#1 |
Member#: 140845
Vehicle:02 wrx blue |
I have a 2002 wrx with a subframe that is rusted to point of failure. The car has 144000 miles on it. I called Subaru to complain and they set up to have it inspected. They called to inform me that they will not be replacing the subframe because of the cars age and milage! Is this acceptable? Has anyone else experinced this?
#2 |
Member#: 174651
Vehicle:03 gonna be different next year |
that sucks. sorry to hear it. use POR next time on the new one. ( http://www.por15.com )
#3 |
Member#: 271341
Vehicle:2003 wrx stormtrooper white |
I think it's mostly how you take care of it determines how much the car will rust. I'm getting some on the quarters so I have to take care of it right away (just bought it a couple months ago)
I'm going to check into that por15 |
#4 |
Member#: 174651
Every car I've ever helped restore has used that POR-15. It's like rhino lining that uses moisture to cure. The stuff is frigging unbelieveable!
#5 |
Member#: 174695
Vehicle:1983 antarctic blue super sportswagon |
control arms don't mount to it. engine is not mounted to it. it's failure will not cause a catastrophic accident that will cause the manufacturer to be held liable. that's business. find someone who put all the bracing on their car and buy their stock one from them.
#6 |
Member#: 6423
Vehicle:2002 impreza wrx sed blu..now with big lights |
Sorry to dig up this old post.
ive just noticed that my subframe is rusting out on the passengers side. wondering if there is a thread or link for a "how to" replace. Also is something better left for a dealer to fix i am willing to try it myself ? thanks in advance. 2002 WRX 120,000 miles Paul J. |
#7 |
Member#: 32459
Vehicle:02 WRX VF34 Junior Tuned 301whp |
Very simple - there are about ~10 bolts (don't remember) you have to unbolt in order to remove the sub-frame. Make sure you have a breaker bar.
#8 |
Member#: 284180
South East
Vehicle:1986 BRAT |
I have an '02 WRX 115,000 miles with the same rust on the subframe passenger's side.
the arrow is pointing at the worst point, but further towards the rear is pretty bad too. ![]() I think I'll give Subaru a call too. I'll try to remember to post the outcome. |
#9 |
Member#: 281014
Vehicle:2002 WRX Wagon SOL by SoA |
I have an MY2002 wagon with 69k miles in New Jersey. Bought it new. Gently driven. No rust on the body.
Two weeks ago, I had a control arm snap off. Towed to mechanic, who pointed out the recall, but said the front subframe would also need replacing. Towed to dealer, who summoned the SOA distributor. The distributor states that due to the $5000-7000 (in their estimate) of repairs that would need to be done in order to make the car road-worthy, they will not cover ANYTHING, including the parts covered by the recall. They generously <sic> offered $750 towards the purchase of a new Subaru (Yeah, right). Incredibly, the SAME THING happened to a friend of mine with the same year Impreza in MA. The distributor made all the same statements, including "we've never seen one this bad". I guess every one that comes in must be worse than the last. So they've basically totaled the car on me. Any suggestions? Anyone wanna buy a really nice, great-running drivetrain/body/interior donor car? ![]() |
#10 | |
Member#: 32459
#11 |
Member#: 281014
It gets better than this. We asked the dealer to make an estimate, since the above was given by the distributor. The dealer quoted us $12,000 to make the repair.
I've asked for an itemized list, so we'll see just what this nonsense is about. |
#12 |
Member#: 279243
Vehicle:2006 STi CGM |
I have mine for sale ( sorry for the hijack
#13 |
Member#: 162070
Vehicle:2005 VF48 wrx wagon WRB |
I'll sell you a front subframe if that's where your problem is
#14 |
Member#: 32459
Any update on this?
Apply POR-15 before it's too late... ![]() ![]() |
#15 | |
Member#: 219200
#16 |
Member#: 270358
Vehicle:2002 WRX Wagon Midnight Black Pearl |
Can you drop the sub frame and leave everything else in place, or do other parts need to come out with it? I'm guessing you might have to tie up the rack, etc.
#17 |
Member#: 321762
I just took my car in for the inspection and I have the same issue. Both sides of the front U shaped sub-frame is rusted. You can poke your finger right inside it. I tried to order a new one from Subaru however they said that they are out of stock Nationwide. Has anyone else went through this? Why would they be completely out of stock. I am trying to find one from a salvage yard but having trouble. This is ridiculous!
#18 |
Member#: 7022
Vehicle:2013 BRZ Limited SWP |
While I am a fan of the stock subframe for safety reasons(Front end accident the stock one lets the motor drop out of the body vs. entering the passenger compartment), you guys might want to consider a beatrush or perrin or someother brand subframe. There have been tons of companies that make "performance" subframes for the GDA chassis.
#19 |
Member#: 39169
Vehicle:2005 STi, s2000 Tuned Perfection |
I have 2-3 stock subframes in great shape with no rust that have been sitting around for a while, if anyone needs one, pm me!
#20 |
Member#: 326337
#21 |
Member#: 340859
What are some better choices for replacement? Can't see spending $400 for a replacement from Subaru...
#22 |
Member#: 174651
The best aftermarket replacement I've ever found was for $600 thru Oswald performance. MUCH MUCH STIFFER with more bracing
#23 |
Member#: 174651
And for the record, you can drop a front subframe in your driveway with no jack stands or worries.
#24 |
Member#: 270358
#25 |
Member#: 228016
Vehicle:2003 WRB WRX Clark tuned |
| Thread Tools | |
| Display Modes | |
| Excessive rust on subframe - should I be concerned? | TimStevens | Brakes, Steering & Suspension | 58 | 05-12-2011 10:21 PM |
| WTB/WTT : Wanted 02 to 07 wrx sti front subframe. For jiging a tubing subframe. | TSSFAB | NWIC Private Classifieds | 1 | 09-30-2010 02:13 AM |
| 02 subframe replacement? | Scion | Factory 2.0L Turbo Powertrain | 0 | 01-11-2006 09:54 AM |
| Will 02 subframe fit an 04 WRX | Petrie | Subaru Conversions | 2 | 09-03-2004 12:43 PM |
