Old 10-14-2010, 03:58 PM   #1
llamsn
Member#: 201554
2to6 WRX Wagon
Default Help with Center Diff Transfer Drive Gear Bearing R&R
For pictoral directions on how to get to the center diff bearings, jump to page 3. However, there is other good info on both pages 1 & 2 that will probably answer most relevant questions.
My center differential bearings started whirring recently, so I'm in the middle of replacing the group.
I've removed the bearing that sits on the center diff (#28) & the one that fits on the end of the transfer driven gear (#24).
I'm looking at renting a ball bearing tool tonight to remove the spline side bearing (#26) on the transfer driven gear. I'm also going to purchase an appropriate hex wrench and snap ring pliers to remove the bearing mounted in the tail shaft (like #32).
The tech manual calls for a specific bearing installation tool that resembles an over-sized impact socket to replace the bearing on the transfer drive gear, which runs ~$200 from what I can find. I also don't have a press.
Any suggestions on how I can replace bearings 24, 26, and 28 at home?
I have a couple of ideas, but I would like to hear suggestions for the do-it-yourselfer!
I've searched nasioc and multiple other Subaru forums looking for a diy answer to no avail, so any helpful advice would be appreciated!
For Reference:
Similar to a WRX 5MT
llamsn is offline   Reply With Quote
Old 10-14-2010, 07:02 PM   #2
04stigeorge
Member#: 177402
05 STI and 08WRx
blue and white
Never replaced them without a press...wouldn't it be easier to have a local shop with press do the job?..It shouldn't cost much. As far as the special tools Subaru calls installer etc...just find something the size of the inner race that isn't going to break....now that I think of it even if you used a puller you can't beat the bearing back on....well good luck.
04stigeorge is offline   Reply With Quote
Old 10-14-2010, 09:10 PM   #3
MARKSTIV8
Member#: 206393
2008 STI
BLUE
Oh man, It would be awesome if you would make some pictures as this is exactly what I'm preparing to do in my tranny.
As for the tool, if you have a garage, Harbor Freight has some cheap hydraulic presses, that would probably help you a lot. If not then you have to find a local shop who can do that for cheap.
May I know what were the symptoms, when it would whine and such?
MARKSTIV8 is offline   Reply With Quote
Old 10-15-2010, 12:44 AM   #4
llamsn
Member#: 201554
2to6 WRX Wagon
04stigeorge,
After I pulled the pieces from my car, I brought the tail shaft section, the center diff, and the transfer driven gear in my back pack to take home (the garage I have is a couple of miles from my residence). I stopped at a transmission shop on the way home explained and showed them exactly what needed to be done. They figured roughly about 2 hours labor to remove and replace the bearings. That equivocates to about $130. It only took me about 25 minutes (with breaks) to remove 2 of the bearings with a hammer and a punch. I should mention that this is my first time doing something like removing a pressed bearing from a drive train piece.
I did just speak with a local Subie Tech and he said that their press isn't worth while, so they service all of their center diffs using hand tools. I was absent minded enough that I forgot to ask him what they use to replace the bearings. I'll be stopping by there tomorrow to pick up my parts, so I'll ask for advice on how to replace them.
MARKSTIV8,
I've been taking pics of the process. I looked around a few different forums and haven't found a great write-up on all of the steps to fully get to and repair the center diff bearings while the transmission is still on the car(however, n2x4 @ subaruforester.org did a fantastic job w/ the tranny out of the vehicle!). I'm considering adding some info to help others.
As for diagnosis, I found a lot of good info in the forums! A key point to remember: no matter what gear your in, independent of whether or not the clutch is depressed, and from no influence of your rpm that damaged/deteriorating bearings will make a noise if the car is moving and only if it is moving. If the sound goes away if you change the aforementioned, then you need to look somewhere else.
On a 2000 mile road trip, I started hearing a faint whining in the last quarter driving at highway speeds. Naturally, the noise increased the further I drove with it. The whining transformed to a whirring by the time I reached home (just so you know, I had read about the sound in the forums months prior while searching for something else, so I had a decent idea of what it was). When I got back, I let the car sit for a few days and then drove it around my neighborhood to re-diagnose/confirm my suspicions. The sound was even apparent at 10+ mph. I let the car coast to a stop and I could actually hear lightly what sounded like bad bicycle crank bearings (almost like marbles shifting) at < 5mph. My visual and aural inspection confirmed the marble shifting noise after I tore the pieces out of the case.
Here are a couple of links I used for diagnosis and guidance.
http://forums.nasioc.com/forums/show...ential+bearing
http://forums.nasioc.com/forums/show....php?t=1147847
http://forums.nasioc.com/forums/show....php?t=1170285
Center diff removal instructions with pics
http://www.subaruforester.org/vbulle...ce-them-46979/
The forester diff is very similar to the wrx diff.
I'll post more comprehensive info later when I get a moment.
