Old 10-12-2010, 09:47 AM   #1
subbi7
Member#: 241967
02 wrx
Default head port job when?
hi i want to know when you need to port the head,from which hp?
subbi7 is offline   Reply With Quote
Old 10-19-2010, 11:38 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
400whp+ usually. What kind of Powerband are you looking at?
Old 10-19-2010, 07:41 PM   #3
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
It really depends on what your goals are for the car.
There are a lot of drag subarus that are running unported heads and making monster power. See the problem with porting is that if you take too much material out you can easily crack a head.
I am currently porting my STI heads and took my old ones and cut them up into vertical slices. This way, you can see how far you can port safely without overdoing it.
If you decide to go with nice cams, a port n polish would be a nice but not necessary. If you are reving high, id port the hell out of em!
mtcs is offline   Reply With Quote
Basic head porting/5 angle valve job. Gains? Defiant Autospeed Built Motor Discussion 72 08-13-2014 10:48 AM
N/A SOHC Cylinder Heads - Ported/Polished/Valve Job/Backcut/Delta Cams SOLUTION Engine/Power/Exhaust 11 12-04-2006 01:03 PM
Take a look at my port job on a test head.. bonzai Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 43 11-28-2005 06:29 PM
IL: Gruppe-s header, TXS TBE, APS UP, Axis Stg 4, Ported heads, Ported TB, Manifold BLUETURBOWRX Private 'For Sale' Classifieds 20 03-06-2005 06:19 PM
IL:Gruppe-s Header,TXS TB,APS UP,Axis Stg 4, Ported heads,Ported TB,Manifolds & more. BLUETURBOWRX Mid West Subaru Owners Club Forum -- MWSOC 14 02-23-2005 09:47 PM
