Welcome to the North American Subaru Impreza Owners Club Saturday September 5, 2015
Old 09-01-2010, 04:21 PM   #1
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
Default What type of steel to use for a custom subframe?
Just wondering what type of steel to use for a subframe? What diameter and thickness of steel tube is recommended?
Oh and if anyone has pics of their subframe to share, feel free to post them here.
OUScooby is offline   Reply With Quote
Old 09-23-2010, 06:56 PM   #2
oguitar
Member#: 206720
2002 WRX Wagon
I'll bump this for you hoping to maybe get a response from someone who knows.
oguitar is offline   Reply With Quote
Old 09-23-2010, 07:43 PM   #3
sidewayz
Member#: 5810
2001 S366 2.5RS
Just a guess. But I would use 1" Dom steel such as roll bar material
sidewayz is offline   Reply With Quote
Old 09-23-2010, 08:23 PM   #4
col5555
Member#: 142017
I guess it would depend on what you want to do.
If its for full on gravel racing events then you would want to use a heavier wall thickness. Tarmac could me made lighter,road so on.
Commonly chrome moly is used in about 1" Dont know about the wall thickness.
I would think a seamless tube would be the go. I have heard of cold drawn and hot but I dont know what the properties are.
Maybe google roll cages and suspension parts for some clues as to what steel they use.
col5555 is offline   Reply With Quote
Old 09-24-2010, 03:58 AM   #5
boardinshorty81
Member#: 174965
07 WRX VF43
I would personally suggest aluminum (maybe thats because I work at an aluminum fab plant). It is considerably lighter, and you won't be seeing any temps that could make it bend.
Then this is all assuming that you weld aluminum, I would suggest taking your time with a nice tig for something like this.
Because aluminum is lighter you could can get pretty thick side walls.
I made a wakeboard tower out of 2" OD 1/8" wall tube and it towed two boarders and some people on it at the same time. I know this doesn't apply too much to your situation, but I am just saying that it will definitely be strong enough. For your situation you could go with something like .75" or 1" outer diameter. Here is a good site:http://www.onlinemetals.com/merchant.cfm?step=2&id=71
I would suggest drawing or modeling the piece you are going to make before purchasing any material. If you have dimensions I can see if I can make a piece and hopefully even stress test it (this is what I do as my job in the summers).
boardinshorty81 is offline   Reply With Quote
Old 09-24-2010, 01:05 PM   #6
oguitar
Member#: 206720
2002 WRX Wagon
Thanks for the help.
I am going to be making a solar car at school and I need to learn how to weld aluminum. I figured I might as well try and make some sub-frame braces while I have a bunch of cool tools to use.
Old 09-24-2010, 02:16 PM   #7
boardinshorty81
Member#: 174965
07 WRX VF43
I do the same but for our fsae car. The car is good practice for tuning too.
I love college, there are plenty of free ways to get experience in groups and such.
Old 09-24-2010, 05:35 PM   #8
oguitar
Member#: 206720
2002 WRX Wagon
Totally agree. Sometimes I get annoyed working with computer geeks though. EE is filled with these total nerds. Smart as hell but not very good with their hands.
This will be my first venture into the welding world.
Old 09-25-2010, 04:00 AM   #9
boardinshorty81
Member#: 174965
07 WRX VF43
Yeah I walk this fine line. I always come back to working with my hands because I have something to hold after.
Where are you intending on having the support mount under the car?
Old 09-25-2010, 10:55 AM   #10
oguitar
Member#: 206720
2002 WRX Wagon
Well I was thinking about making some fender cowl braces. Maybe some rear subframe bracing as well. In my wagon I get a lot of looseness on the rear tires. Welding aluminum does not look that easy. So maybe my dreams overstepped reality again.
I am attending UNM. What school are you attending bordinshorty81?
Old 09-26-2010, 01:44 AM   #11
boardinshorty81
Member#: 174965
07 WRX VF43
I am at case western reserve in Cleveland. I hope to get some aluminum welding practice sometime next month, I'll see how long it takes me to pick up (to the point of making a brace of some sort. I am actually going to try to help weld the frame for the schools fsae car, that should give me some structural practice.
Old 09-26-2010, 01:49 AM   #12
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
So aluminum is the metal to use for a subframe? If I do a subframe I won't be fabricating it myself, I have zero metal working skills. What would be wrong with using steel, it would be cheaper, and even though there would be a weight penalty it would at the lowest point on the car, if it ways less than the stock subframe you still save weight, if it weighs more than you are lowering the center of gravity on the car.
Old 09-27-2010, 12:18 PM   #13
boardinshorty81
Member#: 174965
07 WRX VF43
Not necessarily. You have to think of what kinds of loads you will get in each direction. Saying aluminum will work doesn't mean much as it will work with the right shape, but if designed poorly it will bend as will most metals.
I just despise of steel because of it's weight, that does not mean it isn't right for your application. I would wait for someone with some experience making a brace to chime in with the magnitude of loads you will be looking at.
