Old 04-19-2011, 05:30 PM   #1
bishops'00RS
Member#: 260490
2003 WRX Wagon
Default Replacing alarm horn with supertones
I have been looking around on multiple forums and google but have not had any success finding an answer.
I want to replace the siren on my car alarm (DEI / Python PF5000) with the set of Hella Supertones I have installed. Does anyone done this / know how to do this? If so please explain how to go about doing this. I am wondering if it is as sinple as rewiring the wires from the alarm siren \ horn and wiring them up to the hellas (power & ground)
any help would be greatly appreciated.
bishops'00RS is offline   Reply With Quote
Old 04-19-2011, 09:23 PM   #2
863JOE
Member#: 271079
Yep. Its that simple
863JOE is offline   Reply With Quote
Old 04-19-2011, 09:52 PM   #3
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
hook the horn output on the alarm up to the car, call it a day, then you get both..
Should be able to set the horns onto a "full attack" mode, so just the alarm siren chirps and not the Hellas..
Old 04-19-2011, 10:24 PM   #4
bishops'00RS
Member#: 260490
2003 WRX Wagon
Great. so disconnect siren power (red) and connect to hella power (red) and I guess that ground (black) can stay as is. I was hoping it was that simple but I didn't want to F up my alarm. Hopefully I will get this done on Thurs.
Old 04-20-2011, 12:31 AM   #5
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I gave NO instructions on how to do anything, you came up with that on YOUR own...
You eff up your alarm and it's on you...
Old 04-19-2011, 11:41 PM   #6
WRB06K
Member#: 211320
2006 WRX
Do it its well worth it. You'll hear your alarm from 5 blocks away and gives you a piece of mind
WRB06K is offline   Reply With Quote
Old 04-19-2011, 11:47 PM   #7
bishops'00RS
Member#: 260490
2003 WRX Wagon
Yeah, car alarms are too common these days. barely anyone looks if you hear one going off. I want everyone looking at my car if it goes off.
Only thing is I have heard that you might need a relay but I figure if I tap into the Hella relay, that should take care of it.
Old 11-15-2012, 10:21 AM   #8
BraxtonGiles
Member#: 337468
My exact thought on this haha. Although my first idea was a train horn instead of Hella Supertones.
BraxtonGiles is offline   Reply With Quote
Old 04-20-2011, 09:19 AM   #9
863JOE
Member#: 271079
No need for a relay unless you want to do anything special. I put a 5 wire relay on my siren to a button thats used as the valet switch on the old DEI alarms so that I can make my siren chirp from the inside of my car. Why you ask? so I can piss off my neighbors ankle biter when I get home every day.
Old 04-20-2011, 12:15 PM   #10
bishops'00RS
Member#: 260490
2003 WRX Wagon
Nice... sometimes its nice scare the piss out of someone (or something) now and again. Haven't looked at the siren to make sure there are only 2 wires but I believe there are only two. I know there is a red (+) and a black (-) but now sure if there are additional wires. Regardless, sounds like it should make it pretty easy to rewire.
Old 04-20-2011, 03:05 PM   #11
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I have this set up on my alarm...
Old 04-20-2011, 03:12 PM   #12
bishops'00RS
Member#: 260490
2003 WRX Wagon
I'm not sure if that setup would get my point across. seems a little.... understated.
Old 11-19-2012, 04:25 PM   #13
Cpt_Pessimist
Member#: 333174
2004 WRX
Just imagine breaking into this car and hearing that ungodly alarm system...
Cpt_Pessimist is offline   Reply With Quote
Old 04-20-2011, 03:15 PM   #14
awdorgtfo
Member#: 252252
2007 WRX Wagon
vf39 ewg
There's no way that's loud enough! hahaha
awdorgtfo is offline   Reply With Quote
Old 11-19-2012, 04:00 PM   #15
rebornS14
Member#: 338337
1997 S14
depending on the alarm model, you can run both horns and siren and yes you do need a relay for the horn.
http://www.the12volt.com/relays/relays.asp
^THEY HAVE LOTS OF GOOD INFORMATION ON HOW TO DO WIRING IF YOU NEED
rebornS14 is offline   Reply With Quote
Old 11-19-2012, 06:03 PM   #16
rebornS14
Member#: 338337
1997 S14
they have those tiny ones from DEI.
for the inside of the car. pizeo siren
horns with aftermarket alarm island boyeee Car Audio, Video & Security 19 04-19-2010 10:56 AM
Question re: replacing factory alarm horn xfader Car Audio, Video & Security 23 02-04-2009 03:35 PM
Alarm horn dead. Easy replacement? mr2quick Car Audio, Video & Security 8 01-13-2009 12:29 AM
Supertones and OEM Alarm Horn? sanremo_russ Car Audio, Video & Security 8 01-28-2006 01:24 AM
How do I get the alarm horn to stop firing with the air horns? Schleppy Interior & Exterior Modification 2 04-09-2002 04:33 PM
Message Board Statistics All times are GMT -4. The time now is 01:55 PM.
