#1 |
Member#: 181314
Vehicle:2005 Impreza OBS SRR 05 Legacy GT RBP |
Questions answered. Please delete thread.
#2 |
Member#: 201277
Vehicle:2008 Legacy OBP |
Well nobody knows yets except TWE as they are still in the process of building the prototype. However they are smart people and performance oriented so im sure they will prouce a unit to address all the gripes amongst the community
#3 | ||
Member#: 93577
Vehicle:98 Impreza |
I've never heard of anyone saying it will. Cost effective depends on you. Coating has its advantages over wrapping though. |
#4 | |
Member#: 165749
South East
Vehicle:2007 No YELLING on the bus! |
#5 |
Member#: 93577
#6 |
Member#: 136688
Vehicle:2005 Impreza RS silver |
I have a 4 into 1 TWE header on my 05 rs (MT) and it used to hit the U-frame on the driver's side until I replaced my engine mounts by hardened STI mounts. No problems since the new mounts are in.
On my 5 speed tranny, the header has to be taken down to flush the transmission oil. No 0420 CEL, and the header's not wrapped nor coated. TWE header & mechanical rear diff = best mods I ever did to the car. DO IT!!!!! |
#7 |
Member#: 181314
Thanks for all of the replies. Your input is appreciated. I updated the original post to be a little more clear on which header my questions are about. Thanks again.
#8 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
Since I ended up with a PM about this:
1) My TWE 4-2-1 HO header, bought in 2010, does not hit the crossmember or power steering lines. Yes, I have the Group N engine mounts. You should have them to. 2) The TWE 4-2-1 header will clear both the 5MT and 4EAT trannies 3) Coating will last longer than wrapping and work pretty well, if done right. The only company doing exhaust coating right is Swaintech. Yes, I've tried JetHot personally. No, it's not as good as Swaintech. The coatings used by cheap pipe makers like Grimmspeed, Import Image, etc isn't worth a damn. Keep in mind that coatings and wrappings work slightly differently. Coating primarily reduces the pipe's ability to radiate. So the surface temperature of the pipe is high but stuff near it, but not touching the pipe, stays much cooler. Wrapping reduces both radiation and conduction. Meaning things can touch the pipe (well, the wrap on the outside of the pipe) with less chance of catching on fire. Wrap does retain more heat overall, but has problems with durability and evenness that coating doesn't have. It's a tradeoff. |
| Thread Tools | |
| Display Modes | |
| twe headers questions | newbiescooby2.5rs | Normally Aspirated Powertrain | 2 | 06-16-2006 04:12 AM |
| Video: TWE Header + TWE Cat Section + Brullen Quiet Catback | Jard | Normally Aspirated Powertrain | 7 | 02-09-2005 11:51 PM |
| TWE Header Question | impr25rs | Normally Aspirated Powertrain | 1 | 10-23-2004 06:23 AM |
| TWE Header owners, I got some questions | 1fastrs | Normally Aspirated Powertrain | 2 | 08-08-2004 02:25 AM |
| The TWE Header question thread | DrBoy01 | Normally Aspirated Powertrain | 30 | 04-12-2003 12:49 AM |
