Alaskan Impreza Club
Go Back   NASIOC > NASIOC Chapters > Alaskan Impreza Club Forum -- AKIC
Old 06-08-2002, 07:14 AM   #1
Tusin
Member#: 17074
01 VW Jetta 1.8T
Default To: Blackknight
Sorry I didnt IM ya, but need to kind of get this out to you and maybe anyong else that might have a idea.
First do you still have that Vag-Tool that you were borrowing? I had to send mine back. And wouldnt you know, after I send it back I start having issues. Drove my car today running just like normal. Hop in to go out tonight and my car wont start, I mean nothing, not turning over, not clicking. Of course I first thought my battery was dead but all my lights were working fine. I did try to jump it but nothing different.
So are you all tied up tommrow? I THINK I still have your cell.
Tusin is offline   Reply With Quote
Old 06-08-2002, 07:10 PM   #2
KapaFool
Member#: 2679
2010 WRX4FD
I don't know what a VAG-TOOL is but I have an idea somewhat.
KapaFool is offline   Reply With Quote
Old 06-08-2002, 08:15 PM   #3
Tusin
Member#: 17074
01 VW Jetta 1.8T
Vag-Tool=ODBII-Tool.
Old 06-08-2002, 10:24 PM   #4
BlackNight
Member#: 16285
2004 VW .:R32
Tornado Red
Sorry man, i gave the tool back. Did you try unhooking the battery and let the ECU reset? i would try that, also your battery could be going bad, we had this problem with the TDI. It would run all the lights. but the battery didn't have the amps to turn the motor. Just a thought. You can have the battery tested at Sears for nothing.
BlackNight is offline   Reply With Quote
Old 06-08-2002, 11:46 PM   #5
Tusin
Member#: 17074
01 VW Jetta 1.8T
Alright I will probably take the battery out and go to sears tommrorw. And I took the whole ECU out and tried my "stock" chip and nothing. When you had the problem with the TDi, would it make a noise when you tried to crank it? Or would it not do anything? I tried to Jump it to and nothing at all.
Old 06-09-2002, 12:14 AM   #6
Code-7
Member#: 5077
'97 e39 540i6
You put the clutch down when you tried to start it, right?
Obviously a spark is not getting to your motor. The battery works fine if all your lights c'mon and don't eventually die, so there's something in between like the starter/distributor that's not responding to the ignition. Perhaps a blown fuse has wiped some systems out? Check your spark plug wires and connections, distributor, etc.
Not really sure what it could be, or wether the fuses would even prevent your car from starting, but it's worth a check. I blew a fuse once in my GTI and it wiped out my power windows, locks, sunroof and truck opening system in one fell swoop. Simple fix. Hope you find out what's wrong and it's not expensive.
OT: Where'd you find the 3M IHG in town? I've always ordered mine online and been forced to wait the 4 days or so it takes to get here. It'd be nice to save that time.
Code-7 is offline   Reply With Quote
Old 06-09-2002, 03:37 AM   #7
Tusin
Member#: 17074
01 VW Jetta 1.8T
Yeh I dont think it is the Battery Either. But I just want to tottally rule it out. Trying to do all I can right now before I either take it to Eero (lol, Ya right, if I do that I wont have my car back in time for the Import Drags), or go by Lee's Adivce and try Artic Import Center. At this point I really dont care if I have to pay for the job, unless it is $$$$$$$$$$$.
Old 06-10-2002, 12:04 AM   #8
Tusin
Member#: 17074
01 VW Jetta 1.8T
OK so the battery is fine. So now I have no freaking idea whats going on.
Old 06-10-2002, 02:13 AM   #9
Code-7
Member#: 5077
'97 e39 540i6
Ok, when you unlock the car with your remote, do you hear the fuel injection primer go off? It's a "whhhhhhrrrr" sound, along with the clunking sounds of the locks. If you don't hear that, something can be wrong with that too. Though, if it was a fuel problem, you should still hear the clicking/turnover sounds. You did check all the fuses right?
The only other thing I can think of is the starter solenoid. Going to have to start working down the chain, beginning with the starter to the spark plugs.
Old 06-10-2002, 05:45 AM   #10
Tusin
Member#: 17074
01 VW Jetta 1.8T
I actully just did replace the spark plugs about a week ago. But if it was the Spark Plugs wouldnt it it still at least try to fire? I think it might be the Starter Soliniod too, but that is kind of beyond me. I like farting around with my car and installing stuff. But when it comes to real mechanic work, most of the time I am clueless, ok maybe not clueless, maybe it is more Timid.
Old 06-11-2002, 12:09 AM   #11
RallyX13
Member#: 1543
2007 Jetta GLI
Yellow
So when you turn the key to crank it over, there is absolutely nothing that happens? No sounds at all?
I could not really tell from the posts above, do your lights and stuff come on?
Well good luck, and let me know if I can help man.
Kris
RallyX13 is offline   Reply With Quote
Old 06-11-2002, 01:20 AM   #12
Tusin
Member#: 17074
01 VW Jetta 1.8T
Yeh dude, nothing happens at all. The lights and everything works like normal, just when I turn it over nothing happens.
It is down at Eero now. So everyone pray to the Car-Gods with me tonight and hopfully it is a quick and easy fix I hope to get my car back, get the AVC-R and get it installed and get the rest of my Exhaust Done all by this Saturday.
Old 06-11-2002, 03:56 PM   #13
RallyX13
Member#: 1543
2007 Jetta GLI
Yellow
Well good luck man, are you gonna be working on it over at Winslows place when he returns?
Kris
Old 06-11-2002, 04:31 PM   #14
Tusin
Member#: 17074
01 VW Jetta 1.8T
Yeh last week Winslow and I were talking about putting in the AVC-R over at his place. I found a walkthrough the other day and it seems really straight forward. But first got to get the car moving
Old 06-12-2002, 07:53 PM   #15
Code-7
Member#: 5077
'97 e39 540i6
So has eero told you what is wrong with it yet?
Old 06-12-2002, 07:59 PM   #16
Tusin
Member#: 17074
01 VW Jetta 1.8T
Just posted a thread
How To: Push Start?? bluey Newbies & FAQs 41 06-20-2001 05:14 PM
How To: Setting Valve Lash on SOHC EJ25 stimpy Normally Aspirated Powertrain 3 06-06-2001 03:58 PM
To: sccobysouth STi - IMPREZA Hawaii Impreza Club Forum -- HIIC 0 05-01-2001 01:52 AM
To: Everyone writing me about engine & tranny mounts Revision Mid West Subaru Owners Club Forum -- MWSOC 2 04-25-2001 09:28 PM
To: SYMS goten Vancouver Impreza Club Forum -- VIC 1 04-22-2000 01:15 AM
