Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 07-21-2002, 12:29 PM   #1
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Default MAP sensor DEAD!, neutral Safety Switch DEAD, 1st recorded map kill?
MY00 RS. 36,800 5MT
my neutral safety swtich is dead, causing a bad idle, no biggie covered under warranty, (on order)
but the other day at idle, my car overheated, then shortly after MR CEL came on, and it started idling like crap, stalling and blowing black smoke.
pulled the code, its was Map sensor ckt high input I think, forgot to right it down.
car idles like crap, running extremely rich, doesnt drive bad, but not running good. Classic bad map sensor symptoms.
Its either my MAP sensor or my SAFC took a dump. I know it cant bee a wireing problem for my safc cause all the conecctions are soddered, though I will check them neway.
the thing that gets me is the pressure reading from my SAFC is good, its constant and doesnt fluctuate when the car runs bad.
anyone else have a map die on them.
im supposed to have the car dynod and the safc tuned this saturday too, I gotta get it fixe.
Jay McDade
Lincoln/Mercur/Jaguar Tech.
munkis is offline   Reply With Quote
Old 07-21-2002, 12:49 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
anyone have the part number for the map sensor?
Jay
Old 07-21-2002, 04:37 PM   #3
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Well I figured it would be in this pic but I don't see a listing for it.
Buster
EvasionOfTruth is offline   Reply With Quote
Old 07-21-2002, 04:45 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
thanks evasion.
1stsubaruparts.com, has a full oem parts catalog online with keyword searchs, so I didnt need the part number.
its 200.00 bux, wich makes me not happy.
The Map Sensor is in the intake manifold, on the diverside next to the coil pack .
Jay
Old 07-21-2002, 10:17 PM   #5
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Default possible recall?
I heard there was a recall/TSB on MAP sensors on late model 2.5 motors...you might want to check if you fall under that one so you can get it for free...
Good Luck.
-Milan
US2JDM is offline   Reply With Quote
Old 07-22-2002, 07:09 AM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Thanks Ill check it out.
If its late model 2.5s I dont think mine will fall under it, my rs has a build date of 12/99.
thanks!
Jay
Car Won't Start / Neutral Safety Switch neurotic Newbies & FAQs 3 12-21-2005 03:49 AM
Neutral safety switch...? adam555 Transmission (AT/MT) & Driveline 10 12-05-2005 10:25 AM
Neutral Safety Switch dfgu Factory 2.0L Turbo Powertrain 1 11-21-2005 01:23 PM
neutral safety switch code buru6 Service & Maintenance 2 08-16-2004 03:41 PM
neutral safety switch problems w/MT reveler Car Audio, Video & Security 2 10-24-2002 08:02 PM
Message Board Statistics All times are GMT -4. The time now is 01:26 AM.
