Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 08-16-2002, 11:30 AM   #1
jmott
Member#: 6713
2007 Prius
brown
Default re-reading "how to make your car handle" last night
interesting bits:
*the amount of weight transfer that body roll adds is basically zero. Only a tiny amount (<3% of the cars weight) of weight transfer is added due to the CG of the car changing as the car rolls.
In other words, you could have bricks for springs, and 50mm swaybars and the weight transfer in a corner won't really change.
the only way to reduce the weight transfer is to lower the CG of the car.
*changing the roll stiffness on one SIDE of the car causes more of the cars weight to be transfered to that side of the car in a corner. so a stiffer rear bar, or stiffer rear springs, causes more weight to transfer to the rear of the car. which is how you can tune over/undertseer with stiffer swaybars/springs etc.
*the main reason to reduce body roll (besides the *Slight* reduction in weight transfer) is to reduce the amount of camber change mid corner.
so from this what can we learn?
body roll really isn't all that bad.
lower is better.
adjustable swaybars and struts are going to be useful for dialing in the over/understeer properties of the car.
jmott is offline   Reply With Quote
Old 08-16-2002, 11:43 AM   #2
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
yep, lower is better. unfortunately i only went with the 30mm srpings over the 45 mm ones. my car is still ever so slightly lower than yours. plus i'm a little shorter than you so i don't move the CG much.
Orion is offline   Reply With Quote
Old 08-16-2002, 11:44 AM   #3
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
BTW - I got your 'secret mod' last night. My copy looks like someone went to Kinko's to make it.
Old 08-16-2002, 11:50 AM   #4
jmott
Member#: 6713
2007 Prius
brown
heh
mine arrived yesterday as well
its the content that counts! not the presentation =)
Old 08-16-2002, 11:51 AM   #5
jmott
Member#: 6713
2007 Prius
brown
haha
I dunno, when I measured with my high tech water bottle tool
it seemd the same
we need those ground controls that prey has
so we can jack it down for the autox
Old 08-16-2002, 12:05 PM   #6
LiquidIQ
Member#: 6408
2004 MINI 2011 WRX
Dark Silver & White
I think tuning the understeer/oversteer is cruicial though, IMO. When I went to a 22mm adj. rear sway and endlinks, I noticed the car being very uneven but at the same time, I could not get the back end to swing out. When I put the 20mm front sway on, I have noticed the car being MUCH more nuetral and definately better handling than stock. I can take a corner much faster with more confidence because of the predictability and the front end not dipping as much as it was. It will be interesting to see what happens when I go to a coilover system. I'll more than likely have to either stiffen or loosen the rear sway to adjust.
This is with stock springs/struts and 17" wheels with Yoko AVS Sports.
- Steven
LiquidIQ is offline   Reply With Quote
Old 08-16-2002, 12:09 PM   #7
jmott
Member#: 6713
2007 Prius
brown
the increase in speed you noticed through the corner you noticed (which I kinda doubt you experimented with scientifically, kinda scares me to try!) may have been due mostly to reduced camber change in the corner.
OR, from better dividing up the cars weight between front and rear.
and yeah, when I get some sort of adjustable strut setup, I will experiment with going back to the stock front sway bar and set my rear bar softer.
- Steven
Old 08-16-2002, 12:17 PM   #8
Tex-WReX
Member#: 7107
2014 Mustang GT
http://shopping.yahoo.com/shop?d=b&i...0&note=1#notes
I have this book and it is also a good read. Anyone that would like to check it out, I will bring it to the next auto-x.
ps- you guys have a link to purchase the handling book?
thanks
Tex-WReX is offline   Reply With Quote
Old 08-16-2002, 12:19 PM   #9
jmott
Member#: 6713
2007 Prius
brown
www.amazon.com
search for "how to make your car handle"
thanks
Old 08-16-2002, 12:48 PM   #10
LiquidIQ
Member#: 6408
2004 MINI 2011 WRX
Dark Silver & White
Yea, it might be the reduced camber change, I have about a degree in the front. I think a lot of it though, it the better balance of weight through the car when doing the corner. I don't feel the rear or the front getting floaty at all, it just sticks.
There's this turnaround by the best buy and it's a two lane 90degree turn, twice. Since it's two lane, you have a little play room. Stock I would understeer that mother like a bish, with the rear, I could feel the rear floating a tad, but now it's quite nice and crisp through the turn.
- Steven
Old 08-16-2002, 12:58 PM   #11
Tex-WReX
Member#: 7107
2014 Mustang GT
Default thanks
Old 08-16-2002, 02:52 PM   #12
Bad Dogg
Member#: 8331
2002 WRX Wagon
Stealthified
Default You can buy it at borders
on alabama, along with max. boost by corky bell - both good bedtime reading.
Bad Dogg is offline   Reply With Quote
Old 08-16-2002, 07:35 PM   #13
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Two (three?) words for you. Anti-lift kit. I just did this last night and the change is very substantial. Took my favorite 2 turns 5-10 mph faster last night, that would be from 100->105 and 45->55 mph. That's exit speed, btw.
wcbjr is offline   Reply With Quote
Old 08-16-2002, 07:41 PM   #14
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
Big problem for most of us....
ALK is illegal for Stock, STS, STX, SP classes, and even SM!
Besides a good set of coilovers will be more versatile and would eliminate the need for an ALK. Sure it's 10-20X for coilovers, but they are legal and adapt better to specific conditions. Many of us AutoX or go to track events. If I didn't race, the ALK would have been on my car last November!
Old 08-16-2002, 09:23 PM   #15
Bankheist
Member#: 2237
2000 GC8 STi
2015 Ford Mustang GT
we're going out for a drive soon.
Bankheist is offline   Reply With Quote
Old 08-17-2002, 10:57 AM   #16
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
How would coilovers eliminate the need for the ALK? For one, the ALK changes suspension geometry, notably .5 degress positive castor. Also, it replaces bushings with less compliant ones. How would coilovers do that? Sure they could lower the car a bit, that would help. But other than that, how could they achieve the same results?
edit: castor, not camber
Old 08-17-2002, 11:01 AM   #17
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Oh, and you guys really didn't read this post. Just in case I want to run in SM someday...
Old 08-17-2002, 08:58 PM   #18
jmott
Member#: 6713
2007 Prius
brown
anti-lift
stiffer struts and springs wont let the front end lift as much.
simple =)
Old 08-18-2002, 06:02 PM   #19
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Yeah, but you'll be hopping and sliding all over the place. Fine if you like to hit cones.
How to make your car faster and reduce the stress on your transmission Unabomber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 04-13-2011 01:29 PM
How-to make your car look perfect (polish, wax, etc)!! Phil Jr. Car Care & Detailing 187 07-24-2006 09:18 PM
Free mods to make your car faster... driver8 South East Region Forum 5 04-14-2003 03:19 PM
How to make your car handle to your liking Eric SS General Community 4 11-10-2001 05:34 PM
('93-'01) something that is supposed to make your car invisible to radar? Keirik Impreza Forum 9 05-15-2001 08:54 PM
