Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC > NESIC Private Classifieds
Old 04-15-2011, 08:16 PM   #1
todeswalzer
Member Sales Rating: (45)
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
Just lowered prices for almost everything left. CHEAAAAP STUFF
SCROLL DOWN FOR PICS. IF YOU WANT TO SEE SOMETHING MORE DETAILED JUST ASK
Help me fund my sti drivetrain swap!
Located just outside of Lowell
Aftermarket:
sock from a walbro install kit. $5 pickup $7 shipped.
perrin p.s.r.s. RED bushings - $5 picked up $10 shipped.
Cobb license plate frame - $5 pickup
Brand new unused IWG arm off of a blouch e3 16g. got the grimmspeed bracket to go EWG so i didnt need it. - $10.
PLEXIGLASS HOOD SCOOP DELETE. MADE IT MYSELF. Fitment is GREAT, went KSTech delete to allow heat to exit - it needs new hardware, the stuff i bought rusted to ****. - FREEEEEEEEEEEEEEEEEEEEEEEEE.
Stock 05 STI flywheel + 8x flywheel --> crank bolts - came with the tranny i bought. Using an ACT flywheel. - $50
Stock 05 STI shift lever - also came with tranny. Bought a short shifter. - $20
ALL STOCK PARTS FROM MY 05 WRX:
WRB Crash beam + Styrofoam bit. Cut for JDM fogs. Went FMIC cant use it. - $40
Stock WRX Floor Mats. Front and Rear. - $25
Stock front and rear sway bars and rear sway bar end links. front end links are ruined from removal. both bars come with bushings. $20 each picked up per item (rear bar, front bar, or end links) or $50 for everything. pick up only for bars will ship endlinks for $25.
Stock intake Silencer/Snorkel Bit (goes in the fender) - $10
stock radiator hoses - $20 picked up $25 shipped. will split for $10 pickup or $15 shipped each
stock fender braces - $5 picked up
stock tmic-to-throttle-body coupling - $5 picked up
stock battery tie down - $5 pickup
stock t-stat - $5 picked up
stock fuel pump, has the wiring harness to connect to pump assembly - $10 pickup $15 shipped
tmic brackets - the one that bolts to the block. - $5 each
FOR GC8/2.5rs:
i bought a 2.5rs and these were all extras given to me with it.
white sti fog lamp covers - $25 pickup $35 shipped
big fat IMPREZA sticker/windshield banner - $5
stock shift lever - $5
Gc8 hid kit. Xentec. Bulbs are 6000K. These are 100000% plug and play. remove the stock bulb and stick the spade connectors in the stock harness, ground em out to chassis, and done. - $40
JUST ADDED:
stock turbo heat shield - both pieces - $20
airsoft gun with ~500 plastic bbs - $20
stock dual din 6 cd changer head unit out of my 05 wrx - $40
todeswalzer is offline   Reply With Quote
Old 04-15-2011, 08:17 PM   #2
todeswalzer
Member#: 191495
'05 WRB GTX3071R
05 WRB Trunk Lid with WRX Wing - This is completely separate from the wing i have for sale. Fully debadged. Great condition. - $SOLD
05 WRB WRX Hood Scoop - $50 pickup. $60 shipped. If you want the splitter too both for $65 pickup $80 shipped$OLD PICKED UP
05 wrx scoop splitters - $OLD PICKED UP
WRB WRX Wing - Bought a 2nd trunk lid to do my molded mines spoiler and it came with this. i dont need it. Near mint condition, no paint chips or deep scratches. The tail light wire does not have the connector clip - $SOLD $OLD PICKED UP
stock wrx tmic with y-pipe - take taken off around 50k miles - $OLD SHIPPED
stock exhaust manifolds heat shielding (all 4 pieces) - $OLD SHIPPED
stock exhaust manifold cross pipe - no longer has the heat shielding. $OLD
stock washer fluid tank - $OLD
stock 4EAT radiator (has tranny cooler and lines!) NOTHING WRONG JUST UPGRADED IT FINS ARE IN GREAT SHAPE.- $OLD
stock bov and elbow - $OLD SHIPPED
SRS (ebay) Bellmouth Downpipe - roughly 10k miles on it. - $OLD PICKED UP
unused SPC camber bolts new in packaging - $OLD SHIPPED
Walbro 255LPH Fuel Pump. Brand new. I was having start up issues thought it was the pump...replaced it and still same problem. so i put the old one in and brand new is for sale. literally less than 5 miles on it. no install kit pump only. - $OLD.
gc8 antenna delete. its brushed steel and says 'impreza' as well. $OLD
cobb turbo heat shield - wasnt on the car for very long. some scratches. ill take a good pic - $OLD
Stock plastic intake (grill to fender bit) - $OLD
stock oil cap - $OLD
stock pitch mount - $OLD
stock corner lights with amber bit - $OLD
Aftermarket gc8 TRACK PIPE - unknown brand - $OLD
Stock intake airbox - $OLD
Stock strut assemblies ~ 50k. - $OLD
stock 05 rear sway bar mounts for you guys with wimpy 02-03 mounts - about 55k miles on em - $OLD
stock anti lift kit - $OLD
Old 04-15-2011, 08:18 PM   #3
todeswalzer
Member#: 191495
'05 WRB GTX3071R
Marshall MG15CD amp - great condition - hardly used - $70
Jackson Dinky JX-10 guitar. Good condition, few scratches but great condition - $100
-3 ft cord, 12 foot cord, and Metal Masters Digitech pedal - $50
Guitar+amp+stuff combo - $!80.
