Old 02-20-2012, 06:02 PM   #1
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
I want hear the stories, the good, the bad, and the ugly.
Trying to make a decision on what to use on a car running 35+ PSI / 700ish WHP
I have the 625+ 11mm in stock, the P&L and AMR are on backorder for a month. Cost is a non-issue.
Anyone put any real boost through the 625+ yet? Anyone have any problems using the bigger stuff?
Keeping the extra material in the block with the 11mm sounds nice as long as they can take the pressure. If I have to, I will wait for the bigger stuff.
Heres some data I found, I am not an engineer.
ARP CA625+
Material - ARP Custom Age 625+
Yield Strength: 235-255,000 PSI
11mm body diameter
Tensile Strength: 260,000 PSI
Torque Spec - 100ft lbs
P&L
Material - ARP2000
215,000-220,000 clamp load rating
13 mm body diameter
110 ft/lb torque spec
Larger 24.5 mm/o.d. washer for increased clamping area
AMR
Material - 8740 chromoly
220,000 psi clamp load rating
9/16 diameter (14.2mm)
120ft/lb torque spec
No Limit Motorsport is offline   Reply With Quote
Old 02-20-2012, 06:09 PM   #2
B.R.E.D
Member#: 289606
06 WRX
white
Trying to make a decision on what to use on a car running 35+ PSI.
The 625+ are where its at in my opinion. We have used them to over 600whp and had no issues. I'm sure that the AMR studs are nice but thats a lot of work for something that doesn't really need to be done.
B.R.E.D is offline   Reply With Quote
Old 02-20-2012, 06:14 PM   #3
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
K thank you that is one reputable source down.
I just heard that the boys at Georgie Performance have been using stock diamter (L19) studs with good success. That tells me the 625+ would only be better.
Old 02-20-2012, 06:59 PM   #4
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
I have the custom age 625+ . I run the calculations and even with the larger cross sectional area and 10ft/lbs more at final torque the P&L 13mm have less clamping force than the 625+.
Old 02-20-2012, 07:00 PM   #5
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
How much horsepower are you running and how many pounds of boost? I need results not math lol
Old 02-20-2012, 08:40 PM   #6
juanmedina
Member#: 133146
lol everything is math... .
I just started my car for the first time,,, it has run 5 minutes so far. I will have some numbers soon.
Old 03-04-2015, 08:53 PM   #7
KinkSti
Member#: 414850
2004 WRX STI
What has your experience with the CA625+ been like?
KinkSti is offline   Reply With Quote
Old 03-07-2015, 07:19 PM   #8
nitsuj
Member#: 87081
05 PSM STi
05 AW XTi
Holy old thread lol
I run 38psi on the 625's w/o any head lift
nitsuj is offline   Reply With Quote
Old 02-20-2012, 09:27 PM   #9
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Real world experience > math/theories
Md05STI is offline   Reply With Quote
Old 02-20-2012, 09:48 PM   #10
juanmedina
Member#: 133146
Probably every part on our cars has gone through an FEA analysis
Old 02-20-2012, 10:09 PM   #11
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
While it probably has, just because math and theories say it will work.... doesn't mean it will and vise versa.
Old 02-20-2012, 11:19 PM   #12
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
but to play devils advocate, that makes the 625 more prone to failure for the same given defect in material. However from what little I know, L19 as a material is quite susceptible to defects in processing.
I had planned on guinea pigging the 625 11mm in my own car this year. 14mm have never given an issue but they're pricey. They're the only oversized stud that Darton East will install.
Old 02-20-2012, 11:46 PM   #13
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Anyone know what studs the other fast cars are running? Obviously p&l are running their own
Easy street? Rigoli? Roger Clark? Precision tuning? I'm sure I am forgetting a bunch.
Evo guys making 700ish tend to go for the L19 studs stock diameter with no issue. We have built a couple evos that make just over 800 with L19. Different application though.
Old 02-21-2012, 08:19 AM   #14
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Roger Clark has their own 14 mm headstuds
berdugo is offline   Reply With Quote
Old 02-21-2012, 10:52 AM   #15
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Interesting, good to know.
