Old 01-12-2011, 02:14 AM   #1
auslyle
Member#: 129737
04 Sweet Impreza
Default So found out what made my car sounds like two squirrels fighting in my engine bay
so I decided to rip down my block today and what I found was just what I thought I would find. Spun bearing... Bummer deal. so I guess I'll send the crank in to be machined down, Order some some new ACL bearings once we find out how much material needs to be removed to get it back smooth. get the block hot dipped and cleaned up. new seals, piston rings and put it all back together should be like new again.
not really supposed to look like this.
auslyle is offline   Reply With Quote
Old 01-12-2011, 02:20 AM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Wow, you did an even better job on yours than I did on mine!
I mean, we're supposed to use those bearings up to get our money's worth, right?
Old 01-12-2011, 02:43 AM   #3
auslyle
Member#: 129737
04 Sweet Impreza
ohhh yeah you know it! see most people when they hear their car knocking they shut it off well me... just turned up the music haha. I have a system for a reason
Old 01-12-2011, 02:45 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Heh, I didn't recognize the sound at first, so I proceeded to drive the car at WOT for another 10 minutes after it first started. Oops. Nothing like 7000RPM with a 280F oil temp on 4 spun bearings...
Old 01-12-2011, 02:49 AM   #5
auslyle
Member#: 129737
04 Sweet Impreza
damn thats way worse than mine.... the bad thing is this is the third motor ive done this to. so im open to suggestions haha
Old 01-12-2011, 02:58 AM   #6
Seventh
Member#: 263223
2011 WRX 5dr
SWP, 332ti
The questions everybody is dying to ask are... How long do you warm it up in the morning? and What kind of oil do you use? Edit: My apologies tho man that sucks!
Seventh is offline   Reply With Quote
Old 01-12-2011, 03:05 AM   #7
auslyle
Member#: 129737
04 Sweet Impreza
I take it easy on it till it gets up to operating temp.... but I do drive it like i stole it often haha this motor that the pictures are from happened at the beach drifting driftwood. Castrol full synthetic
Old 01-12-2011, 03:01 AM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Well, how long isn't the right question about warming it up.
The ideal warm up is to let it idle for 30 seconds or so, blip the throttle to about 50% of redline twice or so, then drive it gently while keeping it under 3kRPM until the oil temp goes over 180F.
Just sitting and letting it idle for any long length of time is bad for the oil and engine.
Old 01-12-2011, 09:34 AM   #9
GEE-OTTO
Member#: 201277
2008 Legacy
This^^
GEE-OTTO is offline   Reply With Quote
Old 01-12-2011, 11:25 AM   #10
renob123
Member#: 41986
'06 STI/'85 Brat
Damn, I didn't know that. When are you going to make a williaty FAQ with all of this stuff that I didn't know/even know to ask? Of course, I guess it wouldn't be a FAQ, more like a Should Be Frequently Asked Questions But Nobody Knows to Ask, or SBFAQBNKA.
Jacob
renob123 is offline   Reply With Quote
Old 01-12-2011, 01:35 PM   #11
superhero
Member#: 32153
2006 300C
crappy blue
Question
I heard similar advice from my cousin who is a total motorhead... know what the general theory behind it is??
superhero is offline   Reply With Quote
Old 01-12-2011, 03:07 AM   #12
Seventh
Member#: 263223
2011 WRX 5dr
SWP, 332ti
Have you replaced the bottom end ever or you just keep rebuilding the same one?
Old 01-12-2011, 03:09 AM   #13
auslyle
Member#: 129737
04 Sweet Impreza
this was the motor before this one
Last edited by auslyle; 01-12-2011 at 03:27 AM. Reason: added the picture of the head
Old 01-12-2011, 03:10 AM   #14
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
So a hone and you rebuilt it, right?
To be serious, though, why does that block have so much rust in it?
Old 01-12-2011, 03:13 AM   #15
auslyle
Member#: 129737
04 Sweet Impreza
the rust is from the coolant sitting in it and not taking it apart right away.
Old 01-12-2011, 03:10 AM   #16
auslyle
Member#: 129737
04 Sweet Impreza
I have had a new block in it every time, ive even had a built high reving na.... that was fun
Old 01-12-2011, 03:17 AM   #17
auslyle
Member#: 129737
04 Sweet Impreza
the block i took apart to day though seems to be just fine, needs cleaned up and what not but it still has the honing marks on the cylinder walls.
Old 01-12-2011, 09:27 AM   #18
watchdoc
Member#: 104821
2002 2.5 RS
So what do you think is killing your motors? low oil? cavitation? bearing starved from high g loads?
Did you upgrade your oil pump on any of these engines?
watchdoc is offline   Reply With Quote
Old 01-12-2011, 01:21 PM   #19
auslyle
Member#: 129737
04 Sweet Impreza
its oil starvation for sure, this motor had just hand a RS oil pump on it, but ones before have been sti oil pumps
Old 01-12-2011, 01:31 PM   #20
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Unless you were running substantially larger than stock bearing clearances and you had an oil pressure gauge showing you that you were making less than 10psi/1kRPM, it wasn't the oil pump's fault.
The 7mm oil pump will make 20psi/1kRPM on stock bearing clearances. That's more than enough flow.
Old 01-12-2011, 02:00 PM   #21
auslyle
Member#: 129737
04 Sweet Impreza
this is true, but at high RPM's drifting drift wood for 15 min non stop might have had something do to with it. oil sloshing to one side of the block, maybe not getting back to the bottom of the pan fast enough... idk. it was brad new oil as of 200 miles before this happened.
Old 01-12-2011, 02:04 PM   #22
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yeah, oil starvation from g-loading is MUCH more likely than the pump not being large enough. From what you describe doing, you need a dry-sump setup.
Old 01-12-2011, 09:36 AM   #23
GEE-OTTO
Member#: 201277
2008 Legacy
Man you should consider a new crank
Old 01-12-2011, 01:22 PM   #24
auslyle
Member#: 129737
04 Sweet Impreza
looking into it but might just have this one machined, knifed and blueprinted
Old 01-12-2011, 10:46 AM   #25
M-dub39
Member#: 210599
2008 AW Sti
I agree cranks are cheap and then you know it is right also easier to get it all perfect again too.. just put in and go.
M-dub39 is offline   Reply With Quote
ZOMG How do I make my car sound like the X Games carz!!11 No, we dont know what bov. Davenow Newbies & FAQs 28 08-01-2010 09:50 PM
What my car sounds like DLC Legacy Forum 38 06-20-2007 08:05 PM
My car sounds like in reverse gear but when moving forward sonicowrx03 Transmission (AT/MT) & Driveline 4 06-20-2004 12:22 AM
Why does my car sound like my mom's car? wlchan Factory 2.0L Turbo Powertrain 18 11-27-2003 01:14 AM
Sounds of moving rocks/pebbles in the engine bay? DVN428 Service & Maintenance 1 11-02-2003 03:01 PM
Message Board Statistics All times are GMT -4. The time now is 09:18 PM.
