Old 07-11-2009, 12:42 PM   #1
kpalena
Member#: 82431
2006 06 wrx limited
CGM
Default Am I in trouble?
I did my 30k service...well...30k miles ago. I am due for my 60k and have been seeing that the coolant conditioner is recomended for all models and all years. I did not put it in 30k miles ago. How bad was this oversight?
Edit....
Called SOA. They said that I do not need the conditioner....FWIW.
kpalena is offline   Reply With Quote
Old 07-11-2009, 06:16 PM   #2
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
SOA is correct, you do not need the conditioner. The conditioner was needed in non-turbo models because of diff headgaskets.
RonJitsu is offline   Reply With Quote
Old 07-11-2009, 07:03 PM   #3
kpalena
Member#: 82431
2006 06 wrx limited
CGM
Thank you. From the mood around here though I'd thought I had gone and killed my car...
Old 07-13-2009, 11:37 AM   #4
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....a couple of years ago the coolant replacement procedure had been amended in the service manuals for all model years to include the recommendation for the use of the conditioner. I checked bak in early 2007 and found this snippet from the SOA site for the MY2007 schedule:
To prevent cooling system leaks, always add Genuine Subaru Cooling System Conditioner (Part no. SOA635071) whenever the coolant is replaced.
....unless something has changed since that time.
Old 07-15-2009, 01:56 PM   #5
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
I'm on my second subaru, and have never installed the conditioner. (stop leak) no problems
crampfan is offline   Reply With Quote
Old 07-16-2009, 03:20 PM   #6
leecea
Member#: 37359
2003 WRX
I believe the "conditioner" is just Radweld. I haven't used it in my car because I have no leaks.
I've certainly used Radweld on old beaters, to keep them going, but I'm hesitant to be putting Radweld in a newish car with every coolant change. That's just my opinion.
leecea is offline   Reply With Quote
Old 07-17-2009, 01:20 PM   #7
Nims
Member#: 159085
If it's been fine for the last 30k, I think you're in the clear!
Nims is offline   Reply With Quote
Old 07-17-2009, 04:30 PM   #8
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Subaru revised their policy and Coolant conditioner is to be used in every coolant change regardless.
It is also listed in the cooling system FAQ on here too
http://forums.nasioc.com/forums/showthread.php?t=504002
blackfang is offline   Reply With Quote
am i in trouble??? legacydreamz Off-Topic 8 04-20-2007 10:50 PM
am i in trouble? Jeff Moses Tire & Wheel 7 02-11-2007 09:27 PM
TXS Stage 4 + UTEC + 50 Mile One Way Freeway Commute = Am I In Trouble????? xfactor834 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-14-2002 03:40 PM
Am i in trouble?? Future Subaru Driver1 Normally Aspirated Powertrain 10 09-28-2001 11:39 PM
Rosecroft Raceway (Maryland)Autocross this weekend. Hoo boy..am I in trouble? El Kabong General Forum Archive 3 05-06-2000 12:36 AM
