Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 05-30-2010, 03:00 PM   #1
beaconhillkilla
Member#: 174710
1992 Legacy Turbo
Dream Machine
Default Engine Overhaul
Finally came across some cash, so I ordered myself a new clutch. Im going to pull the motor instead of dropping the trans to do it (I hate straining my neck under the car that much). My car has 167 thousand miles with a mysterious past, so while the motor is out I want do all the possible maintenance things I can without splitting the block (my engine experience ends at removing the heads). I need some help figuring out exactly what all I should do. Also, would anyone recommend doing the head gaskets? I don't know if they have been done.
Working with a 95 ej18
-Timing belt
-Water pump
-Oil pan gasket
-Rear kidney plate
-Trans input shaft seal
-Rear main crankshaft seal
Have things to add?
beaconhillkilla is offline   Reply With Quote
Old 05-31-2010, 03:07 AM   #2
GrundleJuice
Member#: 165749
cam seals, valve cover seals/gaskets, coolant hoses, exhaust gaskets that are removed, timing belt tensioner and pulleys, oil pump seals. do they water pumps need service/replacement unless they have failed?
Old 05-31-2010, 01:06 PM   #3
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
if it ain't broke....
You could replace ALL the gaskets if you want, but if they're working fine...why? Take a look at the front main seal as well. I daresay you should remove the oil pump and check the screws on the back to make sure that nothing has backed itself off. If you're really ambitious, you can check to see if the output from the oil pump lines up properly w/the input to the block.
I'm not familiar w/the 1.8L heads, is there any valve adjusting to do there?
yarrgh is offline   Reply With Quote
Old 05-31-2010, 07:48 PM   #4
grafton
Member#: 187936
97 Legacy w/12:1CR
07 WRB STi OTS Stage 2
the ej18's have hla, no adjusting nessary or possible
grafton is offline   Reply With Quote
Old 05-31-2010, 07:58 PM   #5
beaconhillkilla
Member#: 174710
1992 Legacy Turbo
Dream Machine
I'm prepping this car for rally cross and am going to put it through heavy abuse. I may be wrong, but don't the hla's need to be refilled with oil after some time?
Old 05-31-2010, 11:08 PM   #6
grafton
Member#: 187936
97 Legacy w/12:1CR
no, kinda, the oil in them is part of the oil that runs around in the motor in reality it changes with each oil chance all on its own with time
ether you have good or bad hla's but if you take them out you are supposed to re oil them or it will take a few hours* of the engine running to get them @ 100% again.
* not too sure on the time
also see if you can find a 97 -98 ej22e they have SLA and reduce some of the effort it takes to turn the camshaft*, but they do need adjusted every 100k
*subaru changed them to get better mpg along with other changes in the 97MY
04 STi Engine Overhaul. Am I missing anything? tjphillips36 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 03-01-2009 09:39 PM
Engine Overhaul omnithreat Texas Impreza Club Forum -- TXIC 6 11-19-2007 01:48 AM
WTB: Ej25 engine overhaul kit snowcrzy Private 'Wanted' Classifieds 0 07-28-2007 12:39 AM
piston slap rod knock...engine overhaul baby_rs Bay Area Impreza Club Forum -- BAIC 3 12-25-2003 01:16 AM
engine overhaul baby_rs Alaskan Impreza Club Forum -- AKIC 16 05-27-2003 04:29 PM
