Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 02-15-2011, 02:02 AM   #1
Tglazed
Member#: 231216
Default Getting rid of CEL P0519
I just bought a swapped 2000 rs coupe. The only thing that is stopping me from passing inspection is the cel code P0519, it doesnt come up when your scanning the car with just a regular obd 2 scan tool but as soon as it gets plugged in to the emissions computer it pulls this code and stops me from passing. If you have any questions about the car just ask, I just barely bought it so I am still figuring things out about it. Its on utec on a stage 2 map. I need to get rid of this code so I can pass.
Tglazed is offline   Reply With Quote
Old 02-15-2011, 02:03 AM   #2
Tglazed
Member#: 231216
O and I have been told a couple things from people. I was told I need to adjust the idler on the utec with a laptop. Anyone know anything about this?
Old 02-15-2011, 09:18 AM   #3
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I found this, i guess it's as good as any place to start trouble shooting
DTC P0519 - IDLE CONTROL SYSTEM MALFUNCTION (FAIL-SAFE)
DTC DETECTING CONDITION:
Immediately at fault recognition
TROUBLE SYMPTOM:
Engine keeps running at higher revolution than specified idling revolution.
Here are the steps if you want to do the step-by-step inspection yourself before taking it in. If you recently changed your air filter, check your air box and see if it is seated correctly. It can be that easy or adjustment of throttle cable, loose or cracked vacuum lines, cracked gaskets or worst - idle air control solenoid.
1. Check for loose installation of intake manifold - particularly the unit that house the air filter
2. Check for cracks on intake manifold
3. Check for cracks on gasket of throttle body
4. Check for cracks on gasket of idle air control solenoid valve
5. Any vacuum hose disconnected or leaking?
6. Check throttle body cable for excessive play
7. Check the bypass air line for foreign particles that can clogged the system
medamullet is offline   Reply With Quote
Old 02-15-2011, 09:56 AM   #4
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
I would go into your factory ECU and turn off that code just for a temporary fix until you get that problem fixed.
Surprised to see somebody using the UTEC, Didn't know that still existed. Ever thought about ditching it and going open source? It would be a lot easier.
bhhamblin is offline   Reply With Quote
Old 02-15-2011, 11:27 AM   #5
Mush04
Member#: 191705
2007 Limited STi
Swp
Open Source FTW!!!!
Mush04 is offline   Reply With Quote
Old 02-15-2011, 11:50 AM   #6
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
I just got that code on sunday so i've been researching it. I found that it sometimes can be your nutral position sensor freaking out and sending the wrong voltage to the ecu making it think it's in gear or out when it's not so it's trying to adjust the idle. If you have a good scan tool plug it and and move your shifter back and forth but not into gear. The scan tool will show it going in and out of gear even though it's not in gear.
aclver1 is offline   Reply With Quote
Old 02-15-2011, 12:45 PM   #7
Tglazed
Member#: 231216
Well I bought the car with utec. Personally I like open source I had my 06 done by logan. How can I go into my ecu to turn off that code just as a temporary fix? So I can get my car to pass emissions. Its not on when I drive or idle or anything, only when it gets plug into the obd 2 thing for emissions.
Old 02-15-2011, 02:24 PM   #8
subtech02
Member#: 215613
two things! one do you use the trans to slow you down on off ramps or whenever. two its an issue with the nuetral position switch on the side of the trans depending on the components in the swap. delete the code
subtech02 is offline   Reply With Quote
Old 02-15-2011, 02:28 PM   #9
Tglazed
Member#: 231216
Yes I downshift, should I not? How do i delete the code, can someone tell me how or help me do it.
Old 02-15-2011, 02:53 PM   #10
Mush04
Member#: 191705
2007 Limited STi
Swp
I would assume someone with an open source type thing could delete it, but I have been told if you use the motor to slow down it just wears your clutch and everything out quicker, I would rather replace brake pads myself haha but I will say that I still do it from time to time.
Old 02-15-2011, 05:25 PM   #11
Tglazed
Member#: 231216
Anyone close local that could come delete it for me. I could drive to you.
Old 02-15-2011, 05:32 PM   #12
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
are you just trying to delete it or mask the code and keep it from showing up? you can just disconnect your battery to delete it but if there really is a problem it will come back, also that will set all your I/M stuff to NOT READY. Do you have a code reader?
Old 02-16-2011, 02:19 PM   #13
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Did you get yours to pass?
Old 02-15-2011, 05:37 PM   #14
Tglazed
Member#: 231216
Ya I have been borrowing my friends code reader. There was no check engine light though. Also, when you plug in a code reader it will come up clear but the emissions computer pulls the code, thats how I figured out I had it.
Old 02-15-2011, 05:51 PM   #15
Mush04
Member#: 191705
2007 Limited STi
Swp
I couldn't pass for awhile either this last year and I just had Jason "make" it clear haha that's why I love open source haha, do like Brody said and ditch the utec and go OS! but I'm sure there are ways to get yours to pass too GL
Old 02-15-2011, 06:24 PM   #16
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
I didn't think a pending code would keep you from passing emissions. I would just get someone /Medamullet to do an open source tune for you and have them turn off that trouble code. I wish i had the option, instead if have to actually fix codes and run a piggyback controller for my tuning. Open source is nice.
Old 02-15-2011, 07:08 PM   #17
Mush04
Member#: 191705
2007 Limited STi
Swp
is there no open source for N/A car's? I figured you could haha
Old 02-15-2011, 07:53 PM   #18
Tglazed
Member#: 231216
Just passed. just deleted the code, drove exactly 50 miles, and took it in and it passed. I was so happy haha
Old 02-16-2011, 12:39 PM   #19
Mush04
Member#: 191705
2007 Limited STi
Swp
well that's a good thing!! no more tickets!!
Help getting rid of CEL ToxicCrucible Newbies & FAQs 9 01-05-2011 03:14 PM
no cat. how get rid of cel 2.5racer Normally Aspirated Powertrain 3 08-10-2002 07:58 PM
How do you reset the ECU to get rid of a CEL? Jasno999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-19-2002 01:54 PM
So what is the best way to get rid of those damned Cats without triggering CEL? IncubusDude Newbies & FAQs 9 04-18-2002 02:11 PM
does someone in Ventura county has obd2 reader to get rid of my CEL? scoobypuff Southern California Impreza Club Forum -- SCIC 8 03-19-2002 05:02 PM
