Old 08-05-2002, 01:20 AM   #1
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Default Odd unorthodox pulley side effect...
I got a used unothodox underdrive pulley installed on my car last week and noticed a very weird side effect since the install..
My A/C sounds like a freakin blow off valve everytime it turns on and off!!!
Im guessing its a result of the underdrive... I never planed on trying an underdrive pulley, but the price for this one was impossible to pass up
Anyone else have this problem?
(Note: I have a '95 with an EJ18... Not a rex or RS or anything remotely powerful )
Old 08-05-2002, 03:32 AM   #2
Basshead
Member#: 112
2011 Jetta TDI
hmmm...perhaps your belt isn't tight enough, may be slipping everytime and causing the noise..might wanna check it out, even though that bov sound is to die for..
Basshead is offline   Reply With Quote
Old 08-05-2002, 04:39 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
kostamojen-mine sounds that way since i put the flywheel in, it's only at idle though *shrug* first time i turned it on i was SURE the compressor was locking up...then i checked another RS with a flywheel and it sounded the same....oh well just another quirk.
jeremy
HndaTch627 is offline   Reply With Quote
Old 08-06-2002, 01:59 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I belive its damn tight...
Old 08-06-2002, 02:26 AM   #5
ImprezaTs
Member#: 1086
99 Impreza TS
Black Diamond Pearl
what brand of UD pulley you got? I am thinking of getting one too.. but would most UD pulley have the same effect as yours did?
ImprezaTs is offline   Reply With Quote
Old 08-06-2002, 02:35 AM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I think its just specific to my car... I dont think racecarriot even had this problem with the UD (unorthodox btw) pulley on his EJ18 L...
Old 08-06-2002, 07:04 AM   #7
ImprezaTs
Member#: 1086
99 Impreza TS
Black Diamond Pearl
ok thanks for the reply... but what brand and price you get for?
Old 08-06-2002, 11:01 AM   #8
Blindeye_03
Member#: 4418
2016 Focus ST
Does it slip when you shift? Thats what mine is doing. I need to tighten it up more (I dont think it can go much further)...but I may end up buying a smaller belt.
Oh and mine sounds loud when tje A/C turns on and off .
-justin
Blindeye_03 is offline   Reply With Quote
Old 08-06-2002, 12:29 PM   #9
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
It's not the pulley or the belt...all Scooby AC Compressors start to make this noise as they get older.
Opie is offline   Reply With Quote
Old 08-06-2002, 12:49 PM   #10
RaceCarRiot
Member#: 6542
1997 Ver IV
whoa, watch out! -- it could be the signs of your idler pulley/bearing on the a/c compressor starting to go.
mine started making all kinds of weird turbo whine-like noises right before it went...incidentally about 5 months after putting on the N1 pulleys, although they aren't underdriven.
you'll know when it goes, because you'll start your car, and hear the most awful metal-on-metal scraping you'll ever hear...as in you can't SHOUT over it. if it does, just remove the idler assembly, and you'll be fine...except you won't have any way to run your a/c. if you want to check it, i suppose you can remove the belts, and turn the pulley by hand -- the one i removed felt VERY gritty when i turned it.
here's the REAL beeeeyotch about the whole thing -- subaru doesn't sell the pulley/bearing separately, so you have to buy a WHOLE new assembly with the bracket, then disassemble that (the new bracket didn't fit my car) to get just the pulley/bearing assembly, and stick that on the old bracket. the entire assembly should run you $90-100 new...ugh...
i tried locating the pulley alone (for several months), and anything i could find in a junkyard was just as bad, so i just bought the whole thing new from the stealership. of course then once i got that back together, my a/c started that weird shuddering nonsense at idle (still works fine under load), so i've been running without a/c around town for almost a year...
-adam-
RaceCarRiot is offline   Reply With Quote
Old 08-06-2002, 12:50 PM   #11
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
he said UNORTHODOX!
as for the sound....it seems they have covered the basics...i dont think mine sounds like that....pretty much mine just blows out less air it seems..
andres
ATX25RS is offline   Reply With Quote
Old 08-07-2002, 03:58 AM   #12
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
here's the REAL beeeeyotch about the whole thing -- subaru doesn't sell the pulley/bearing separately, so you have to buy a WHOLE new assembly with the bracket, then disassemble that (the new bracket didn't fit my car) to get just the pulley/bearing assembly, and stick that on the old bracket. the entire assembly should run you $90-100 new...ugh... -adam-
Damn, that sounds about right too... Its starting to make a constant noise now as well albiet hard to hear.
Anyway, i have a subaru specific recycler yard 15 minutes from here I can check if it the thing just dies out like that...
$180 Good for Unorthodox Pulley?? BrysImpreza Normally Aspirated Powertrain 2 04-10-2001 11:44 AM
unorthodox pulley IMPREZA GUY Normally Aspirated Powertrain 4 03-30-2001 09:52 AM
Unorthodox pulley subymamma Newbies & FAQs 21 11-02-2000 09:27 AM
Unorthodox Pulley Install - how do you break that F*&#ing bolt???? Tim Harris Technical Forum Archive 19 06-02-2000 09:55 PM
Loss of A/C at idle with Unorthodox Pulley? Impresario Technical Forum Archive 4 05-16-2000 07:18 AM
