Old 01-07-2011, 04:59 PM   #1
31motors
Member#: 198830
Default timing belt install with no marks
I had my helper take the motor apart and he did not mark the belt to reinstall. I want to make sure its on correct so what do I do?
31motors is offline   Reply With Quote
Old 01-07-2011, 05:07 PM   #2
JoshP
Member#: 94350
what car? You can count teeth and mark them yourself. I know the 1.8 is 44 teeth and 40.5. from left to crank then to right cam, I believe 2.2 is the same.
JoshP is offline   Reply With Quote
Old 01-07-2011, 05:14 PM   #3
31motors
Member#: 198830
its a single cam 2.5 98 legacy. Thats what I was hoping for do you think those #s are the same?
Old 01-07-2011, 07:02 PM   #4
PaulieKeyboard
Member#: 268990
What 98 2.5 was a single cam? I thought that they were all DOHC setups until the 3 or 4th gens....
PaulieKeyboard is offline   Reply With Quote
Old 01-07-2011, 07:54 PM   #5
31motors
Member#: 198830
It was a 96 sorry. I got it figured out runs good. Thanks for the help.
Old 01-07-2011, 07:54 PM   #6
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
If it's single cam, it's 2.2 liters.
How old is the belt? Unless it's practically new, I'd go ahead and replace it. They're quite cheap.
BAN SUVS is offline   Reply With Quote
hyperco springs with no markings? nhat Brakes, Steering & Suspension 9 09-23-2012 08:04 AM
Help! Timing Belt Install, stuck on the... you know, install RS-Flyboy Normally Aspirated Powertrain 11 07-09-2009 01:03 PM
Timing belt install?? AK'S REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-15-2004 12:18 PM
Timing belt installation for a PE belt? IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-27-2003 03:45 PM
02 WRX timing belt install after crash cky211 Service & Maintenance 1 12-28-2002 11:25 PM
