Old 08-14-2009, 12:29 PM   #1
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Default Oops...broken RPF-1 :-(
Not sure how or why, but one of my RPF-1s cracked on my drive home from a friend's place last night. I heard a clicking noise and waited until I got home to check it out. I jacked up the corner of the car and wiggled the wheel thinking it might have been a wheel bearing or something with the brakes. When I actually looked at the wheel I kinda had a moment and freaked out. Had I been on curvy fun roads on my way home instead of the expressway I might have broken the wheel right off.
So far I can't say anything but good things about Enkei and their customer service. I sent a couple pics and they are already looking into whether or not they can warranty the full set. If nothing else I was told they might sell me a set direct at a reduced price.
Scooby921 is offline   Reply With Quote
Old 08-14-2009, 01:10 PM   #2
Web Foot STi
Member#: 39086
2004 STi
Holy crap!
What does the bead/rim look like? I've never seen anything like that.
If it cracked in the middel of no where you have a case.
Web Foot STi is offline   Reply With Quote
Old 08-14-2009, 01:26 PM   #3
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Originally Posted by Web Foot STi View Post
Holy crap!
The lips on all the wheels have a few dings here and there, but they've been like that for the 3 years I've owned them. I never had a problem in 3 years of autocrossing. Now that I've been daily driving on them for a week they cracked .
Old 08-14-2009, 01:15 PM   #4
BeatLA
Member#: 182396
2005 WRX Wagon
2004 FXT for Mrs. BeatLA
That is a very odd place to crack. I'm no expert, but I'm voting on a defect in the manufacturing process...
BeatLA is offline   Reply With Quote
Old 08-14-2009, 01:20 PM   #5
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
The wheels look to have been Powder Coated. At what Temperature where they baked at?
Reason I ask is the grain structure of aluminum changes at a relevantly low temperature compared to other metals. Which could have caused the metal to become brittle and crack.
RallySport Direct is offline   Reply With Quote
Old 08-14-2009, 01:24 PM   #6
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
They were painted...PPG automotive paint. Prior to painting they were dipped in an aircraft grade chemical stripper, no blasting and no high-temp baking involved.
Old 08-14-2009, 01:27 PM   #7
RallySport Direct
Member#: 33174
We are Open Late!
Thats a good paint job then, couldnt tell from the images if it was painted or coated.
How long have you had them on the car for? Any track days? Any damage to the tire around where the fracture occurred (maybe a pot hole)?
I have seen several sets of Enkei wheels get damaged in road racing from hard impacts, but not fracture to the extent of yours.
Old 08-14-2009, 01:31 PM   #8
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Paint job is pretty good, three coats of base and one coat of clear.
These had been my auto-x only wheels for the last 2.5-3 years. I stopped autocrossing the car and decided to use them as dailies. I had new tires mounted up and I've been driving on them for a week. Tire is in good shape.
Old 08-14-2009, 01:35 PM   #9
RallySport Direct
Member#: 33174
We are Open Late!
I dont even know what to say about that kind of fracture if there is no damage to the rim, thats just a bit uneasy to look at.
Keep us updated on what Enkei says about the fracture, as we are all quite interested on what they say could have caused the damage.
Old 08-31-2009, 06:05 PM   #10
gpshumway
Member#: 43950
07 WRX LTD Wagon
It's possible that chemical stripper caused hydrogen embrittlement. Acid baths can cause the problem. Were the wheels baked after the stripping process to allow the hydrogen to diffuse out of the material harmlessly?
Mind you I have no idea the particulars of your stripping process.
Wikipedia entry on Hydrogen Embrittlement
gpshumway is offline   Reply With Quote
Old 08-31-2009, 07:26 PM   #11
Web Foot STi
Member#: 39086
2004 STi
If you read your link you will see that aluminum isn't very susceptible to hydrogen embitterment. It's more of a problem with steel. One of the worst examples is chrome plating and not properly baking the H out afterwards. That's why there is no such thing according to the SCCA as a chrome roll bar. They don't want to get involved with processing.
These wheels were not baked. That is a heat treat/artificial age issue. They were striped with and aircraft chemical stripper. One that the FAA is ok with using on Al. They are kinda picky about such things.
Those black lines on the other spokes is the typical wear debris that works its way out of a tight crack fretting and propagating. In the past I did a lot of fatigue testing of cast A356-T6 Al truck hubs and saw a lot of those black lines. Typically the initial one would be so tight that wet florescent dye penitent would not indicate, but wipe the black off and run for another hour, or so and the black line would be back. Sooner, or later that crack would take off, trip the limits, and you would have a box of broken parts. It's impressive when a hub disassembles itself at 1,200 rpm under 13,200 lb vertical and 6,600 lateral load...
Glad that wheel the had enough belt and suspenders so that the whole spider didn't tear out at once.
Looking at the photos again from the back you can see the relatively sharp corner where the parting line was ground. Perhaps this is where things started? I know inside radii get all the attention, but outside corners can cause problems too.
