Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 10-19-2009, 03:11 PM   #1
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
Default WTF, need some input
So this summer some of you knew I had some problems with my STI and misfires on cyl. 2 and 4. Well for the last couple months I have not been driving it and have been saving for a new engine.
Well I took it to a local shop for a comp test and leak down test to make damn sure it was the engine before I purchased a new short block.
Results were 110 across the board....?
So now to what is causing the misfire. The mechanic told me it may be an intake manifold leak? The car has all new injectors, I have tried new coilpacks, new ngk plugs one step colder.
All I know is that I am super stoked now but I still have problems. Anyone else ever have this problem?
Mods are; FP green, PE850, FMIC, 3" Catless and I am not sure if any of the other mods really matter.
I know when John was tuning my car cyl 2 and 4 had a slight roughness and he was having troubles tuning it.
Help please!
skatevolcom06 is offline   Reply With Quote
Old 10-19-2009, 03:14 PM   #2
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
aftermarket flywheel?
bhhamblin is offline   Reply With Quote
Old 10-19-2009, 03:20 PM   #3
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
nope, stock clutch and flywheel
Old 10-19-2009, 03:22 PM   #4
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
It still runs good tho, this is from this weekend
Old 10-19-2009, 03:25 PM   #5
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Help please!
You need a better tune. I would change maps and see if it clears up the problem.... You are not the first person I have heard about with misfire codes from Johns tune.
medamullet is offline   Reply With Quote
Old 10-19-2009, 03:45 PM   #6
Not-EWRX
Member#: 158043
2013 Wrx Hatch
You were out at tear apart auto this weekend wern't you!.
Not-EWRX is offline   Reply With Quote
Old 10-19-2009, 05:40 PM   #7
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
Yes I was! We were pulling a tranny for my friends Cavalier.
Old 10-20-2009, 12:51 AM   #8
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
the shop also pulled these codes, which are new to me.
P0122 Throttle position sensor circuit low input
P0123 Throttle position sensor circuit high input
Old 10-20-2009, 09:00 AM   #9
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Sometimes when I tinker with my car I get those cars on initial start up. I reset and they don't come back. Are yours coming on all the time?
Old 10-20-2009, 10:13 AM   #10
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
yeah, I am guessing those two codes are the culprits when my car goes into limp mode. I will just be driving and all of a sudden it will just die out until it goes under 3k rpm and then it feels like i am driving a honda and it wont let me rev over 3k rpms.
It did this to me a few times while driving to SLC this weekend, it sucks when you are going down the free way and your car just dies out, haha.
Old 10-20-2009, 11:28 AM   #11
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Check the wiring connections on your throttle inlet/ DBW unit, check connectors for pinches or frays, maybe even moisture breakdown dude.
Have you had the IC off recently? or any work in that area?
Kastley85891 is offline   Reply With Quote
Old 10-20-2009, 11:59 AM   #12
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
Your AVCS Solenoid on cyl. #2 and #4 may be going bad.
Stames_wiltz is offline   Reply With Quote
Old 10-20-2009, 12:21 PM   #13
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
Nope, no work has been done for a while on this car. Also I am FMIC, but I did notice that the elbow off of the turbo does press up against the harness on the throttle body. I will take a picture tonight after work.
Do these commonly go out and cause misfire codes? I am not to familiar with the AVCS.
Old 10-20-2009, 02:03 PM   #14
Stames_wiltz
Member#: 143264
2006 WRX TR
Not super common, but they do go out. When they go bad you will get misfires.
Old 10-20-2009, 02:46 PM   #15
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
Would they also cause an erratic idle?
Old 10-20-2009, 02:51 PM   #16
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
I think I am going to pull the AVCS banjo bolt filter out, hopefully that helps with my Idle issues.
Old 10-21-2009, 10:36 PM   #17
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
Ok, well its going to Solid on the 30th to install my EWG setup and try to find my issues.
May need a new(er) laptop. Need some input. wizzman New England Impreza Club Forum -- NESIC 21 10-29-2005 02:47 AM
Need some input. 128d Car Audio, Video & Security 2 05-07-2002 04:37 PM
I need some input Hittokiri Battousai Interior & Exterior Modification 1 03-17-2002 01:41 AM
needs some input gnurider Mid West Subaru Owners Club Forum -- MWSOC 10 10-27-2001 01:13 PM
Gonna paint my calipers...need some input Aaron'z 2.5RS Interior & Exterior Modification 3 09-25-2001 11:04 AM
