Old 12-29-2011, 10:55 AM   #1
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
UPDATE: I traded you Injen intake for a stock and it fixed my misfire issues. As soon as I installed in the oem intake I now notice I have a boost leak and the noise coincides when the turbo is under load. Is it maybe the turbo intake? Little stumped on this. Didn't hear the noise with the Injen intake and it is a very loud noise.
bassplayer5504 is offline   Reply With Quote
Old 12-29-2011, 11:06 AM   #2
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
It is quite possible it's an Ignition issue. You should check your Coil Packs and Spark Plugs.
kayen is offline   Reply With Quote
Old 12-29-2011, 11:15 AM   #3
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
most likley a coil. happened on my vw and chevy when the coil went bad, the moisture will get into the crack of a bad/cracked coil and cause issues when raining. find the bad coil by removing and inspecting, or buy a good one and swap until issue goes away.
jayman4312 is offline   Reply With Quote
Old 12-29-2011, 09:50 PM   #4
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
Thanks! I will check the coil packs and report bad.
Old 10-06-2012, 11:47 AM   #5
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
bumping this because I have codes in OP and still need help!
Old 10-06-2012, 11:54 AM   #6
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
There is no actual way to "check" the coil packs unless there is significant visual damage or you can swap to a different cylinder. Do the codes only show up when it rains? Sorry if its in the op then I missed it.
boosted25 is offline   Reply With Quote
Old 10-06-2012, 12:40 PM   #7
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
yes, only when it rains. no other time will I have the issue.
Old 10-06-2012, 01:51 PM   #8
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
Might seem a little far fetched but maybe an ecu problem? Seems like too many codes come up that don't effect each other. Really hope someone chimes in with experience with your issue. Possibly swap with a buddies ecu? Wouldn't hurt to rule it out.
Old 10-06-2012, 01:53 PM   #9
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
No one in my area has a wrx that i know. Any way to test it?
Old 10-06-2012, 04:56 PM   #10
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
OMG...such guesses here...bad guesses
this is a harness issue....there is a plug getting wet and shorting out a bit
iirc this one is the big brown one behind the battery...
Old 10-06-2012, 05:43 PM   #11
itr.#1446
Member#: 162447
03 Wrx
Sonic yellow
Also how about the ones under the intercooler for the trans and rear o2 sensor it would make sense that when it rains it's going in the hood scoop thru the intercooler and right on them. Also see if a wire has rubbed thru, a lot of sensors could be on the same ground circuit.
itr.#1446 is offline   Reply With Quote
Old 10-07-2012, 12:00 PM   #12
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
What is this harness for? Gonna check it out, get it a little wet and see what happens.
Old 10-07-2012, 06:35 PM   #13
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
OK. Wetted these harnesses down and nothing..........any other guesses?
Old 10-08-2012, 09:01 PM   #14
Uncle Scotty
OK buy Nates beans
meaningless
take the bloody connector apart and LOOK for corrosion
Old 10-09-2012, 08:02 PM   #15
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
meaningless
Checked it out. Seems to not be worn, is intact, and clean.
Gonna check out the maf again tomorrow.
Old 10-07-2012, 07:37 PM   #16
itr.#1446
Member#: 162447
03 Wrx
Sonic yellow
Did you check under the intercooler on the trans where the harness attaches there?
Old 10-08-2012, 08:30 PM   #17
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
yessir.
Old 10-08-2012, 01:45 PM   #18
awd-turbo
Member#: 167551
02 wrx
i had this issue... mine was cause the MAF sensor was getting wet...
the car would stutter like you hit the rev limitor... but more violantly..
awd-turbo is offline   Reply With Quote
Old 10-08-2012, 03:06 PM   #19
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
I bet you had an aftermarket intake.....
Old 10-08-2012, 08:28 PM   #20
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
I checked the maf sensor and it seamed dry and clean. It may have dried quickly after it had rained. I checked the morning after the issue had began. I originally had this problem after the car had set for about eight hours during my shift and it had snowed about two inches. When I started the car up it would rev high and then die. Did this three times until I gave it some gas and that kept it running.
Not sure if this is any help..........
Old 10-10-2012, 09:17 AM   #21
awd-turbo
Member#: 167551
02 wrx
yea... i would drive 1/4 throttle and it would dry out after a couple of miles and be fine...
Old 10-10-2012, 09:15 AM   #22
awd-turbo
Member#: 167551
02 wrx
actually i didnt...i did how ever removed the tubing in the wheel well...
Old 10-10-2012, 01:35 PM   #23
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
So do you still have the issue or is there something to resolve it?
Old 12-09-2012, 08:46 AM   #24
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
Talking with subaru they think it is a maf sensor. Any thoughts? I wouldn't think this would cause misfires.
Old 04-24-2013, 08:29 PM   #25
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
bumping this up for more help, please see OP with more info.
When it rains it pours chri3 Off-Topic 24 02-24-2005 12:01 PM
When it rains, it freakin' pours.... gjhsu Texas Impreza Club Forum -- TXIC 25 01-21-2005 12:11 AM
When it rains it pours... 4x4GGG Off-Topic 58 03-05-2004 03:00 PM
ARG! when it rains it pours! munkis Tri-State Area Forum 9 12-30-2002 10:05 PM
When it rains, it pours : another Ford recall. Snoopy General Forum Archive 26 09-01-2000 03:56 AM
