#1 |
Member#: 64908
Vehicle:10.8 XT+ Real stock turbo record holder 11.4 |
Event: Dyno Tune !
Location: P&L Motorsports Ambient Temp: 85 degrees F Elevation: sea level Weather: Just a mild day Car: 2005 STi Tuner: Junior2jz Dyno Info: DynoJet Peak HP at RPM: 645 @ 7000 Peak Torque at RPM: 508 @ 5750 Baseline hp/tq for a stock on same dyno: 230-240 Target Boost: 29-30PSI Target AFR: 11.7 Fuel: Straight e85 Engine/Power Modifications: P&L PS5 Block P&L CNC Heads Kelford 199c P&L FWD Face IC P&L 1600cc Fuel kit w twin Aero340s P&L Vband 6265 TurboKit .82 PTE Vband hotside AEM v2 / Cobb AP for emissions Cosworth Intake DSS ProLevel DSS DS P&L/Exedy Triple Disk This thing was built to mirror FastEddie's beast. Fast(slow)Eddie worked on the build from start to finish and it came out flawless! The P&L crew did it again!! The blue run went 10.1@139.8 The Green run was at 29-30psi and has another 500rpm to pull. Motor is pretty fresh so we didnt want to lean on it to hard on the first session. I think we will have some track numbers for it tomorrow. ![]() ![]() Last edited by Junior2JZ; 10-16-2011 at 05:47 PM. |
#2 |
Member#: 104200
Vehicle:828 WHP BUGEYE Street Proven Performance |
Tad's car ? great numbers!
#3 |
Member#: 64908
#4 |
Member#: 84105
SCIC
Vehicle:2005 Super Slow STi CGM |
Wow! Is the 6265 really spooling faster than the 6262 Eddie had on? Must be the E85
#5 |
Member#: 64908
I always said optimizing the exhaust wheel (EGBP) vs inlet pressure will result in faster spool, even with a bigger turbine wheel, turbine housing. Its all about matching everything up properly.
#6 |
Member#: 162151
E. Canada
Vehicle:2.6L BLUE THUNDER LOW&WIDE&SHAVED |
Great work again guys...
#7 |
Member#: 64908
![]() You would never expect the whoop ass! ![]() |
#8 |
Member#: 145658
Vehicle:On my 4th scoob and lovin it |
Looks stock. Makes monstrous power. Love it.
#9 |
Member#: 156247
Vehicle:05 STI-10.6 @ 134 GTR - 9.31 @ 151.78 |
Looks good
How many pounds of boost was the 10.1 car on? |
#10 |
Member#: 64908
Mr.V I should have the logs, but I think it was around 28-29psi as well. Im going to try and turn this one up at the track and see if we can get some low 140s out of it. It is still on the old style gear box.
This car reminds me of your car, looks stock until you mash the throttle. |
#11 | |
Member#: 156247
Looks like a beast Good luck |
#12 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
any timeslips? that'd be bad ass
dynograph looks amazing |
#13 |
Member#: 81102
Very nice, fatttttttt powerband
#14 |
Member#: 64908
10.3@133 shifting 5th
6.6@108 1/8th 27psi Just turned the boost back up to 29-30psi |
#15 |
Member#: 156247
#16 |
Member#: 64908
Bunch of missed gears.. the 05 sti trans is not liking life anymore. P&L long ratio on the way
It did make a bunch of 6.5-6.8@106-108 1/8ths though |
#17 |
Member#: 77470
Vehicle:04 sti 10.51@138.5 on e85@ 30psi--spinning |
I assume he is running the hoosier dr's jr.
#18 |
Member#: 64908
Yes they are
#19 |
Member#: 64908
Vids will be up soon.
Wait til you see this guy hit gears. The car sounded like an auto going down the track. Well until the missed gears .. lol Best 60ft was a 1.54 Last edited by Junior2JZ; 09-11-2011 at 01:56 PM. |
#20 |
Member#: 156247
Why no avcs?
#21 |
Member#: 1199
Vehicle:1994 Supra+1K, 22b alike, 07STI |
#22 |
Member#: 103631
Vehicle:2004 STI Black |
If you had kept the AC in that car, it almost looks as though you could drive it daily (sorry I'm from Hawaii, so no A/C means not driven daily).
I'm going to guess that your times would improve with the longer gear set. After driving a z06, I realized how short the 257 powerband is compared to the gearing. |
#23 | |
Member#: 64908
The trans is happening, it will pick up some big mph. Im estimating we lost 4-5mph with the shifting of 5th. I say once the car gets the gearbox and Tad makes a full boost pass we will see some 9.80s at 140-142mph |
#24 |
Member#: 108089
#25 |
Member#: 124663
South East
Vehicle:2003 AW WRX 2008 GG Evo X MR |
I'm impressed... Especially since this is the turbo I'm going to be running. not sure I can bust out those ETs though. I have a PPG 5 speed.
| Thread Tools | |
| Display Modes | |
| FT : Cleared 05 sti headlights FOR stock 05 sti headlights | GallardoKing | NWIC Private Classifieds | 4 | 11-07-2011 12:13 PM |
| FS : 05 sti Project Mu. Rear brake pads FO FREE!!!! | sundayWRX | Suspension/Brakes/Handling | 10 | 01-04-2011 03:13 PM |
| 05 sti project, soon on 18x9.5 rota grids | stilv | Member's Car Gallery | 88 | 09-25-2009 04:04 PM |
| 05 sti project car.. only 25k miles! | michsti | Private Vehicle 'For Sale' Classifieds | 1 | 07-13-2009 03:06 PM |
| 05 STi stage 2 dynotuned... at AMS? | EarlQHan | Proven Power Bragging | 76 | 08-17-2007 02:57 AM |
