Old 08-15-2011, 07:38 AM   #1
Rymantas
Member#: 264225
2011 WRX Sedan
Lightbulb Weird Knock Event during driving 2011 WRX
I've read around and heard that our knock sensors pick up some strange events (ambient noise in engine bay). I have been getting a knock event that was very consistent on the logs. They were always spaced equally apart while driving at highway speed (70 mph to be exact) with cruise control on. The events would happen every 45 seconds or so. I thought maybe I had bad gas at first but as I looked at my logs i began to see a pattern. The knock events always occurred when the AC compressor would kick on. So I tested this by making sure recirc was on, AC was off, and blower was off. I drove 100 miles with no knock. So then I drove another 100 miles (distance to work and home) with the AC on and it knocked every time the AC compressor came on.
I then tried forcing it to happen by randomly turning the AC on and off. It would actually trigger a knock event while moving 2 out of 3 times i would do this.
I will be going through the engine bay and checking to make sure everything with the AC system is snugged up. Has anyone else had occurrences like this?
Rymantas is offline   Reply With Quote
Old 08-15-2011, 12:09 PM   #2
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
Yea check the engine bay and make sure nothing is loose. Are you running a custom tune or anything? What load and rpm are the knock events at? If they are at really low load, you could modify the Feedback Correction Min Load table.
D0nets is offline   Reply With Quote
Old 08-15-2011, 05:54 PM   #3
Rymantas
Member#: 264225
2011 WRX Sedan
Running Cobb OTS Stage 1 93. Occurs at 2800 rpm Highway cruising with cruise control on flat surface.
Old 05-06-2013, 01:01 AM   #4
kabz
Member#: 351744
2016 STI
CWP
Ok, I worked out that my stock 2013 WRX is doing this. A good chunk of the time, the AC compressor coming on creates a FBKC event, which decays over about 4 seconds.
This was really driving me nuts.
kabz is offline   Reply With Quote
Old 05-06-2013, 10:00 AM   #5
Cobb Tuning
Member#: 4803
If it is a single count correction (-1.4) or so, I would not worry about it too much. The engine control unit (ECU) actually has a delay in which it prevents a correction to feedback knock taking place shortly after the A/C compressor comes on (a tuneable table in our Accesstuner tuning software). It may be something loose as mentioned (which is rattling as compressor comes on) or it may be that that some false knock due to A/C compressor coming on is normal at times (I haven't specifically check for a connection between A/C and feedback knock before via logging so I can't say for sure).
Bill
Old 05-06-2013, 12:07 PM   #6
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
I have seen this on many cars, mostly 08+. I usually only see single to double counts registering in conjunction with the A/C compressor, and it always unlearns quickly.
endrswrd is offline   Reply With Quote
Old 04-13-2015, 12:44 PM   #7
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
I am getting this now too... Is the overall consensus that I just ignore?
JeffrWRX is offline   Reply With Quote
Old 04-16-2015, 09:54 PM   #8
enzomatic75
Member#: 266558
I wouldn't waste any sleep on it. I hit a big bump and it registered as a knock event the other day.
enzomatic75 is offline   Reply With Quote
2011 WRX COBB tuned 295 WHP / 320 WTQ Yellow_Feva Proven Power Bragging 23 12-25-2011 09:16 PM
Help analyze log, 2011 STi Stage 1 OTS knock event RoninSTI AccessPort 7 08-07-2011 01:43 PM
Weird knock / loss of power event (UTI logs) bpwatts UTEC 13 11-23-2006 12:37 PM
Any wintercrosses and driving events during winter? MachinesWRX New England Impreza Club Forum -- NESIC 28 11-17-2005 10:23 AM
Weird Knock Events ShaggyGT Engine Management & Tuning 29 01-22-2004 06:28 PM
