Old 06-28-2002, 03:11 PM   #1
Tim Smith
Member#: 19147
2002 Impreza RS
Alpine White
Lightbulb Low cost 4 psi of boost....
I want 4 psi of boost on my 2.5 RS and I want it cheap (like a couple hundred cheap). Is this too much to ask? I also want about 60,000 acres of prime woodland. Which is more likely to happen first?
Tim Smith is offline   Reply With Quote
Old 06-28-2002, 04:01 PM   #2
Tim Smith
Member#: 19147
2002 Impreza RS
Alpine White
bump:
Not even a smart comment from the 15 views.
Old 06-28-2002, 04:13 PM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I think people were waiting for me to slap you down.....
FAQ and Threads of Note- Read me first!
kastle is offline   Reply With Quote
Old 06-28-2002, 04:30 PM   #4
moogooob
Member#: 15764
00RS -Dumb all over
A little ugly on the side
There it is... I was waiting for that.
moogooob is offline   Reply With Quote
Old 06-28-2002, 04:57 PM   #5
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
IB...nevermind.
wcbjr is offline   Reply With Quote
Old 06-28-2002, 05:13 PM   #6
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
4 psi on a couple hundred bucks? Not going to happen! I'm just starting on a low-pressure turbo kit for my RS, and so far, I've gotten good deals on the two parts I've bought, the turbo and a RRFPR. And I'm already at $300, and I still need a proECM, up/down pipes, external wastegate, intake, charge pipe, and an intercooler. The only cheap pressure you can get is from that e-Ram, the fan thing for the intake, and that only makes maybe 0.5 psi, if your lucky, and probably not even that. And that runs about $300. You want real boost, you're looking at at least $1500 if you can find deals on the parts.
HondaH8er is offline   Reply With Quote
Old 06-28-2002, 06:36 PM   #7
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
there is always nitrous
ac_gohan is offline   Reply With Quote
Old 06-28-2002, 06:59 PM   #8
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
well, if you wanna think of thousands in the hundreds..then how about it'll cost you about fifteen hundred bucks for a low boost turbo??
-vic
cRayZee is offline   Reply With Quote
Old 06-28-2002, 07:36 PM   #9
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
i was thinking the same thing...28 is a couple to some people...so 28 hundred dollar bills........damnnnnnnnnnnn
akcel is offline   Reply With Quote
Old 07-01-2002, 10:44 AM   #10
Tim Smith
Member#: 19147
2002 Impreza RS
Alpine White
Just to stand up for myself. I have read all of the facts in all of the forums on I-club.
I just haven't read one that only cost a couple hundred dollars. That is why I asked. So.....not going to happen.
Thanks for the replies anyways.
Old 07-01-2002, 11:39 AM   #11
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I suppose you could buy a bunch of hamsters to run in some kinf of turbine wheel for a couple hundred dollars. Not sure if they could provide 4psi of boost though.
8Complex is offline   Reply With Quote
Old 07-01-2002, 02:18 PM   #12
Tim Smith
Member#: 19147
2002 Impreza RS
Alpine White
Yeah, but it would cost a lot to feed them. Plus, my friend with a civic said that it doesn't work all that well. But he definately felt an improvement over stock.
Old 07-02-2002, 12:08 AM   #13
bensonwrx
Member#: 6904
AWD R35, XE30, V37
BO, AS, MW
I may have an almost-complete turbo kit that I will sell for couple hundred bucks though It works especially on a non-hoodscoop Impreza. That is, if my friend doesn't want it first.
Good luck finding another one.
-Benson (Another MY98 Owner)
bensonwrx is offline   Reply With Quote
Old 07-02-2002, 03:45 PM   #14
Gonthrax
Member#: 18925
Heres an Idea, find a VG30 turbo from a Zed. You should be able to get the custom work fabbed for a few hundred, turbo will be very cheap if you don't buy it in the states. This is a very common thing to do with non turbo skylines, most of them only run 7-9psi from these turbos before they either highflow them or start replacing wheels.
Not sure if this is more then you want to spend but it's a pretty cheap idea.
If you are worried about the spool time on the VG turbos, look around for a T28 off of an RB20DET. If you get one off of an R33 you will get ceramic blades aswell The little snails off of a Vr-4 is an option aswell. The only problem with these plans is finding a guy that does cheap fab work.
Gonthrax is offline   Reply With Quote
Old 07-02-2002, 04:48 PM   #15
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Talking
Go down to Target, WalMart, KMart, etc. get the following:
1) Biggest Hair dryer you can find.
2) CB radio with PA capabilities
Then drive over to Home Depot for:
3) Dryer hose
4) Silver spray paint
then off to Krispy Kreme for:
5) One dozen glazed donuts (just really need box)
After that drive home to do "turbo" kit install. Follow these easy steps for your new "forced induction " kit.
1) Paint KK box (TMIC) and hair dryer (turbo) silver. Let parts thoroughly dry. You could detail the parts with your favourite manufacturer logos or other "details" to make it more realistic.
2) Install "turbo" right around where a real turbo would go.
3) Mount "TMIC" in position.
4) *This is the hard part* - Wiring the CB unit with the PA under the bonnet right around where the BOV would go.
5) Connect all important areas with dryer hose to make it look "legit."
6) Take your new turbo out for a "drive" making "pssssssht" noises when you shift or rev up.
Best part of this kit...you can make it sound like a VTEC turbo or a true boxer turbo or your favourite WRC car. It's a very felxible kit in terms of "style."
-mykr.
mykrrrr is offline   Reply With Quote
Old 07-03-2002, 09:37 AM   #16
Tim Smith
Member#: 19147
2002 Impreza RS
Alpine White
That is about the most creative thing I have ever read.
You must have had KK donuts for breakfast.
Great idea except for the fact that it would not contribute at all to the power. Unless of course I had a Blowtech stick put in the back window. Then I would have to get tires every two weeks.
stoc sti with boost 28 psi of boost?!!!!! Mohammadov Newbies & FAQs 5 08-26-2007 10:42 AM
Wanna know what 32 PSI of boost @ 9000 RPM sounds like? zzyzx Off-Topic 36 12-15-2005 08:22 AM
What % of hp increase per psi of boost? reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 4 12-16-2004 03:02 AM
Stage 4 and 8 psi of boost SuperHawk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 06-25-2002 12:20 PM
How much HP do you get from 1 PSI of boost? Scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 07-31-2001 12:18 PM