Old 02-21-2012, 11:08 AM   #16
berdugo
Member#: 163108
07 EuroDM STi 2.5L
the Gobstopper don't have a headgasket, they use o-rings and something like o-rings to separate the oil and water from the block going to the heads. It works for closed deck Subaru engines only, I think version 3 and 4 STI engines. lots of machining but they have proven their technology
Old 02-21-2012, 11:30 AM   #17
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Awesome. I love that car.
I made some phone calls. I am going to give the CA625+ a go. Going to O-ring the block and run Cosworth headgaskets. If it lifts, I can always do bigger studs. I have faith it won't at the power levels this thing will see. Its also going to save about $400 in work that the machine shop wanted to do the job.
Just waiting on my billet JE pistons to get here so I can sleeve this thing and get the ball rolling...
Old 02-21-2012, 10:16 PM   #18
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I know of 3 places working on this with one putting one into use and it seems to be working so far on a semi-closed block.
Old 02-21-2012, 08:10 AM   #19
CatfaceType-R
Member#: 81102
I think these guys are doing Orings in racing.(the Evo guys surely are)
What are your guys retorquing strategies after initial install?
Old 02-21-2012, 10:51 AM   #20
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
The Evo's we did were not o-ringed. I am sure some do, and it can't hurt.
This particular Subaru motor is getting O-ringed
Old 02-21-2012, 11:38 AM   #21
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Old 02-21-2012, 02:48 PM   #22
jamal
Member#: 71875
98 Legacy GT
my wheels fit
what's the biggest stud that will fit through the stock dowels?
also, wrc cars use larger studs on the center two holes. It's something I've thought about doing.
Although we were up to 38psi on cosworth 11mm L19 studs. I think keeping the headgasket together is more an issue of temperature management than it is headstud size.
jamal is offline   Reply With Quote
Old 02-22-2012, 09:13 AM   #23
CatfaceType-R
Member#: 81102
Originally Posted by jamal View Post
also, wrc cars use larger studs on the center two holes. It's something I've thought about doing. Interesting!
^^^^^^ this.
Old 02-22-2012, 02:56 PM   #24
Homemade WRX
Member#: 33782
96 bastard child
Originally Posted by wrx_driver_2002 View Post
I am running the A1 Technologies Bolts. 620 whp at 28 psi on a GT4094R with E85 and a mustang dyno. I plan on pushing the boost to around 35 psi in two weeks.
The MA performance bolts, I have heard good things about them. Which variant?
on a semi-closed deck with stock liners? That doesn't seem like a worthwhile endeavor.
there's a guy in norway with wills rings:
That's Bjornar. I know his engine came apart though he I don't recall why. He ended up going back to a 2.0L with parts that he had sitting around IIRC. So no real in-depth feedback from long term use, that I know.
Old 02-22-2012, 04:33 PM   #25
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
I am using the H11 / L19 variant because I didn't know they offered other materials. So far no problems. Car runs amazingly and has held onto all of it's coolant without filling the overflow bottle since July. It is not daily driven and lately with the weather conditions, it's only been driven on average of once every other week. Since july I have only put about 2200 miles on this engine. With 1500 of them at 16 psi, 500 at 20 psi, and 200 at 28 PSI.
wrx_driver_2002 is offline   Reply With Quote
FS : EJ257 block w/ Darton Sleeves, O-ringed, P&L 13mm head studs bugeyesubby Tri-State Area Private Classifieds 9 11-12-2011 08:00 AM
FS : (NJ): EJ257 block w/ Darton Sleeves, O-ringed, P&L 13mm head studs bugeyesubby Engine/Power/Exhaust 8 04-10-2011 07:25 PM
FS : NJ: sleeved,o-ringed 2.5 block w/ P&L 13mm head studs EmaciatedCow Engine/Power/Exhaust 7 02-14-2011 02:56 PM
2007 Prodrive Time Attack Challenge 9/15 & 9/16 wrx grl Southern California Impreza Club Forum -- SCIC 87 09-12-2007 12:33 PM
Perrin vs U-R vs P&L FromEvoToRS37 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 08-22-2007 01:10 AM
