Old 11-17-2010, 09:39 AM   #1
Fahrenheit
Member#: 262306
2011 WRX 5-Door SWP
Default Rota Torque R's
So I was looking through the Member's Gallery and noticed that some people have the Rota Torque R's, which look real good in my opinion. Does Rota still make these, I checked online and it looks like they are only selling the Rota Torques.
Fahrenheit is offline   Reply With Quote
Old 11-17-2010, 10:14 AM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
they're still there on wheeldude's site: 17x9 +30
http://www.wheeldude.com/catalog/pro...oducts_id=5759
nhat is offline   Reply With Quote
Old 11-17-2010, 11:00 AM   #3
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
If you are already buying a cheap knock-off, might as well get the Drag dr-31. They are a lot less and have a better offset. I bought a set for winter wheels and thought they looked good enough for my summer also. They just are a bit to heavy for track wheels. Here's mine in a 17x9 +38 powdercoated flat bronze with a 255/40/17.
aclver1 is offline   Reply With Quote
Old 11-17-2010, 11:43 AM   #4
sc00by4life
Member#: 97135
work > rota > drag. for an extra few hundred $$, I'd probably want a more reputable brand than the Drag's. Rota is probably the cheapest wheel you should consider.
Old 11-17-2010, 12:03 PM   #5
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
I've had no issues and for $400 new they are almost half price of the Rota's.
Old 11-17-2010, 02:07 PM   #6
Nakioki
Member#: 124924
I had both... I'd consider Rota > Drag. Done.
Nakioki is offline   Reply With Quote
Old 11-17-2010, 06:33 PM   #7
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
haha, I've had both also and thought the Rota's looked terrible. My Rota's were the P45R and they just looked like cheap wheels and had color variations and rough spots on them. Plus i have never seen a thread about broken Drags and I've see a million about Rota's. If you are thinking about buying a set of $850 Rota's you might as well spend $150 more and get some used Works kai's. The only reason i got the drags was I had to sell all my wheels when i did the 5x114 conversion so these were dual drilled and came in the right size and offset for my snow tires. After having them for the winter i decided to get some for summer and then just get something else for track wheels. For $400 a set new i figured i could get 2 set's for less then the Rota's and still get them custom powder coated a flat bronze with Flake that matches the Java black in my car.
Old 11-17-2010, 04:06 PM   #8
sc00by4life
Member#: 97135
The one thing I do like about the drag's is that its a more true-to original replica. Although I still preffered the concave of the torque R. Its listed on most websites as just the "Torque" but generally all of the 9"+ are the "R" models.
Wheel dude has them in (though in limited colors these days) in 17x9 +30, 18x9.5 +30/35, and a few other's.
Old 11-17-2010, 04:48 PM   #9
Fahrenheit
Member#: 262306
2011 WRX 5-Door SWP
Thanks for all the info guys. I am thinking about either the
Drag DR-31 (Gunmetal) in 17x9 +38 with a 255/40/17
Rota Torque (Gunmetal) in 17x9 +30 with a 255/40/17
This setup on a 2011 WRX w/ stock supension would be a perfect fit with no rubbing right? From what I have read it seems like the Drags would have a much closer to stock offset. Is that correct?
Old 11-17-2010, 06:37 PM   #10
sc00by4life
Member#: 97135
Oh.....there will be rubbing with that set up. Low offsets aren't very friendly to stock suspension either (and looks....odd). You'll probably need to roll all around but if you are comfortable with it, go for it.
Old 11-17-2010, 10:04 PM   #11
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
With the new wide body on the wrx i would bet they will fit but it's always good to make sure. The stock wheels are a 17x8 +53 so a 17x9 +38 will be farther away from the strut but will stick out 1" farther than the stock wheels so you will need to make sure that isn't too much. I don't think it would be with stock suspension height but better make sure.
Here is a good tool for finding good wheel and tire combo's.
http://www.rimsntires.com/rt_specs.jsp
My New Rota Torque R's 17x9 +30 FRSB! JDM555 Member's Car Gallery 129 05-03-2010 03:46 AM
socal FS- Rota Torque R's 18x9.5(5x100) anthonyfur Wheels/Tires 13 10-11-2008 04:36 AM
FEELER FT- Rota Torque R's 18x9.5!!! anthonyfur SCIC Private Classifieds 53 09-25-2008 01:47 PM
socal (FEELER FT)- Rota Torque R's 18x9.5 anthonyfur Wheels/Tires 18 08-27-2008 03:13 PM
FS: ROTA TORQUE R's 5x100 17x9 +30 so steezy Wheels/Tires 20 07-28-2008 10:40 AM