Old 10-15-2010, 09:39 AM   #5
klinebau
Member#: 122383
2006 WRX Wagon
My transmission has started to make some noise also. I've been thinking that it might be the transfer gear bearings, although I haven't completed my diagnoses yet. I have been looking into how to replace these and there isn't that much DIY information available even though it appears to be a fairly common problem. Have you inspected the old bearings and is the damage visble? Which ones went bad? Let us know how you solve the problem.
klinebau is offline   Reply With Quote
Old 10-15-2010, 11:27 AM   #6
llamsn
Member#: 201554
2to6 WRX Wagon
klinebau
After searching through forums and then speaking with a both a Subie tech and gear shop, I'm under the impression that this is basically a maintenance part with a 5MT. The bearing set is something that you change every so often like one would a timing belt. I had my transmission rebuilt in January of 2009 and the bearings were replaced during the rebuild. I put about 63,000 miles on the car since then. It might just be the nature of the beast.
The damage was immediately obvious when I saw that the rollers were deteriorated specifically in the spline side roller-bearing. The outer race also stayed in the tail housing when I pulled the transfer driven gear (tdg). The smaller roller bearing on the transmission side doesn't really show any wear on the rollers, but the outer race stayed in the transmission housing as well.
The bearing that slides around the collar of the center differential seemed very tight and within tolerances, but I'm going to install a new one as preventative maintenance. I really don't want to do this again in 15,000 miles!
I have yet to get to the bearing in the tail shaft. I'm going to work on it this morning and I'll post info later.
Look at the roller deterioration. Many of the rollers are similar. The surface resembles a potholed road.
Old 10-15-2010, 12:01 PM   #7
klinebau
Member#: 122383
2006 WRX Wagon
That certainly looks worn out. I guess you will have to cut the outer races somehow to remove them. Thanks for the picture. I will probably need to do this as I have about 64,000 miles on mine.
Old 12-06-2012, 08:15 PM   #8
no694terry
Member#: 220816
98 Forester S/t
heart breaker
Originally Posted by llamsn View Post
04stigeorge,
.... I stopped at a transmission shop on the way home explained and showed them exactly what needed to be done. They figured roughly about 2 hours labor to remove and replace the bearings. That equivocates to about $130..... .
Yikes, you can buy your own harbor freight shop press for less than that
no694terry is offline   Reply With Quote
Old 12-08-2012, 06:56 PM   #9
llamsn
Member#: 201554
2to6 WRX Wagon
Yes, and actually you can get them cheaper than that new. However, it depends on where you live. I actually did this in an industrial zoned storage garage in Charlotte, NC (meaning I could work on my vehicle). The place I lived, on the other hand, frowned on opening a hood in the parking area. Per the lease agreement, working on one's vehicle was not allowed. I've moved a lot in the last 5 years and I've lived in areas that have private parking or garages that don't allow renters to work on vehicles. It was also not in my best interest to run around and purchase a press that I'd later sell/give away/or take to the loft. It depends on one's situation and what accessibility you have. If I had a chunk of country property, I would definitely own a lift, pneumatic tools, and a lot of other toys with a large garage!
Old 12-15-2012, 07:43 PM   #10
diesel87
Member#: 337899
Default Part #s
Here are the part numbers i have for my 05 LGT (same as wrx, I think) which of these needs to be updated to the superseded (redesigned) numbers?
The tech on the phone said something about the 806322050 changes to 080.
Is that right? Any others?
any help would be great.
Item Detail Part# Qty Price Total
BALL BEARING
Make: Subaru 806230170 1 $26.22 $26.22
BALL BRG 55X80X13
Make: Subaru 806255010 1 $30.68 $30.68
ROLLER BEARING
Make: Subaru 806330110 1 $18.68 $18.68
ROLLER BEARING
Make: Subaru 806322050 1 $28.02 $28.02
OIL SEAL
Make: Subaru 806735210 1 $5.76 $5.76
diesel87 is offline   Reply With Quote
Old 10-15-2010, 04:28 PM   #11
MARKSTIV8
Member#: 206393
2008 STI
BLUE
Thanks for pictures ,this thread could be a nice DIY!
Old 10-15-2010, 06:42 PM   #12
04stigeorge
Member#: 177402
05 STI and 08WRx
blue and white
The price the shop wants is crazy. I don't blame you for going at it.
I could re and re both bearings on my press in under 20 minutes...
I know of some rally guys who have come up with some inovative stuff to work out in the field. Not uncommon is using a bottle jack and welding up some think gauge metal frame around it, using hardened threaded rod to adjust the hight.
Old 10-15-2010, 07:27 PM   #13
ragejed
Member#: 76817
2005 WRX
This is great! im pretty sure I have the same problem and plan to tackle it in the next weekend or two. Do you have more pictures? I <3 pictures.
Can you get to this withOUT dropping the tranny? I really dont feel like going through that if I dont have to.
