Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 08-02-2009, 04:15 PM   #1
SubieKid707
Member#: 188840
2007 Impreza 2.5i
Default 2.5i wagon wheel fitment
Im usually not the one to start a new forum but i'm going off to college in two weeks so i need some help fast. I own a 2.5i wagon, and as some of you know 6.5" wide wheels are the pits so i need some change. I've been looking into some 18x8" wheels. I want to wrap them in 245/45/18's but i don't know about fitment. Making matters worse i am lowered on Epic lowering springs. Will they fit? Rub? Any help is appreciated...
Information on the springs:
http://www.rallysportdirect.com/shop...gs-p-3862.html
SubieKid707 is offline   Reply With Quote
Old 08-02-2009, 04:34 PM   #2
Crawdads
Member#: 30907
SWP GDB-G
245/45 is way too tall...and a 245 is pretty wide for a wagon.
225/40 would be better/easier.
Crawdads is offline   Reply With Quote
Old 08-02-2009, 04:42 PM   #3
SubieKid707
Member#: 188840
2007 Impreza 2.5i
what if i went with a 245/40? or 235/45 or 40?
Old 08-02-2009, 04:45 PM   #4
Crawdads
Member#: 30907
SWP GDB-G
Do you understand how tire sizes work?
If so, you want a tire close to 25" tall.
Are your rear 'fenders' rolled? There is not much room in the rear of a lowered wagon...hence why I suggested a 225.
What tires are you looking at specifically, there is a lot of variation in tire width between brands and models, so that will have a significant impact.
Old 08-02-2009, 04:58 PM   #5
SubieKid707
Member#: 188840
2007 Impreza 2.5i
Nothing in perticular yet. I'm trying to get some ideas for now. I'm on a budget. Any suggestions?
Old 08-02-2009, 06:09 PM   #6
ScoobyDooKC
Member#: 192164
2003 Impreza WRX
I figured I'd throw this idea out to you: While 18's do look great, you don't necessarily need rims that big!
Here's what a member on my local forum did, see what you think:
http://kcsubaru.com/forums/viewtopic.php?t=17325
The nice thing with keeping a 16" wheel size is your unsprung weight stays very low.
For example: an 02-04 WRX rim weighs 16.5lbs. A newer stock WRX rim weighs in the neighborhood of 20-22.
That pair of forged BBS wheels? 12.2 lbs. A set of 18's? 30 pounds, at least. Correct me if I'm wrong.
The other thing about running a 245 width tire (with a lowering kit) is that the wagons do not have the flared fenders that the sedans do. Too wide a tire, and the tire will rub against the suspension and fender, most often in the rear. Mess up a tire, and you got yourself a $120 toy for your kid to swing on.
Bottom line, the widest I'd go is 225.
My .02 cents
ScoobyDooKC is offline   Reply With Quote
Old 08-02-2009, 07:13 PM   #7
SubieKid707
Member#: 188840
2007 Impreza 2.5i
I totally understand where your going with the rim weight, but at this time I want something more pleasing to the eye like crawdads said. Anyone hear anything good about Hankook Ventus V12 Evo K110's?
Old 08-02-2009, 09:07 PM   #8
kman25i
Member#: 217792
2010 Impreza 2.5i HB
I just bought some in 225/45-17 wrapped on enkei rpf1 17x7.5.
http://www.caranddriver.com/reviews/...mparison_tests
Tirerack had them to me in 4 days and I'm in Canada. Can't beat that.
kman25i is offline   Reply With Quote
Old 08-02-2009, 11:55 PM   #9
mslstixx
Member#: 101387
2006 2.5i Wagon
RBP
225 is a good width. You can fit 235, but then if your offset of the new wheels are too low then you might still rub the fenders. I put 245/45/17 on a +47 offset and they ripped both fender rubbers right off - don't do that
mslstixx is offline   Reply With Quote
Old 08-03-2009, 10:10 AM   #10
BeatLA
Member#: 182396
2005 WRX Wagon
2004 FXT for Mrs. BeatLA
If you want an idea, I have Prodrive P1's, 18x7.5 with an offset of 46. I run 225/40/18's, all on an 05 Wagon, stock suspension.
Does it rub, absolutely. You'll need to roll your fenders as a minimum.
Personally, if I had it to do over again, I would have went 17's.
BeatLA is offline   Reply With Quote
Fitment on '06 2.5i Wagon rabbit_ears Tire & Wheel 0 02-04-2010 12:05 PM
07 2.5i wagon wheels on 07 wrx dc2skel Tire & Wheel 6 06-04-2009 06:14 PM
Will 04 WRX wheels fit an 07 2.5i wagon? incorporeal Tire & Wheel 1 11-08-2007 03:30 PM
07 2.5i Stromung midpipe fitment issues Mus35th Normally Aspirated Powertrain 4 11-25-2006 10:39 AM
Wheel size For 06 2.5i wagon ryan2b Normally Aspirated Powertrain 0 11-08-2006 04:06 PM
