Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 01-11-2012, 07:49 AM   #1
Caseman
Member#: 273103
Default O2 Sensor. Does not fit
I just ordered my 2nd O2 sensor and it still will not fit.
(from *Rockauto* DENSO Part # 2349122 OE Style
DENSO is the O.E. Manufacturer / Air Fuel Ratio Sensor; Upstream)
The red circles show 2 tabs on the current sensor that the new one does not have.
The new one is the blue one.
Do I have the wrong one? It was far less expensive the the other sensor which was $230
I only paid $130.
I understand you get what you pay for but you would think it would at least fit.
2005 92x Linear (impreza rs ) BTW
Sorry if this is in the wrong section. I picked electrical because I am thinking some one swapped my harness or something.
Caseman is offline   Reply With Quote
Old 01-13-2012, 12:59 AM   #2
SAx Colin STi
Member#: 227895
Is the length of wire between the sensor and connector the same? If not it's probably the wrong one.
SAx Colin STi is offline   Reply With Quote
Old 01-13-2012, 10:11 PM   #3
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
upstream expensive, downstream less expensive...
CosmoTheCat is offline   Reply With Quote
Old 01-14-2012, 08:56 PM   #4
Ben Armato
Member#: 14432
2002 WRX Wagon
Looks like you need the Denso # 2349123.
Ben Armato is offline   Reply With Quote
Old 01-15-2012, 03:21 AM   #5
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
there are upstream and downstream sensors
dont try to use one for the other....wont work
do NOT buy ANY 'universal fit' o2 sensor for your subaru....odds of it working properly are VERY slim
FS: WRX TMIC w/ STi Y-Pipe, o2 sensor, oil pressure fitting, oil pump, water pump toflaherty Engine/Power/Exhaust 17 09-10-2009 04:05 PM
WTB: rear O2 sensor that will fit a 98L minhha2006 Private 'Wanted' Classifieds 1 03-26-2009 03:22 AM
How come our O2 sensor does NOT adjust A/F ratio? GregUnd Texas Impreza Club Forum -- TXIC 11 10-23-2002 11:59 AM
Amsoil filter does not fit! jlyttle Normally Aspirated Powertrain 16 04-18-2001 01:47 AM
My new wing does not fit! david2z4 Technical Forum Archive 13 07-17-2000 09:58 PM
