhead39 is offline   Reply With Quote
Old 10-21-2009, 01:50 PM   #20
downpipe12
Member#: 212666
2002 WRX Wagon,
Black, EVOIII16G+Meth
LOVE the color you did the engine bay with.
downpipe12 is offline   Reply With Quote
Old 10-22-2009, 04:44 AM   #21
simonasaur
Member#: 128997
99 rsti 207
white
Just got back into town. Needs to b wired and it'll b good to go
Old 10-22-2009, 01:38 PM   #22
nine7oh
Member#: 208840
2004 FXT, White
18ged
my mom has that same car. its allways been my plan to swap it someday!
nine7oh is offline   Reply With Quote
Old 10-24-2009, 04:08 PM   #23
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Mmmmm.... wagon! Now it's making me have to think of painting the engine bay in mine a different color and if I do, when?
Seraphinwolf is offline   Reply With Quote
Old 10-24-2009, 05:05 PM   #24
simonasaur
Member#: 128997
99 rsti 207
white
Thansk
for all the cool comments guys. I gotta say this has been and still is a crazy stressfill project. I'll prolly have some updated pics by tmrw!
Old 10-25-2009, 11:21 PM   #25
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Originally Posted by simonasaur View Post
Thansk
Stress is one thing. Progress is another, of which you have there. Most of us get stuck ot held up on things. My car hasn't moved from her cave for some time now and it makes me sad.
What is that thing on the 2009 Forester hood? EJ25RUN General Community 52 11-26-2011 07:38 PM
What is that thing called that the water company has JjSwee Off-Topic 5 03-09-2005 05:44 PM
Quick question; what is that paint that has the effect of marble you can get wal-mart ChosenWon Off-Topic 6 11-24-2003 03:05 PM
What is that place that makes Magnetic Decals??? mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 4 01-09-2002 02:03 PM
