Old 01-18-2011, 10:22 AM   #1
d3v0
Member#: 225692
2015 WRX
Default Advice on how to craft a functional/aerodynamic scoop delete
Since I have a FMIC I have decided to get rid of the drag-creating scoop that no longer functions on my vehicle. I have considered a few options:
1) KS-tech mesh delete and Louvre plate
http://www.kstech.biz/servlet/the-WR...ete/Categories
2) WRB stock hood
3) Keeping stock scoop and installing Oil Cooler
4) Custom hood scoop delete which will serve one of two purposes:
a) Aesthetic delete + allows heat to escape
b) Aesthetic and diverts some air to an oil cooler (jury out on the oil cooler as well)
Of course the easiest option is 3, the second best option is 1, but I would prefer to figure out to craft the most functional and aerodynamic scoop delete. I think the stock hood is a bad option, as the scoop creates drag. the impreza base model hood does not allow heat to escape the turbo area. the KS tech is not only expensive but also out of stock.
I have a local guy who will be able to craft something from scratch out of CF and other materials. I would greatly appreciate some help in figuring out how to fabricate a custom delete.
d3v0 is offline   Reply With Quote
Old 01-18-2011, 10:28 AM   #2
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
My vote is to use the scoop as an air intake.
http://forums.nasioc.com/forums/show....php?t=2058032
In all honesty, these car's are not very aerodynamic.
ZeroDrift is offline   Reply With Quote
Old 01-18-2011, 10:31 AM   #3
d3v0
Member#: 225692
2015 WRX
Haha I had thought reverse scoops are bad news
As far as aerodynamics, yeah its a GD so the aero is bad to begin with, but might as well improve where we can. The two tracks the car will be at are higher average speeds so every bit helps.
Old 01-18-2011, 10:36 AM   #4
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
Not sure I follow the 'reverse scoops' bit. I think with some ducting a reverse scoop could be quite effective.
If you don't find another use for the hood scoop a flat plate to delete it is not a bad route. If you can match it to the hood contours, all the better.
Old 01-18-2011, 10:44 AM   #5
d3v0
Member#: 225692
2015 WRX
Was thinking about crafting a mesh/vented scoop delete that would duct the air into an oil cooler, possibly. I will run the CAI through the passenger side fog bezel in the summer most likely.
Checked out your thread, glad to see the GC is holding up in snow and rain with that scoop intake! Nice!
Need advice on how to install gauges on A-pillar maxpower_454 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-06-2005 10:19 AM
Need advice on how to train my dog timo Off-Topic 42 12-31-2004 04:58 PM
Need advice on how to deal with wapce mklier1218 Off-Topic 33 09-22-2004 12:32 PM
advice on how to read A/F guage? 03mbpREX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-09-2003 12:28 PM
