Old 12-17-2009, 12:21 AM   #1
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Default Parallel Fuel Rail options for '00-'04 SOHC EJ25 motor?
Just wondering if anyone's done a parallel fuel rail conversion for the top feed injectors for '00-04 SOHC EJ25 motors?
GTBGUY is offline   Reply With Quote
Old 12-17-2009, 09:16 AM   #2
Skidd
Member#: 1853
GC6 Supercharged
STM
Skidd is offline   Reply With Quote
Old 12-17-2009, 10:44 AM   #3
Safir
Member#: 3873
. Paradise is
like Disney with hookers
for mine I started with these:
http://www.outfrontmotorsports.com/fuel_rail_setup.htm
various -6 fittings, hoses, "T" fittings, FRP, etc later, parralel fuel rails.
less budget-friendly than the one above, but worked best for my application.
Safir is offline   Reply With Quote
Old 12-20-2009, 08:49 PM   #4
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Safir, do you have some pictures of your set-up? I'm thinking of doing this conversion on my brother's Outback which has now been supercharged.
Old 12-20-2009, 09:15 PM   #5
Safir
Member#: 3873
. Paradise is
I may - my web server died but I think I have some backups on a USB drive somewhere.
pretty typical parralel setup, line from fuel filter goes to a "T" fitting, -6 line to one end of either fuel rail, -6 lines back to a universal FPR
fuel rails, ~10' -6 braided line, dozen or so -6 hose ends, a few adapters, FRP and said "T" fitting.
a few crappy celphone pics... i'v got good ones SOMEWHERE...
http://www.twitpic.com/jizkc
http://www.twitpic.com/kfn75
Old 12-22-2009, 01:47 AM   #6
niteon3
Member#: 166902
1999 RBP Gc8
is there a need for this modification when you turbo charged your car or not really? does it matter even if you have a type of engine management?
niteon3 is offline   Reply With Quote
Old 12-22-2009, 07:20 PM   #7
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
i did mine using aeromotive wrx fuel rails, they work u just have to make a custom bracket.
Jeff54 is offline   Reply With Quote
Old 12-22-2009, 08:36 PM   #8
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
Just helps cyc # 4 since its last in the series and runs a tad lean. Equal fuel better safe especially when playing with boost on N/A engines regardless of EM
here's a crap pic of mine.
rubber fuel lines and brass fittings.
freeride is offline   Reply With Quote
WTB: SOHC EJ25 Motor or WRX Motor Gomer_GSX NWIC Private Classifieds 0 04-20-2009 05:27 PM
Question on finding parts for the series to parallel fuel rail mod Legacy777 Normally Aspirated Powertrain 1 02-24-2003 09:06 AM
Can't find the Parallel fuel rail instructions Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 7 02-22-2002 12:47 AM
Parallel Fuel Rail Mod Queston Skidd Normally Aspirated with bolt-on Forced Induction Powertrain 26 01-27-2002 11:59 AM
Parallel Fuel Rails? adeck Normally Aspirated Powertrain 0 08-31-2001 02:27 PM