How did you know which bearings to get (part numbers)? Did you just go to a local subaru dealer and tell them what you needed? Total cost?
ragejed is offline   Reply With Quote
Old 10-15-2010, 08:15 PM   #14
llamsn
Member#: 201554
2to6 WRX Wagon
I may make this a complete diy by the time I'm done! I'm taking plenty of pics and notes.
The links in the post above contain videos, part numbers, and ideas on diagnoses.
The four bearings with part numbers are in the pic:
Total price < $125.
Old 10-15-2010, 08:18 PM   #15
llamsn
Member#: 201554
2to6 WRX Wagon
ragejed,
The rest of the transmission is still in the car. The tail shaft part of the housing/extension comes out, but the rest of it stays.
I'm occupied for the weekend, so I probably won't install the new parts until Monday.
04stigeorge,
I've spent about a half hour using a punch and hammer removing 2 of the bearings. It's time consuming, but works if you don't have a press. The Subaru tech I spoke with told me that their press is a piece, so they use hand tools for the bearings as well. What I forgot to ask him is how he removes the spline side bearing! He won't be back until Monday morning. I guess I'm already repeating myself!
Old 10-16-2010, 11:52 AM   #16
ragejed
Member#: 76817
2005 WRX
llamsn,
I know your busy this weekend, but your saying that you didnt use a shop press at all? If thats the case, GREAT! I wont need to buy one.
Was there a gasket on the tail section of the case? or just liquid gasket?
Old 10-17-2010, 09:05 PM   #17
klinebau
Member#: 122383
2006 WRX Wagon
I was under my car this weekend to fix the boot on the front CVs, so I had a chance to eliminate other possible causes of my noise. It is definitely not related to the accessories as I pulled off the belts and rotated each pulley. The noise is definitely in the transmission and is the loudest when in 4th or 5th gear. There is still a noise when I pull it out of gear, but not as loud. I might have else going on, but I will still probably pull out the tail section and have a look.
Old 10-18-2010, 10:09 PM   #18
llamsn
Member#: 201554
2to6 WRX Wagon
I ended up paying a shop to remove the other 2 bearings and replace all four. I don't have a press nor do I have place to put one. I did get them back tonight. I'll put everything back together tomorrow.
My transmission was rebuilt a year and a half ago. I had silicone between the seam of the tail shaft and the transmission. The local Subaru parts department also told me that it was silicone when I stopped by and asked for a gasket.
klinebau,
If you search the links I posted earlier, you can listen to a couple of videos that are representative of bad bearings.
Old 10-19-2010, 05:46 PM   #19
ragejed
Member#: 76817
2005 WRX
pictures picture pictures! please and thank you
Old 10-19-2010, 08:27 PM   #20
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
if you paid to much too press in which a harbor freight press is just 120 bucks 12 ton I think and enough for a small space pictures also subscribed
EROCS04SBRUSTI is offline   Reply With Quote
Old 10-20-2010, 09:45 AM   #21
klinebau
Member#: 122383
2006 WRX Wagon
If you just replace the bearings, do you need to worry about re-measuring and setting the pre-load or can you just use the existing shims?
Old 10-21-2010, 08:40 PM   #22
ragejed
Member#: 76817
2005 WRX
+1 for this. I would also like to know.
Old 10-20-2010, 10:17 PM   #23
ohemgeeitsNiko
Member#: 239620
2003 WRX Wagon
did your dealership have these bearings and gaskets in stock? or did you have to order them ahead of time?
ohemgeeitsNiko is offline   Reply With Quote
Old 10-22-2010, 07:16 AM   #24
Storm
Member#: 5218
96L Most Over-
Developed Beater
Typically, the bearings have the same dimensions, down to a couple thou. 99.9% of the time, if you stay with OEM bearings and don't change the shafts, the shim requirement will remain the same.
Jay
Old 10-22-2010, 08:35 AM   #25
klinebau
Member#: 122383
2006 WRX Wagon
^^^ That makes sense. In another thread it was suggested that even if you change the gears/shaft, the shim requirements will remain the same and that the variability is due to differences in the case.
One last questioin I have is how to remove the outer races from the transfer case and extension case. How difficult is this to do and what tools would be necessary?
NEED: Center Diff/Transfer Case MyRuRex Private 'Wanted' Classifieds 8 08-26-2015 08:22 PM
WTB: center diff / transfer case for my 98 2.5RS MR2fanatic Private 'Wanted' Classifieds 1 10-01-2009 12:52 AM
FS: IN: 04 STi 6 Speed With Center Diff And Rear Diff STiGuy46554 Drivetrain 5 09-20-2008 12:10 PM
For sale 02 WRX tranny case,center diff and drive gears felixwankel88 Drivetrain 2 06-06-2007 06:22 PM
Bearing preload for center diff transfer gears. 340Duster Transmission (AT/MT) & Driveline 2 05-21-2007 04:24 PM
