Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 05-20-2010, 09:20 PM   #1
THE ONE
Member#: 43918
2002 Scooby Wagon
Default Cruise Control Help Please!
Hey all!
I know the WRX has a reputation for the cruise control going bad. Mine has been not working since I bought it back in October. Car is a 2002 WRX wagon. What should I check first to make it work again? Planning a couple road trips and having cruise control would be nice. Thanks.
THE ONE is offline   Reply With Quote
Old 05-21-2010, 05:48 AM   #2
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
Well first off, is there a cable going to the throttle body?
Second, check the Cruise control fuse
Look under the dash and see if there are any wires attached to the sensors going to the clutch or brake. Or do they look disconnected or broken.
Are all the brake light bulbs good?
Is the brake light on in your dash?
looking at the wiring diagram, you need f/b fuse no. 18 and Horn Relay.
Fuse no 16 looks like it powers the brake wire signal that stops the cruise when you hit the brakes.
Does it light up at all?
Never really looked at a subaru cruise control, but normally they have vacuum running to them. Check for disconnected vacuum lines.
bobturismo is offline   Reply With Quote
Old 05-21-2010, 09:33 AM   #3
THE ONE
Member#: 43918
2002 Scooby Wagon
Thanks I will check those things out. I have just heard this is a common problem with the WRX near this model year.
Old 05-21-2010, 10:47 AM   #4
nwood1976
Member#: 103273
2002 WRX 2.15 18gxtr
Sedona Red Wagon
I had this same issue with my 2002 wrx wagon. I took it to the dealership and they found that some of the wires had pulled out of the connector going into the cruise control module under the dash behind the steering colum. They just pushed all the wires firmly back into the connector and everything was good.
nwood1976 is offline   Reply With Quote
Old 05-21-2010, 04:56 PM   #5
bobturismo
Member#: 42145
6-4 jockin da bish-
Most of those people had their cruise light come on and it worked halfway. If yours doesn't do anything, then mosr likely it's a power problem.
\Either you're not getting main power, or one of the sensors is not getting power or you're getting a signal from a sensor telling it not to work or you have a break in the circuit, disconnected plug or broken wire.
here is the wiring diagram for your car, on page 61 is where the cruise diagrams start
http://ken-gilbert.com/wrx/mans/7%20-%20WIRING.PDF
If switch doesn't light up, check for power at the fuses, the check for power at the swtich and so on and so on.
Old 05-21-2010, 08:32 PM   #6
THE ONE
Member#: 43918
2002 Scooby Wagon
Yeah the cruise control button on the side lights up when I push it, but when I try to use the lever to set it nada happens.
Old 05-21-2010, 08:34 PM   #7
nwood1976
Member#: 103273
Sedona Red Wagon
Exactly what my wagon did, I hope you're able to track it down man!
Old 05-21-2010, 11:11 AM   #8
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
If that fails, check the signal of the neutral position sensor. If those fail, it's possible for the car to think it's in neutral all the time and then will not let you activate the cruise control.
Old 05-22-2010, 08:13 PM   #9
NO PULSE
Member#: 110733
Could this be an issue with CEL? Doesn't CC stop working if the car threw a CEL and wasnt cleared?
NO PULSE is offline   Reply With Quote
Old 05-27-2010, 09:08 AM   #10
THE ONE
Member#: 43918
2002 Scooby Wagon
Not a chance in my case.
Horn and cruise control help please! PDX25i Electrical & Lighting 1 03-13-2009 08:27 PM
removing cruise control HELP gr8wheels Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-22-2002 06:00 PM
Cruise control users, please pull over when.... Snoopy Off-Topic 16 08-01-2002 07:10 PM
Button Blanks by the Cruise Control...Help me out here! wrx182 Interior & Exterior Modification 2 02-14-2002 01:15 PM
Cruise control help Marinator Normally Aspirated Powertrain 3 06-20-2001 09:00 PM
