Old 08-28-2010, 05:10 PM   #1
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
Default 07 sti wiring stripping fail :( help me get the car read for track
hey, i was wondering if you could help me out.
I have 07 sti harness that i tried stripping
I traced each wire individualy. things removed:
door wiring, key less unit (was never pluged in and car worked fine), hvac, stereo, clock, stereo, hid control, i/c spray button wiring and climate control.
I put wiring back in (temporarily) and as soon as I connect negative battery terminal car starts beeping. really soft (could barely hear it) and its coming from front/ps pump area. I went to start it and it cranks over with no start
any clue what could be the issue?
thanks for the help in advance.
-slava
slava from goshen is offline   Reply With Quote
Old 08-28-2010, 05:10 PM   #2
slava from goshen
Member#: 152176
BRP/SRP
I think it's ignition coil making the noise. I have an unused plug and can't find where it would go. Also if I unplug the unit that's mounted on steering column it will stop making noise. It's not imob though
will take some pics today.
Old 09-04-2010, 10:25 AM   #3
slava from goshen
Member#: 152176
BRP/SRP
anyone know how to wire 07 sti immobilizer back in the harness? i looked at service manual and the plug it had listed for sti already has wire in it.
Old 09-04-2010, 01:12 PM   #4
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Are you also using an 07 STI ECU? AFAIK the 07 ECU needs to be paired with the matching key, key cylinder and immobilizer unit and won't fire up if you are missing anything.
minifreak is offline   Reply With Quote
Old 09-16-2010, 04:18 AM   #5
slava from goshen
Member#: 152176
BRP/SRP
Yes it's all 07sti. Immob wiring got stripped out. Idk where the two wires to the ecu go to. Diagrams that I found have wrong pin out
Old 09-16-2010, 04:19 AM   #6
slava from goshen
Member#: 152176
BRP/SRP
Oh and the car ran fine prior
Old 09-17-2010, 07:58 AM   #7
slava from goshen
Member#: 152176
BRP/SRP
Anyone?
07 STI cylinder 2 failed. Need help planning rebuild. 03RexWgn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-17-2008 02:01 PM
Help me get my car in the air EZ Rider North West Impreza Club Forum -- NWIC 11 06-02-2005 02:28 PM
Thanks to all who helped me get my car back together manchild83 New England Impreza Club Forum -- NESIC 8 07-01-2004 05:04 PM
Okay, who wants to come over and help me get my car running? bobturismo South West Impreza Club Forum -- SWIC 0 03-10-2004 05:59 PM
help me decide the best turbo for about $700-1000 to get 300whp M32WRXin3seconds Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 10-22-2003 11:35 AM
