Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 12-16-2010, 04:12 PM   #1
vutony
Member#: 176991
OMGHi2U Does this sound like piston slapping? URGENT plz help!
HI, I have this very loud noise from my motor. I searched and some previous threads say it can be piston slapping or broken timing belt tensioner. Therefore, I removed the covers in hope it was only the tensioner but I dont think it is. Please let me know what you guys think. I need this car running smoothly.
Here is my video clip.
Two other videos I found with good and bad tensioners.
vutony is offline   Reply With Quote
Old 12-16-2010, 04:33 PM   #2
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Definitely not your tensioner, it is pretty solid in the video. Unfortunately, it sounds like you threw a rod or spun a bearing. Take off the oil pan and see if you can wiggle any of the rods around.
Jessekrs123 is offline   Reply With Quote
Old 12-17-2010, 11:04 AM   #3
02scoob08
Member#: 266119
2002 Wrx
white
Just went through this problem with mine. Come to find out it was my lower gear next to the water pump. The bearing inside the gear just exploded and caused slack in the timing belt. And yours sounds about like mine. It caused the tensioner to move more than normal make sure all bearings are inside of the gears. That's just my suggestion. Hope you get her fixed.
02scoob08 is offline   Reply With Quote
Old 12-18-2010, 08:39 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
sounds a lot like rod knock to me too. drain/flush the oil and check what you see in it.
Does this sound like a hosed piston to you guys? serendipity Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 69 11-05-2007 11:36 PM
Does this sound like a piston prob?? OMEGA SUPREME Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 07-24-2006 07:45 PM
Does this sound like an alright system? ImprezedRS Car Audio, Video & Security 3 01-14-2002 03:52 PM
Does this sound like a good idea??? SomeoneStoleMyName General Community 33 12-09-2001 07:44 PM
Help Me:- Does this sound like a normal Canadian Address? MY99 2.5GT Canada Region Forum 11 07-16-2001 11:50 AM