XBOX 360 Steering Wheel/Pedal set (literally used once, I preferred using a controller)- $50 picked up
Oh and that Tomlinson jersey is for sale too. Not like anyone would want it...
Old 04-19-2011, 09:53 AM   #4
todeswalzer
Member#: 191495
'05 WRB GTX3071R
Bump. Adding a gc8 hid kit. Bulbs are 6k. Ill have pics/brand up later today. $50
Also added sti flywheel.
Old 04-19-2011, 07:06 PM   #5
handmesome02
Member#: 215874
2007 Forester XT
UGM
pm sent
handmesome02 is offline   Reply With Quote
Old 04-26-2011, 10:20 PM   #6
todeswalzer
Member#: 191495
'05 WRB GTX3071R
responded and talking.
HID Kit is Xentec. These are 100000% plug and play. remove the stock bulb and stick the spade connectors in the stock harness, ground em out to chassis, and done.
Old 05-01-2011, 11:17 AM   #7
todeswalzer
Member#: 191495
'05 WRB GTX3071R
Bumpp
Old 05-01-2011, 05:34 PM   #8
todeswalzer
Member#: 191495
'05 WRB GTX3071R
Struts sold thankyou
Old 05-02-2011, 12:26 AM   #9
rabbitnutz
Member Sales Rating: (8)
Member#: 51940
would you do track pipe and corner lenses for $60 picked up?
i'm in lowell usually once a week.
rabbitnutz is offline   Reply With Quote
Old 05-02-2011, 08:18 AM   #10
todeswalzer
Member#: 191495
'05 WRB GTX3071R
Pm'd.
Old 05-05-2011, 09:08 AM   #11
todeswalzer
Member#: 191495
'05 WRB GTX3071R
Bump!
Old 05-05-2011, 11:28 AM   #12
myklwrx
Member Sales Rating: (43)
Member#: 150791
2012 wrx sedan
you haz PM in yo box
myklwrx is offline   Reply With Quote
Old 05-06-2011, 09:33 AM   #13
todeswalzer
Member#: 191495
'05 WRB GTX3071R
Bump.
Wrx Airbox, pitch stop, oil cap sold today
rs track pipe and corner lights should be gone later
Also someone messaged me about the Cobb license plate frame but that got deleted when the forum rolled back. I don't remember who you are please message me again thanks l
Old 05-07-2011, 01:40 PM   #14
todeswalzer
Member#: 191495
'05 WRB GTX3071R
updated with solds bits and added some stuff for sale:
Old 05-09-2011, 08:51 AM   #15
todeswalzer
Member#: 191495
'05 WRB GTX3071R
To the top
Old 05-10-2011, 03:12 PM   #16
Sixthy
Member#: 257767
Hi...
Ehmm...
First question....
Would you ship to Europe, Croatia...?
If yes, I would be interested in some things...
Cheers!
Sixthy is offline   Reply With Quote
Old 05-14-2011, 09:49 PM   #17
todeswalzer
Member#: 191495
'05 WRB GTX3071R
bump. updated and prices lowered
Old 06-21-2011, 06:09 PM   #18
todeswalzer
Member#: 191495
'05 WRB GTX3071R
bump.
Old 06-22-2011, 09:42 AM   #19
boricuajr
Member Sales Rating: (33)
Member#: 62842
05 STI\98LGT\97OBS
AW White Grids - RED - WH
are you able to meet anywhere
I work in fitchburg and reside in worcester
possible interest in the fog covers for gc
boricuajr is offline   Reply With Quote
Old 06-22-2011, 11:25 AM   #20
ScoobieNoobie790
Member Sales Rating: (4)
Member#: 242947
13 WRX Hatch
is that airsoft gun spring or gas?
ScoobieNoobie790 is offline   Reply With Quote
Old 06-22-2011, 05:34 PM   #21
todeswalzer
Member#: 191495
'05 WRB GTX3071R
spring
Old 07-18-2011, 12:28 AM   #22
todeswalzer
Member#: 191495
'05 WRB GTX3071R
bamp.
WTB : lots of stuff....stock/aftermarket....getting my racecar back on the streets texas05sti TXIC Private Classifieds 6 11-25-2010 09:11 AM
GC8 Garage Sale!! Short shifter Tons of Stuff JDM Importers Drivetrain 9 03-14-2006 02:51 PM
Tons of stuff for sale mostly gc8 gauging intrest on brake duct scobaru Private 'For Sale' Classifieds 1 02-23-2005 11:00 AM
FS: Bunch of Stuff. Some Ebay some not. GC8,RS Rims,Xbox stuff,Alarm,Misc,free stuff dRu888 Private 'For Sale' Classifieds 6 01-02-2005 11:00 PM
Tons of stuff for sale: GC8 (turbo, tec, stereo, etc) preza Texas Impreza Club Forum -- TXIC 15 10-06-2002 04:06 AM