Old 09-27-2010, 01:15 PM   #14
bigusnickus
Member#: 245851
2004 WRX Rally car
Easy one: 4130 aka chrome-moly aka t45. It is what all race car roll cages and subframes are made out of. It has an infinite fatigue life (unlike aluminum) if properly designed and can be made nearly as lightweight as aluminum. Look up MSI's subframes. Common diameters are .75"-1.5" and wall thicknesses of 0.049"-0.095".
Last edited by bigusnickus; 09-27-2010 at 01:18 PM. Reason: gave wall thickness and diameters
bigusnickus is offline   Reply With Quote
Old 10-02-2010, 02:26 PM   #15
syndromeofthedown
Member#: 190627
No, 4130 isn't what ALL race car roll cages and subframes are made out of. MOST of them are made out of DOM which stands for Drawn Over Mandrel for those of you who don't know. 4130 is used by racers that can AFFORD it.
syndromeofthedown is offline   Reply With Quote
Old 10-04-2010, 06:39 PM   #16
bigusnickus
Member#: 245851
2004 WRX Rally car
DOM is a manufacturing process, not a steel grade.
4130 is DOM. The least expenisve DOM grade is a plain carbon steel such as ASTM 1018 or 1020, which would also work exceptionally well in this application. I guess I am just used to 4130 because you can realize a weight savings over plain carbon by decreasing the wall thickness due to the higher strength of the material.
Either way, steel tubing would be your best choice, preferrably a DOM or seamless tube.
Old 11-07-2010, 12:00 PM   #17
kalescustom
Member#: 147598
95 Impreza 2dr
Just to clear things up, 4130 is NOT T45. 4130 is not accepted by may sancioning bodies due to how brittle it gets in the HAZ.. The only way to solve that problem is to normalize the material. Since there is really no way to prove the joints have been normalized. You cannot use it.
T45 is Carbon Manganese Steel. You cant even buy it in the US and the only place that I have seen it being used is in FIA Homoligated roll cages. AKA Custom Cages UK. Its got around the same tensile strength as 4130 but its properties dont change with heat.. meaning you can even MIG weld it..
Save some money and make your subframes out of DOM 1020. Use 1" x .080". Design it well.
kalescustom is offline   Reply With Quote
Old 11-07-2010, 02:06 PM   #18
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Looking at the differences between 4130 and 1020 (price and strength) I may change my mind from my previous statement. Properly designed with appropriate safety factors, the part made with 1020 will only be about 10% heavier. A properly designed subframe will weigh around 15 lbs, that's only a difference of 1.5 lbs. Not a big deal in my book for the cost and hassle.
I'll probably still go with 4130 for my stuff, but will more seriously consider 1020 as a good option.
Old 11-07-2010, 03:23 PM   #19
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Double post
Old 04-13-2011, 01:50 PM   #20
nottofast
Member#: 89663
1962 Fuji 350
cerelean blue
Absolutely agree with you and hope the OP considers your suggestion. Do you think that 1020 is many times over looked? When I was at Rallispec
talking with Dave he was saying exactly the same thing with regard to 4130 and T45.
nottofast is offline   Reply With Quote
Old 09-27-2010, 09:42 AM   #21
eg33GC
Member#: 206851
56 Belair
Pro Street
how has 4130 not been mentioned? I would't bet Al for a rear subframe
Old 10-02-2010, 02:23 PM   #22
syndromeofthedown
Member#: 190627
It was mentioned in post #4
Old 10-04-2010, 07:28 PM   #23
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I would not use aluminum in this application without a post-weld heat treatment.
T-0 aluminum is pretty much junk. It looks nice and won't corrode, but it will be much heavier than steel for the same structure if both are well designed.
6061 T-651 aluminum would be a great material for a subframe, lighter and stronger than steel. Stiffness is all in the design and could be made equal with either material.
If you do use aluminum, take care to make sure your bolt hole surfaces are thick enough to handle the impact forces they will be seeing without ovalizing.
I would use 4130 steel myself.
Old 11-11-2010, 01:25 AM   #24
Burnman
Member#: 218087
95 Legacy
That ugly 'spruce' green.
No.
Tensile strength is only 45000 psi.
Mild steel starts in the 60000 psi range.
You may be thinking of 7075-T6.
83000 psi tensile strength. But it is not considered to be weldable.
Burnman is offline   Reply With Quote
Old 11-13-2010, 01:28 AM   #25
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Originally Posted by Burnman View Post
No.
I was thinking of A36 steel and comparing based on yield strength. After a material starts yielding it's pretty much over.
What I meant was that it has a better strength to weight ratio, and I worded it poorly.
What Type of Sealent To Use for Headlights? (specific Brand?) WoopWoopSti Interior & Exterior Modification 10 08-14-2007 03:40 AM
What kind of oil to use for the winter season? affinity1 Mid West Subaru Owners Club Forum -- MWSOC 10 09-14-2006 12:42 PM
What type of oil to use on high mileage car? txl146 Service & Maintenance 5 02-04-2005 11:01 AM
Best Brand/Type of Paint to use for the car? Costas Interior & Exterior Modification 14 02-23-2003 07:32 PM
What kind of paint to use for your interior Ripper Interior & Exterior Modification 3 07-01-2001 10:07 PM