Old 08-31-2009, 11:57 PM   #12
gpshumway
Member#: 43950
07 WRX LTD Wagon
Its much more common with high strength steel, but it's not unheard of with Aluminum. The fact that these wheels had been chemically stripped raises the question.
It's certainly possible that the FAA approved procedure requires a post-treatment for certain alloys which was not performed in this case. Its been a while since I specified a process which required post treatment on aluminum, but my recollection is a long duration, low temperature bake was recommended for alloys subject to issues with certain plating processes.
Again, I have no idea what alloy the wheels are made from or what potential issues the stripper and its related process pose, I'm simply suggesting the possibility that the stripping process weakened the wheel. Given many auto-x and open track guys run these wheels without issues, I wouldn't write off the possibility.
Of course it's unlikely Scooby921 will be paying someone to autopsy his wheels, so we may never know for sure.
Old 08-14-2009, 01:26 PM   #13
Web Foot STi
Member#: 39086
2004 STi
Good point, but over aged still would have cracked at the stress points. Why did it pick the middel of the spokes?
Old 08-14-2009, 01:26 PM   #14
Web Foot STi
Member#: 39086
2004 STi
Old 01-29-2010, 02:36 PM   #15
trick3d
Member#: 202146
2010 evoru
GG
trick3d is offline   Reply With Quote
Old 08-14-2009, 01:28 PM   #16
Web Foot STi
Member#: 39086
2004 STi
Shazbat 921. You know what you are doing.
Old 08-14-2009, 01:33 PM   #17
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
I honestly think its just one of those awkward failures. If it wasn't me it could have been someone else. I'm just thankful I caught it and didn't drive more than 20 miles like that.
Old 08-14-2009, 01:34 PM   #18
Mechie3
Member#: 120152
No one?
Oh Snap!
I have RPF-1's for AX and they've never had issues.
Old 08-14-2009, 01:37 PM   #19
Web Foot STi
Member#: 39086
2004 STi
That's a fatigue crack, but in the middle of no wear. as you know. I'm scratching other od places thinking about it.
The only thing I can think of is an improperly vented casting bubble. They F'd up the mold for a lot run.
Now they have to think about the R word.
Old 08-14-2009, 01:47 PM   #20
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Originally Posted by Mechie3 View Post
No one?
Oh Snap!
Nor have any of the normal STX/STU competitors I know. Wong's orange wheels were powder coated and are still going strong as the wets on McCance's ESP car. Those saw a lot more abuse than mine have.
This one failure certainly doesn't mean RPF-1s are anything to be concerned about. The number of people using them in high abuse situations and not having any failures far outweighs my one cracked wheel.
I'm expecting a call-back on Monday or Tuesday. I'll give you guys an update when I know something.
It could have been something as small as a stone chip that cracked the surface and simply took this long to propagate and snap. When one went the other took all the load and couldn't handle it.
No need for a recall if one wheel out of hundreds or thousands breaks. When you consider the physical loads a wheel sees during any given drive it is amazing they hold their shape to begin with.
Old 08-14-2009, 02:01 PM   #21
Web Foot STi
Member#: 39086
2004 STi
One notch was catastrophic?
Not in the world that we know.
Other than satiates who designs that close to the edge? (SST went down with a cascade failure.)
(I've been around some campaigns. No fun.)
Old 08-14-2009, 03:45 PM   #22
draco159
Member#: 204121
2005 WRX Wagon
CGM
Wow thats crazy! Sorry to get off topic, but OP do you happen to have a pic of the wheels on the car? They look great!
draco159 is offline   Reply With Quote
Old 08-14-2009, 04:10 PM   #23
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
A friend of mine had the same thing happen to his 5Zigen wheels. They sent him a whole new set in whatever size he wanted. Cracked in the same place roughly. This was during an autox though with R comps.
subydude is online now   Reply With Quote
Old 08-14-2009, 04:19 PM   #24
greco2030
Member#: 183614
2002 wrx
aspen white
damn man good thing it didnt fully break when you were driving... they should reimburse you for the wheels are give you a new set
greco2030 is offline   Reply With Quote
Old 08-14-2009, 10:03 PM   #25
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Had that been a Rota, WW3 would have just broken out...again.
Glad you are ok Brad.
Tony
Platinum Autos sold broken head STi :[ Drewbiehd North West Impreza Club Forum -- NWIC 43 03-30-2010 06:24 PM
WTT 17x8 Black RPF-1's for Silver BBS or Silver RPF-1 MattD87 Wheels/Tires 3 04-22-2009 08:59 PM
Pics of Enkei RPF-1 in gold? NightmareOnSubySt Tire & Wheel 39 03-15-2004 11:47 AM
Enkei RPF-1 final install pics Cosworth Member's Car Gallery 39 05-09-2003 02:44 PM
Enkei RPF-1 teaser Cosworth Member's Car Gallery 20 04-04-2003 07:43 PM
